Mill expansion components
Discussion in 'CNC Mills/Routers' started by Gewehr, Feb 28, 2025.
  1. Gewehr
    Gewehr New
    I still haven't finished assembling my mill. But i would like to widen the x axis to the same as the y axis before building any further as well as push the router out a couple inches further. I would like to know if it is possible to order an expansion kit capable of this.
    I am also interested in a good bolt on vice if you have them.
    I am mostly going to use this for wood, carbon fiber and plastic handgun grips, aluminum, plastic and carbon fiber gun parts, aluminum, wood and carbon fiber knife handle components and very rarely steel gun slides. So something that works for this.
    Also, do you by any chance sell a wrench kit?
  3. Gewehr
    Gewehr New
    Ok. Anything else mentioned above?
    If you let us know
    We can offer more advise on the other questions. Right now we have no idea what machine you have, so can't tell you what you need to extend it :)
  5. Gewehr
    Gewehr New
    Oh. Sorry. The mini mill.
    Thanks!
    OK so with the Minimill, it gets trickier - expansion could be a problem. Because its not a gantry style machine, you can't just extend extrusions (like swopping a 250mm X-axis for the next size up 500mm). It could start to lose rigidity and could become too flimsy to work correctly. (carriage won't be under work to support the cutting loads anymore). You could add a slighly larger (custom cut) like a 300mm or so maybe.
    There are a couple example builds here you can use as inspiration:
    - Beefed up Minimill
    - Big-X Minimill
    - Minimill with slight modifications and v-slot table
    We don't supply any, but you can use your MiniMill to make a or MakerSL MSL-8 OB Vise or you can go with MakerSL style vice - using just off-the-shelf-parts (NB UNTESTED WIP)
  7. Gewehr
    Gewehr New
    I see. Ok. 50mm PROBABLY won't make a difference right now. If it does, do you sell the components?
    Yes!, all our machines are made from components in our modular parts catalog.
    Longer piece of C-Beam, longer leadscrew - rest you can reuse (Leadscrew should be at least 40mm longer than whatever extrusion length you go for)
    C-Beam Linear Rail
    8mm Metric Lead Screw
    If you need custom cuts, speak to Support > new ticket
  9. Gewehr
    Gewehr New
    Awesome!
  10. Gewehr
    Gewehr New
    Looks like i am stuck buying a router from you anyway. Been trying to avoid it (for $ reasons) but i think i definitively lost that fight this morning. Oh well. Will get the wrenches at least.
  11. Gewehr
    Gewehr New
    Sorry. To be clear, I wasn't being critical of your rour router. The opposite actually. I just didn't want to have to buy one at all but the one i have is going to take way more time and resource to build an adapter for than it's worth. If i have to buy one, i am getting what makes the most sense to me which is yours.
  12. Gewehr
    Gewehr New
    I will do that, but it may have to wait till later this year or next. Got a big project going on and spending every cent on it. Yesterday's order was prrtty much the limit for now.
    BTW. I am impressed with how fast you get stuff in the mail.
  13. Gewehr
    Gewehr New
    I just finished putting it together. But the video tutorials mention something about an LED light ring thing. I didn't see it in my electronics package and i am guessing it's not a mandatory part of the build?
    It is not. You can order one from Router/Spindle LED Light Ring
  15. Gewehr
    Gewehr New
    Cool. I might grab one soon. Do you folks offer a water jet add on or know of one thatbwill fit it?
  16. Gewehr
    Gewehr New
    In any case, here it is. As i said. The body is a knockoff i got for Christmas. The rest is stuff i ordered myself from you folks.
    I have to make some knife guards and hilts soon. So if i can install and use the basic functions of a CAD program well enough, i may try it out on them in the near future.
  17. Gewehr
    Gewehr New
    Well, i am having a terrible time with software. I expected the software to be the hard part but not half this bad.
    The tutorials all point to software that i could not find on your website at all. It appears all the tutorials arr outdated as they point to programs that are not there and the ones that are work completely different.
    Do far i can't even get the computer and the black box to even talk to one and other. I am at a loss. No clue how to get anything to work. And like i said, none of the tutorials are helpful at all. They all lead to very quick dead ends.
  18. David the swarfer
    top of this screen 'software' leads to OpenBuilds Software: OpenBuilds CONTROL and OpenBuilds CAM - FREE software to run your CNC, Laser, Plasma or Pen Plotter
    top of this screen 'documentation' leads to documentation for all the products. choose the correct Blackbox, X32 if you bought it recently.
    in CONTROL run the calibration wizard
    use the toubleshooter to check that limit switches work correctly.
    then make sure that all 'tool movement' is in the correct direction and set directions of axes correctly (remember you have moving table so 'too right' for X+ is 'table going left')
    then attempt to home and adjust homing directions as needed.
    on youtube, go to the openbuilds channel and watch the video 'hello world tutorial'
  19. Peter Van Der Walt
    Skipped section 4 of the BlackBox Docs by any chance? (Driver install): docs:blackbox-x32:install-drivers [OpenBuilds Documentation] otherwise comprehensive USB Connection FAQ on docs:blackbox-x32:faq-usb-connection-failed [OpenBuilds Documentation]
    Just plain software dot openbuilds dot com will get you there, but also see the entire Software section of the documentation:
    docs is at docs dot openbuilds dot com
  20. Gewehr
    Gewehr New
    Half of what you are saying sounds like a foreign language. You are talking to someone who has never once even looked at CAD software before yesterday.
    Anyway, what little i can understand that you said, i already tried or couldn't find.
    I already have open builds control installed and the CAM option only brought me to a webpage with what looks to me like a bunch of alien tech language and no software to download that i am aware of.
    Also, i have checked all software options and never once saw anything called Blackbox x32. Anything called blackbox would have grabbed my undivided attention but i don't see anything.
  21. Gewehr
    Gewehr New
    Screenshots. Everything clickable that isn't in the troubleshooting options and isn't a web link is shown.
  22. Gewehr
    Gewehr New
    Well, i tried a bunch of random stuff and eventually got to this.
    I have no idea at this point what it's asking me fore, why, why it needs my wifi password and all this other stuff. I copied a bunch of files to my computer but they are not doing anything and nothing else is working.
    Also, not a single thing i did today appeared in any of the tutorials or documentation i've been able to find on my own. If it weren't for this message board, there is no cnance at all that i would have made it this far. And still nothing has happened.
    It seems like everything here assumes that the user is an advanced computer engineer.
  23. Gewehr
    Gewehr New
    I got it working somehow. But there's a new problem. The motors wont budge. I can hear them being engaged but it sounds
  24. Gewehr
    Gewehr New
    Like there is too much tension on the system.
  25. Peter Van Der Walt
    That computer very old? Screen so small 1/4 of the right side UI is cut off, might want to use a little better PC to ease the learning curve (being able to see the whole application will help) - can zoom with ctrl+[+] and ctrl+[-] but just off the bat, seems like an oldy, etc just trying to avoid issues
    Learning curve is fun, just don't get discouraged or negative - work your way through you'll get it in no time docs:software:overview [OpenBuilds Documentation] explains the basics
    BlackBox is the CONTROLLER (the black box you wired to your machine there) not software
    CAM is web based, CONTROL is installed software. Many other applications same (like Fusion/Vectric is installable, but KIRI is web based CAM etc)
    No idea either, none of the standard getting started documentation/videos asks for Wifi setup, so you went somewhere of course there
    Not at all. Its about as simple as following the docs and videos provided
    Did you remember to load the Minimill profile as shown in the Minimill wiring and software video? (Basically just CONTROL > Connect > Grbl Settings tab > Tell us what machine and add-ons you have > Save and reset when prompted)
    Or if the mechanicals aren't sound (should be nice and solid but not bound up) then perhaps something in the mechanical build went wrong too, check all axes are able to move
  26. Gewehr
    Gewehr New
    It's what i have and i am not in a position to get anogher and probably won't be for a while. I got the computer brand new 3 years ago. After your latest video was published. What is UI?
    Most of that just confused me even further.
    All the mrchanicals can be moved pretty easily by hand. But there is some tension. What should the tension be like?
    This topic wouldn't exist if that were true. Most of this wasn't mentioned at all in any of the docs and videos i've found on it. In fact, they very quickly lead to dead ends. It appears everything has changed since the videos were punlished and whay little documentation i've found prior to this discussion largely matched the video. Most apps just install and run. This thing sends you all over the place and assumes you already know half the steps.
    You might as well be talking to me in a foreign language. I followed the instructions in the video for about 2 minutes until it pointed me to apps and the like on the website that no longer exist.
  27. Gewehr
    Gewehr New
    I have the minimill or rather a copy of it someone gave me for Christmas. From you i ordered the electronics package and the router. That and some tools for assembly.
  28. Gewehr
    Gewehr New
    The motors came with the Christmas package. So i am wondering if they might be defective. But i want to make sure that's the problem before ordering replacements. It's not really about replacing them. It seems to be within my budget and i would rather know for sure what i have. Rather making sure something else isn't the real problem.
  29. Gewehr
    Gewehr New
    Actually, is there a way that i can order just the screw shaft, knob and it's tightening screws for one of the horizontal tracks when i order some replacement motors (which i am going to do either way). I think this would be awesome to be able to be used manually if need be. And it already has everything but the vertical function.
  30. Peter Van Der Walt
    Depends, check their electrical specs, and make sure correctly wired docs:blackbox-x32:faq-identify-motor-coils [OpenBuilds Documentation]
    You did remember to load a Machine Profile in CONTROL > Grbl Settings right?
    All parts are on the store, hit the store's search or menu structure :)
    But note: never spin leadscrews connected to motors by hand. Motors spun backward = generator = backfed voltage to controller = dead controller
