Help with getting Fusion 360 part to generate a code for OPEN BUILDS CONTROL
Discussion in 'CAM' started by Rileyf02, May 22, 2025.
  1. Rileyf02
    Rileyf02 New
  3. Rileyf02
    Rileyf02 New
    Your main error relates to the version (old frequently asked question from folks that forget to stay up to date yes)
    The WCS thing is not an error just a warning, its a good habit to set the WCS otherwise it will default to G54 which is fine too
    See post #4 in Post Process - Fusion360
  5. Rileyf02
    Rileyf02 New
    How can I check what version to downlaod for a post processor
  6. Alex Chambers
  8. Rileyf02
    Rileyf02 New
    Thanks a lot for the help! I got it to work now just a little roughy when it starts to cut parts. The torch will come down and touch material then drag it across the material to the start cut position
    Did you read through the Plasma readme (in that same repository)
  10. David the swarfer
    DO read the plasma instructions! (in item 3 in the image Peter posted !!!!!!!!)
