How does the XYZ Probe Plus find zero?
Discussion in 'Interfaces' started by Willis, Feb 13, 2025.
  1. Willis
    Willis New
    Does the XYZ Probe Plus find zero by probing the edges of the fixture or the hole? If I place the probe plate on a corner of my work piece it probes the edges of the fixture then tries to center the cutting bit in the hole. Which one is considered zero? The reason I ask is if I use a three flute cutter, there isn't a way to find the center of the bit in x/y coordinates. How would the probe know what bit I have in the collet and at what rotation? After probing, the interface tells me it has measured the bit to a xxx mm diameter. It is often off. Does the Open Builds CAM software use this diameter for cutting or does it use the bit I chose in my set up (VCarve Pro). They would be different and one would give me an incorrect cut.
    Lastly: The XYZ probe doesn't want to stay on the corner of my work piece - mostly because of sort of stiff wires which push it around. I click "Probe" and quickly run to the router to hold it in place (I keep my laptop far away from the sawdust and chips). Have others found this a problem and what is their solution? Tape it down, I suppose. Sure would be nice to have "probe start" on the jog widget. Wink, Wink.
    Probe with a precision dowel pin. Install endmill. Do Z probe. That sidesteps the flute issue entirely
  3. Willis
    Willis New
    Thanks Peter. So why probe the hole at all? Seems like probing the sides of the fixture should locate the work piece in X, Y and Z.
    Correct, why would you do that? It's entirely optional, it's your your choice to include it if you have a need for it or not (no calipers, but need more precise endmill diameter for your CAM setup too - works bang on for most of the endmill here in the lab)
    If you don't have a need for it, don't use it: use XYZ Zero tab instead of Automatic tab in Wizard. You as operator pick which probing operation you want to use:
    Vs
    Always read the onscreen instructions :)
    Willis likes this.
  5. Willis
    Willis New
    That explains it all! Thank you Peter.
