Jogging controller? Alternative?
Discussion in 'General Talk' started by Scott Dre, May 17, 2025.
  1. Scott Dre
    Scott Dre New
    Hey all, I do use an old Microsoft Surface hooked up to my OpenBuilds Lead 1010 for using the control software for to control the CNC and also use it for transferring files to my CNC easily from Microsoft OneDrive. This way I can modify the files on my actual PC, then go out to the garage, and all my post-process files are synced up to the cloud and automatically ready to go in the garage.
    My question is - I see people on YouTube using X-Box controllers and such for controlling the jogging portion of the CNC. Can i use something different, or is anyone else using something different for controlling the jogging? I have the small touch screen that I purchased with the CNC, but when it's active, my Surface doesn't control it anymore.
    Thanks for any input! Appreciate it.
    -Scott D
  2. David the swarfer
    I use a cheap xbox type controller with bCNC, with qjoypad software (Linux) that maps joystick movements to key presses, then i assign shortcut keys to function in bCNC.
    There is probably a similar solution for Windows, the key being to make the game controller present keypresses to the control software, and map those keypresses to what you need.
    AntimicroX https://github.com/AntiMicroX/antimicrox/
    Map joystick buttons to keyboard buttons then map those buttons in CONTROL > Wizards and Tools > Customize Keyboard Shortcuts
    David the swarfer and Rick 2.0 like this.
  4. Soultie
    Soultie New
    I created a little jogger out of wood, buttons, LEDs, and a raspberry pi pico. I can give you the code for the pico if you want. Its nothing fancy but it works.
    You can get a look at it in all its crappy glory in this post Catastrophe! Loose gantry, not sure what to do...
  5. Soultie
    Soultie New
    EDIT: its that little wooden box thingy in front of the machine. It can home the machine, set/goto x/y/z, jog, incre,emtal jog, change incremental values, start/pause/abort jobs. Its kinda cool
  6. jakev383
    jakev383 New
    I'd be interested in the Pico code if you're sharing - I have not put my 1515 together yet (came in just before we left for vacation) but that seems like it may be handier than a spare tablet laying around. Thanks!
