OpenBuilds CONTROL Software
  1. NLucier
    NLucier New
    Literally turned on my Surface, it updated, and coords not changing. OpenBuilds machine from 2016 that I haven't touched settings, or even the troubleshooting tab at all since getting a Black Box and using CONTROL several years ago.
    At the suggestion of the only article that turned up in Search for 1.0.377, I did the following. Turned off Black Box, disconnected USB, powered off entire table, relaunched CONTROL. No change. I did notice that I couldn't find how to look at settings that I remembered from years past, and while doing that noticed Dark Mode was a thing. Clicked that and now the Grbl Settings tab is there. This was also someone's issue in that short thread.
    Before touching any of the things under the Diagnostics, currently ALL items, except Show GPU Information, say Disable in front of them. Do those change to Enable when you click one to go revert? Guessing I'm finding out as I think it is DRO that I'm looking for. Clicked that, CONTROL looks to have reloaded and now the coords all say Disabled instead of 0.000. The selection in Diagnostics put a check next to it, so answered that question.
    Went back into Diagnostics, clicked DRO line again, CONTROL reloaded, displays went back to 0.000 and they do not update when jogging.
    My $$ list from the console
    Code:
    [09:42:25] [ update ] You are already running OpenBuilds CONTROL 1.0.377
    [09:42:29] [ $J=G91G21Y2.54F10000 ] ok
    [09:42:30] [ $J=G91G21Y2.54F10000 ] ok
    [09:42:30] [ $J=G91G21X2.54F10000 ] ok
    [09:42:31] [ $J=G91G21X2.54F10000 ] ok
    [09:43:53] [ $$ ] $0=10 ;Step pulse time, microseconds
    [09:43:53] [ $$ ] $1=255 ;Step idle delay, milliseconds
    [09:43:53] [ $$ ] $2=0 ;Step pulse invert, mask
    [09:43:53] [ $$ ] $3=1 ;Step direction invert, mask
    [09:43:53] [ $$ ] $4=1 ;Invert step enable pin, boolean
    [09:43:53] [ $$ ] $5=0 ;Invert limit pins, boolean/mask
    [09:43:53] [ $$ ] $6=0 ;Invert probe pin, boolean
    [09:43:53] [ $$ ] $10=1 ;Status report options, mask
    [09:43:53] [ $$ ] $11=0.020 ;Junction deviation, millimeters
    [09:43:53] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [09:43:53] [ $$ ] $13=0 ;Report in inches, boolean
    [09:43:53] [ $$ ] $20=0 ;Soft limits enable, boolean
    [09:43:53] [ $$ ] $21=0 ;Hard limits enable, boolean
    [09:43:53] [ $$ ] $22=0 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    [09:43:53] [ $$ ] $23=3 ;Homing direction invert, mask
    [09:43:53] [ $$ ] $24=100.000 ;Homing locate feed rate, mm/min
    [09:43:53] [ $$ ] $25=1000.000 ;Homing search seek rate, mm/min
    [09:43:53] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
    [09:43:53] [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters
    [09:43:53] [ $$ ] $30=24000 ;Maximum spindle speed, RPM
    [09:43:53] [ $$ ] $31=0 ;Minimum spindle speed, RPM
    [09:43:53] [ $$ ] $32=0 ;Laser-mode enable, boolean
    [09:43:53] [ $$ ] $100=26.667 ;X-axis steps per millimeter
    [09:43:53] [ $$ ] $101=26.667 ;Y-axis steps per millimeter
    [09:43:53] [ $$ ] $102=200.000 ;Z-axis steps per millimeter
    [09:43:53] [ $$ ] $110=10000.000 ;X-axis maximum rate, mm/min
    [09:43:53] [ $$ ] $111=10000.000 ;Y-axis maximum rate, mm/min
    [09:43:53] [ $$ ] $112=2500.000 ;Z-axis maximum rate, mm/min
    [09:43:54] [ $$ ] $120=50.000 ;X-axis acceleration, mm/sec^2
    [09:43:54] [ $$ ] $121=50.000 ;Y-axis acceleration, mm/sec^2
    [09:43:54] [ $$ ] $122=50.000 ;Z-axis acceleration, mm/sec^2
    [09:43:54] [ $$ ] $130=1320.000 ;X-axis maximum travel, millimeters
    [09:43:54] [ $$ ] $131=1275.000 ;Y-axis maximum travel, millimeters
    [09:43:54] [ $$ ] $132=68.000 ;Z-axis maximum travel, millimeters
    [09:43:54] [ $$ ] ok
    I did a cut yesterday, which ran fine, it is just really unnerving to not be able to see the coords and such while the machine is moving. Just realized the 3D view is not moving either which I didn't notice yesterday, but will now.
    Thats quite old, sure you have a Grbl 1.1f or later based controller?
  3. NLucier
    NLucier New
    Grbl 1.1g It is a Black Box bought in Nov 2020.
  4. kaoscreations
    hi, I see on the installed Controll that it tells me that there is version 1.0.381 but on the site I see 1.0.376. what am I doing wrong? Thank you
    Nothing. 1.0.376 is "current" - newer development versions in pipeline for eventual release once nicely tested etc. Its not "out" yet, its in internal testing, etc.
    Changelog for upcoming versions is public info because lots of parties are interested, waiting for, or curious about whats going to be in the next release, or things like "has their reported bug been looked at" etc, that sort of thing, ahead of the release. We don't release for every little change (but every little change does have a version number bump internally), too many people complained about the regular updates.
    If there is an update actually available, you'll get a notification and it will start update as always
    Alain JBT and kaoscreations like this.
  6. CAK
    CAK New
    Hello, I'm using OpenBuildsControl on Ubuntu 22.04 and cannot get it to flash firmware to a ESP-Wroom-32. Once I start a flash, I cannot abort it to try to get back to try to connect again on the main screen. "flashing, please wait.." is shown in the port list. I've tried to use the Abort button under Troubleshooting but that doesn't seem to help. I am putting the ESP into Download mode by holding the BOOT button down while pressing the RST button, wait a second then release the BOOT button per the ESP instructions.
    How do I go about further troubleshooting this issue? I've tried v1.0.385, 386 and currently using 388.
    Thanks for any help you can provide.
    -Carey
    Try a windows PC. And consider a Blackbox X32 instead of the bare ESP (to entitle you to tech support)
  8. Odell Langston
    Pocket 1OPENBUILDSOSU_1-Pocket 1INCHES_1-Pocket 1.GCODE Can someone please check this file for errors, keep getting errors. I've completed this file before on genmitsu 3030, having issues with my 4030 with the extention kit. I'm new to cnc, any help or suggestions would be appreciated
    What controller is on the machine? (OpenBuilds BlackBox?)
    What software are you using (For CAM and for Host?)
  10. David the swarfer
    runs fine in check mode.
    what are the exact errors you are seeing?
  11. Mohamma393
    Hi
    How to disable auto start CONTROL when turn my old laptop on every time
    Just bought mini PC and touchscreen to use it only with only CONTROL and working good to run my cnc, so this feature will be great but control doesn’t turn on automatically need to activate it
  12. GasperStef
    Hello,
    I didn't understand if you want to enable or disable the auto-start of software when the PC boots.
    But I will post both options.
    For Autostart, on Windows is much strait forward and not so hard.
    Autostart
    For disable
    Disable
    But I also have a question. I have a complete electric cabinet for CNC. I am running OpenBuilds Control on Raspberry Pi 4.
    When I boot my RPi, the software starts automatically, but I need to ask if there is an option to have the software open fullscreen.
    Now it opens as a window. I am searching in .js but I don't want to destroy something.
    I know that this is not something which we cannot live with but nevertheless.
    Thanks.
    #2712 GasperStef, Mar 15, 2025
    Mohamma393 likes this.
  13. Matt McG
    Matt McG New
    Is there a way to get your max travel using (2) xtension limit switches / axis?
    I know I can just move the machine until it triggers each switch and calculate the distance between but was more asking if there's a way to accomplish this without triggering the switch alarms and also account for switch pull-off distance.
    Negative. But just home, setzero, then jog to just short of the other switch and read the values off the DRO
    Matt McG likes this.
  15. BASt_NL
    BASt_NL New
    I'm trying to use a simple external keyboard for machine control.
    Defining any regular key works flawless, but i don't want to get mixed up with keys on my normal keyboard.
    Defining keys in the F13 - F24 gets caught correctly by Openbuilds control when i'm pressing the key to set it as a shortcut, and it shows correctly in the keyboard shortcuts.
    But none of those keys actually activate during runtime. neither for the normal shortcuts, nor for the macro shortcuts.
    F13 upwards is kinda odd, since most standard keyboards has F1-12. Might be why electron is unable to map those.
  17. BASt_NL
    BASt_NL New
    so the keyboard/shortcut wizard isnt electron then?
    (because they do get mapped; they just dont trigger when im using them)
    I am just guessing, based on seeing something outside the norm. If you really cannot use more standard keys, open a ticket on github and the dev team can look into it in a couple weeks for you
  19. BASt_NL
    BASt_NL New
    I'll test with sending modifiers <alt>+ 1, 2, 3, etc.
    I'll probably wont use that normally during machine time.
    If that doesnt work for me, I'll dive a bit into if it is an Electron issue before submitting either there or here.
  20. dawhite
    dawhite New
    Seems installing 64bit os on the pi resolved the issue. only took me a year to figure out...
