Tech support for Javascript Macros in CONTROL
Discussion in 'Control Software' started by sharmstr, Jan 4, 2021.
  1. Alain JBT
    Alain JBT Well-Known
    Hi @Misterg
    Happy to see you again, thank you for your answer
    If you tested the BIG THING I will test it as if it were Christmas :)
    And as the proverb says with us "everything comes in time for who knows how to wait":thumbsup:
    Thank you very much and take care !
    Misterg likes this.
  2. BASt_NL
    BASt_NL New
    Question; if you have the doorsensor enabled in the firmware.
    When you run a job, it will succesfully trigger.
    But when youre not running anything, you wont see anything, but controls are locked and the console will state: [14:59:10] [ ] [MSG:Check Door]
    Would it be possible to have a json macro to trigger a popup either when the door is triggered (although that doesnt show in the console), or show a popup when that Check Door message is returned?
    (I dont always have the console in view, so i wont see it otherwise)
    You should be able to yes,those statusses are available in that laststatus global object inside CONTROL (look at laststatus.comms.runStatus)
    https://github.com/gnea/grbl/wiki/Grbl-v1.1-Interface
    Here's how we parse it for the bottom bar, we do show door status there:
    https://github.com/OpenBuilds/OpenB...fa2d2ff082edb4c/app/js/websocket.js#L643-L664
    (use laststatus in place of status if copying above)
  4. BASt_NL
    BASt_NL New
    That does state " upload_2025-2-24_15-37-20.png indeed, completely missed that, thx
  5. wienans
    wienans New
    Hey Guys,
    i have the following use case. I want to have only one PC controlling multiple Blackbox X32 in parallel. For that i found that normally the CONTROL Software only streams the data and i need to use the SD Card.
    Currently i have this:
    Code:
    let fileInput = document.createElement("input");
    fileInput.type = "file";
    fileInput.style.display = "none";
    document.body.appendChild(fileInput);
    fileInput.addEventListener("change", async function() {
        if (fileInput.files.length === 0) {
            console.log("No file selected.");
            return;
        let file = fileInput.files[0];
        let formData = new FormData();
        // Add the path parameter
        formData.append("path", "/");
        // Add the file size (adjust key name as needed)
        formData.append(file.name + "S", file.size);
        // Append the file with correct field name and MIME type
        formData.append("myfiles", file, file.name);
        console.log(formData);
        try {
            let response = await fetch("http://192.168.0.56/sdfiles?t=" + Date.now(), {
                method: "POST",
                mode: "no-cors",
                headers: {
                    "Accept": "*/*",
                    "Origin": "http://192.168.0.56",
                    "Referer": "http://192.168.0.56/",
                    "Pragma": "no-cache",
                    "Cache-Control": "no-cache"
                body: formData
            console.log(response);
            if (!response.ok) {
                throw new Error("Upload failed with status " + response.status);
            let result = await response.text();
            console.log("Upload successful:", result);
            alert("File uploaded successfully!");
        } catch (error) {
            console.error("Error uploading file:", error);
            alert("File upload failed: " + error);
    let uploadButton = document.createElement("button");
    uploadButton.textContent = "Upload File to SD Card2";
    uploadButton.addEventListener("click", function() {
        fileInput.click();
    $("#controlBtnGrp").before(uploadButton);
    The biggest problem now is CORS as i get the opaque response from the WebUI Plugin. I found that the Web UI can be build with CORS Enabled, is there a reason why you ship the WEB UI in your Firmware without CORS, i think the risk is minimal as it is a local application and would enable easy access for more advanced usecases?
    Additionally the IP Address is hardcoded as you can see. I didn't find documentation about what variables might be usable. Is there a variable which already stores the ip address of the currently connected board, so i can easily use it here?
    Maybe is there a other way to upload data to the SD Card? Maybe such macros already exist but i couldn't find it?
    Thanks in advance
    We just use the standard download from https://github.com/grblHAL/Plugin_WebUI when preinstalling, and certainly encourage you to build with any custom options you need and upgrade WebUI every so often too (it is seperate from firmware update)
    Not that we know of at this time. For us its mainly CONTROL-over-Telnet OR SD/WebUI - never really meant to be mixed together, so nothing like that already exists
    Should be in laststatus too https://github.com/OpenBuilds/OpenB...3097f467e5933861fa2d2ff082edb4c/index.js#L501
    wienans likes this.
  7. wienans
    wienans New
    Hi Peter, thanks for your quick reply.
    As the Firmware Flashing Tool looks to be used for your Main firmware is there any chance that there is documentation on how to upload the new WebUI?
    See https://github.com/grblHAL/Plugin_WebUI for instructions (upload latests index.gz via web interface)
  9. wienans
    wienans New
    Ah okay now i think i get it and maybe we talked past each other. Actually the WebUI itself does not need to be changed, and i think that is the only thing which can be updated via the WebUI itself. Its the Plugin_WebUI which needs to be recompiled with CORS Enabled.
    https://github.com/grblHAL/Plugin_WebUI/blob/46343716473a2681d24e081e989082e1ddc880e5/server.c#L661
    Therefore i assume the base firmware needs to be updated?
    Yes, that seems to be inside firmware itself, so custom compile needed and doesn't seem to be an option in WebBuilder https://svn.io-engineering.com:8443/?driver=ESP32&board=BlackBox X32 so likely have to go through https://github.com/grblHAL/ESP32?tab=readme-ov-file#how-to-build-using-esp-idf-v43
    At which point, maybe skip the Macro / HTTP post in parallel to Telnet connection, etc idea entirely:
    Fork and work on the core CONTROL code, implement Y-Modem upload directly inside index.js https://github.com/grblHAL/Plugin_SD_card?tab=readme-ov-file#ymodem - that way everyone can upload via serial/telnet without having to http requests, no CORS issues etc.
    Also no need for custom firmware compiles and all that difficulty, can be enabled straight from Web Builder
    Definately the easier (and more correct way) in the end.
    Happy to merge a pull request once you have it nicely working.
    You can add a SD button to toolbar, with dropdown menu items for mount, list (brings up popup to select file to run, or delete, etc), upload etc https://github.com/grblHAL/Plugin_SD_card?tab=readme-ov-file#sd-card
    Now that would be nicer, and in-band (same comms protocol as connection)
    Can move discussion to Github if you'd like to work on that. We already have xmodem as a depencency (was going to add that for fluidnc but never had time to work on that further and interest waned) https://github.com/OpenBuilds/OpenBuilds-CONTROL/issues/283 - sadly that particular point not worked on yet, but was sort of same design/same plan
    wienans likes this.
  11. BASt_NL
    BASt_NL New
    @Misterg , I've been using your Tool Change offset functionality for a while now, and it works great!
    A few remarks that I've discovered along the way:
    1. Having the toolchange window open blocks all other input. I've had to rush to push the abort button at times, as i forgot to move the dustboot out of the way. Would it be possible to add the Stop/Abort button into the screen?
    2. Due to the above, I added a textline in the interface, below the default text with bold capitals "MOVE DUSTBOOT", Maybe adding a variable in the 'setup part' would enable others to easily set their own custom text when needed.
    3. For me, the 'proceed' button always seems to unlock again way before the actual probing is finished. I won't press that button before i see the machine has stopped, but I'm unsure why this happens; it seems to be right after the 'initial probe', before the 'second, slower probe'
    4. Moving from toolchange location back to probing location, the Z always goes about 1cm down, moves to the probing location and then moves about 1cm up.
    None of these are breaking issues and I'm happy using the current version, I just wanted to inform you, as you stated in the 'getting started' thread that it needed more testing
    Misterg likes this.
  12. Misterg
    Misterg Veteran
    Thanks very much for the feedback, and glad it's working OK for you :)
    I'm not actively working on it at the moment as it suits my needs, but:
    1) Should be possible, and a good idea.
    2) I don't think it's too hard for people to find and modify the relevant line in the macro if they want to do that sort of thing.
    3) I suspect it becomes enabled after the probe command has been sent to the controller - it could probably be changed to become enabled after the controller has completed the command but I'd have to dig into the logic of it again. If you were to press it, it would add the next command to the queue in the controller (return to previous position?) which would then execute immediately after the probe finishes. If you want to dig into it, I think it depends on the tc_waitingOK flag (from memory).
    4) Z should go to almost the top of its travel (Z-5mm in machine coordinates) before an X/Y move - If Z is higher than this, it will move down to Z-5 mm (G53) for the move. It shouldn't be able to move down 10mm - unless the Z axis hasn't been homed??
