ooznest OX CNC Machine
Discussion in 'CNC Mills/Routers' started by Ryan Lock, Apr 28, 2015.
  1. Ryan Lock
    Ryan Lock Veteran
    Ryan Lock published a new build:
  2. Mark Carew
    @Ryan Lock You my friend have outdone yourself on this build! It turned out absolutely excellent. The PDF assembly is top notch as well, thank you for sharing!
    Mark
  3. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Excellent design Ryan. :thumbsup:
    Tweakie.
  4. Ryan Lock
    Ryan Lock Veteran
    Thanks for your comments, much appreciated!
  5. Marcel Caraballo
    Super great manual, thanks for sharing this! Cheers
  6. MikieLikesIt
    Hi out there. Does anyone have a spare set of plates for the OX cnc. I'm located in Ontario Canada.
  7. GrayUK
    Really really good job! :thumbsup::thumbsup::thumbsup:
    Gray
  8. Ryan Lock
    Ryan Lock Veteran
    Hi, we have just started selling them on our website, we do ship to canada.
    Thanks!
  9. DazTheGas
    DazTheGas Journeyman
    Love the anodized black thing. (Plates Ordered)
    DazTheGas
  10. Lee Whiteley
    This is an excellent build all around. There is nothing lacking in both the mechanical and the instructions and the files presented in this build.
    This build will be my guide after I finish my current build using 8020 extrusions. It's a 4'x5' cnc router. I'll be using this machine to make the plates for my built. I really like the idea of having a larger machine for those larger projects and a smaller machine for those smalled projects.
    Thanks for all you've done.
    Lee
  11. Ryan Lock
    Ryan Lock Veteran
    Thanks for the order!
    Thanks for the kind words. Hopefully you can post come pic's once you finish it.
  12. Robert Walker
    Looking at buying one of these kits in the next few days from ooznest, would it be possible to use 2060 spoiler supports to get an extra 20mm of depth on the Z axis?
    Regards
    Robert
    ChrisV likes this.
  13. Ryan Lock
    Ryan Lock Veteran
    Yes this shouldn't be a problem. Just a few things to be aware of.
    - You will need to have two spoiler board supports running down the right and left side.
    - To secure the spoiler board this will only be possible to the spoiler board supports, unless you use some L-Brackets at the font and back.
    - Every time you cut something which doesn't take advantage of the extra z height, the z-axis will have to extend down a further 20mm than needed. This will increase the length of the lever arm.
    The only modification needed to make this change, is to change the extrusion. The mounting hardware would be the same.
  14. Ryan Lock
    Ryan Lock Veteran
    A couple of pictures of what our completed OX looks like. Our OX uses a CNC xPRO (Thanks Mike!) and a brushless 400w spindle controlled by the xPro.
    We will be updating the build soon with a list of parts to complete the electronics, as well as stl's for all the mounts used.
    silopolis, GrayUK and Mark Carew like this.
  15. Jeferson SImoes
    Nice. Where do you get this spindle/power/controller?
  16. DazTheGas
    Looking good..
    DazTheGas
  17. Ryan Lock
    Ryan Lock Veteran
    If your in the UK, we use this one here: http://www.ebay.co.uk/itm/121634639622?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    It includes the spindle, psu, controller, and a mount. The holes on the mount don't really align with anything on the OX, nor any standard plates. We opted to use the openbuilds router mount with a 3d printed spacer.
    Thanks, the plates are due to arrive this week. So you should receive yours towards the end of the week.
    DazTheGas likes this.
  18. Jeferson SImoes
    Thanks Ryan.
    You can on/off and control the speed of the spindle with Grbl?
  19. Ryan Lock
    Ryan Lock Veteran
    Yup. Use M3 SX (Where X is your rpm). For the spindle above, full power would be M3 S12000.
  20. Tim P
    Tim P New
    Can I get the specs for the included steppers in your kit? More specifically, I need the current rating so I can order the correct resistors.
  21. Ryan Lock
    Ryan Lock Veteran
    No worries, attached is the data sheet for the motors used.
  22. DazTheGas
    Well after a pretty bad day with customers I got a special treat waiting for me at home, my ox plates from Ooznest had arrived over a week early. Absolute pure quality "Cheers Ryan".. Now about getting tomoro off to play with them!!!!
    DazTheGas
    crispin, GrayUK and Tim P like this.
  23. Tim P
    Tim P New
    I just put in an order for the full kit. Can't wait to start my first CNC. Still a ton of research to do and a few parts to order.
  24. Ryan Lock
    Ryan Lock Veteran
    Glad you are happy with the plates, you are the first to receive them :)
    Order received! Now we have the plates, we are going to do a marathon session this weekend and see if we can get all the pre-orders ready ship, i am hoping to get yours shipped by the end of next week.
    If you have any questions regarding other parts, let me know.
  25. kev20009
    kev20009 New
    Hi Ryan Starting Cutting Your Plates Today, But The Plates Missing Is The Motor Mounts, They Are Stp Files, Any Chance You Would Have Them In Dfx, And Can You Say Cutting Hight, As Im Doing The 1200x600,
    P.s The V Groove Was Nice And The Cuts, Thanks Ryan Kev, Look Out For More Orders From Me
  26. Ryan Lock
    Ryan Lock Veteran
    Nice! I have attached the dxf files for them two parts. Sorry i am not sure what you mean by the cutting height? do you mean the insets for the 688zz bearings?
  27. kev20009
    kev20009 New
    Sorry Ryan Should Have Said The z axes From Bit To Spoil Board, As Im Doing The 1200 Was Woudering If The Hight Would Be Enough, Thanks Again Kev
  28. Ryan Lock
    Ryan Lock Veteran
    With a 200mm z-axis extrusion, the max z travel is 69mm, so about 49mm with a spoiler board.
  29. kev20009
    kev20009 New
  30. Ryan Lock
    Ryan Lock Veteran
    The holes on the plate designs are exactly 5.00mm, we get them manufactured to 0.03mm tolerance, so there is some interference between the bolt and plate, but they still go through freely. If your making them yourself you may want to make the holes slightly bigger.
