Precision interface
Discussion in 'Suggestions' started by Melik, Mar 3, 2025.
  1. Melik
    Melik New
    I'll give it a try this weekend. Thanks again!
  2. Melik
    Melik New
    Kept failing
  4. Melik
    Melik New
    I definitely didn't enter bootloader mode. I followed the instructions from the post with the file. How do I enter bootloader mode?
  5. Melik
    Melik New
    These are the steps i followed
    CONTROL > Firmware flashing tool > Interface TAB along the top > Firmware Version > Select Custom: firmware binary file > Red "use custom firmware image" button appears, click to open a file browser, where you can select the BIN file you extracted above > FLASH
  6. Melik
    Melik New
    I tried all three ports. They at least all are recognized
  7. Melik
    Melik New
    Ok I got it flashed. But it doesn't work. If you change it to decimals from percentage it just keeps going
    Thanks for the feedback, as mentioned
