New Blackbox can't connect to port
Discussion in 'General Talk' started by Finlandstation, May 8, 2025.
  1. Finlandstation
    I've got a Blackbox controller X32 that came with a Ratrig Stronghold Pro. When I try to connect via USB Serial port (com 3) it repeatedly returns this message.
    [16:55:44] [ connect ] ERROR!: No Response from Controller - See docs:blackbox-x32:faq-usb-connection-failed [OpenBuilds Documentation] for troubleshooting information. Closing port COM3
    There is nothing connected to the controller except the power and the computer. I've gone through the troubleshooting guidance and nada, zip, nothing.
    anyone got any ideas?
  2. David the swarfer
    is the BB actually plugged into COM3?
    check the device manager listing
  3. Finlandstation
    Yes, I think so. In device manager -USB Serial Port (Com 3) Properties confirms device is working properly
  4. David the swarfer
    check the usb cable, make sure it isnot a 'charge phone only' cable which do not transmit data
