M Cubed CNC Mill
Discussion in 'CNC Mills/Routers' started by M^3, Feb 15, 2015.
  1. M^3
    M^3 New
  2. sgspenceley
    sgspenceley Veteran
    Great build, I like how you made box sections.
  3. Outkastaluminum
  4. vonku
    vonku New
    just to show my avatar, aha
  5. MashX
    MashX New
    Could this machine be used to cut O1 tool steel?
  6. John Williams
    No way. Cutting tool steel. 8mm rods and nema 23. Small spindel. Be lucky to cut aluminium. I use a Deckel knee mill and it's a bear, even still, tool steel is a stretch with it. Time and patience. Better with a tormach or vmc.
  7. zaalexander
    Interesting build! Have you found it stable enough resting on the 20x80 alone? I can imagine doing something similar, but doubling up the Y-axis and spacing the extrusions just far apart enough for two carriages to clear. This would increase stability and rigidity in the X-Y plane without increasing the footprint too much. And increasing the power by dual-driving the Y might help with milling too. I'll be looking forward to seeing it mill aluminum!
    #7 zaalexander, Apr 24, 2015
  8. lolocaledo
    Witch software do you use with this CNC to mill aluminium piece ?
  9. Lliam
    Lliam New
    I have a design that's on hold for the moment, but is pretty much the same as your M Cubed. I had even been calling it that also.
    Nice work.
  10. Julius
    Julius Well-Known
    all your photo bucket images need to be reuploaded
