Why am I cutting air?
Discussion in 'CNC Mills/Routers' started by galtjunk, Apr 16, 2025.
  1. galtjunk
    galtjunk New
    Blackbox 32
    Openbuilds control
    R7
    Vectric aspire for gcode
    I home the machine and set xyz to zero.
    I probe with the open builds probe.
    When I run the gcode it raises the z and executes the program but the z is way too high.
    This same code was working when I used it a month ago.
    I am working with a 3/4 piece of mdf.
    T1
    G17
    G20
    G90
    G0Z0.8000
    G0X0.0000Y0.0000
    S16000M3
    G0X3.9330Y10.0384Z0.2000
    G1Z0.0000F15.0
    G1X3.7850Y10.0007Z-0.0134
    G1X3.7513Y9.9920Z-0.0164
    G1X3.7176Y9.9829Z-0.0195
    G1X3.6840Y9.9736Z-0.0225
    G1X3.6505Y9.9640Z-0.0256
    G1X3.6171Y9.9541Z-0.0286
  2. David the swarfer
    obviously the probe did not set Z zero at the surface of the material.
    which exact probe option did you use?
    if you click 'gotoZero' does it go to the correct 0,0,0 position on the material?
  3. galtjunk
    galtjunk New
    goto work zero sends it to the correct position on the material.
    running the code causes it to lift the z axis and start cutting air.
  4. Alex Chambers
    As @David the swarfer said plus, if you are setting XYZ zero immediately after homing that is not necessary. Homing sets your machine coordinates system and probing will set the workplace coordinate system zero.
    Probing correct then
    Can you hear Z suffering, stalling, grinding or anything during Z moves?
    Anything loose or binding?
    Z-Axes acceleration/max rate tuned for reliability?
    Newly set up machine - or old setup with new issues?
  6. galtjunk
    galtjunk New
    no issues with z moves.
    This is an old working setup.
    Any recent changes, like installing a new controller, new version of a CAM application, anything at all?
    Grbl Settings backup for review? (CONTROL > Grbl settings tab > Backup Settings button on main toolbar)
  8. Giarc
    Did you buy chance tell vectric you were zeroing on the Bed and not the top of the work piece?
  9. galtjunk
    galtjunk New
    No hardware or software changes.
    Working zero is going to the front, left with the z touching the top of the work piece.
  10. Christian James
    Christian James Journeyman
    Yes indeed Craig. If it's set to "zero" off the bed but probed off the material surface, then you will get the exact problem that the OP describes. He hasn't actually stated that he's checked that setting in Vectric so who knows.
  11. galtjunk
    galtjunk New
    vectric was zeroed on the bed.
    I don't know how that happened. I never choose the bed.
    It works now.
    Thank you.
    David the swarfer and Giarc like this.
