Tool position setting Part II.
Discussion in 'CNC Mills/Routers' started by Tweakie, Jan 28, 2014.
  1. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Tweakie published a new build:
    CutAboveZ and Robert Hummel like this.
  2. Mark Carew
    Very cool Tweakie! Keep'em coming these are great.
    Thanks for sharing
  3. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    Is there a way of programing a Spasific x-y location so that a touch plate can be mounted to the frame for a homing cycle ?
    I'll be updating my table top mill I made to improve it's cutting and think that something like this would help a lot.
    I ran short on extrusion so MDF was my only option at the time for a table/spoil board.
    This is a pic of it before the upgrade to 3/8 plate and a 1.5kw spindle.
    All of the first upgrades where cut on it, then transferred to the mill bit by bit :)
    And some of the update pics
  4. Tweakie
    Moderator
    Sure there is Robert. In the script, call the homing routine then specify the co-ordinates of the touch plate.
    In my applications I always set Z zero to the top surface of the work and as the work thickness can be different from one day to the next there is advantage in placing the touch plate on the surface of the work to obtain Z zero without any measurements being necessary.
    btw. very nice machine build you have there.
    Tweakie.
  5. Robert Hummel
    Moderator
    Ty :)
    Now that I think about it, I just may do as you and make a insulated weighted plate, I was mainly thinking about bit changing
  6. Steve123
    Steve123 New
    Thank you Tweakie for the excellent macro. I changed a few lines (SAE) and it works great. No longer do I have to use a eye ball guessing for Zeroing m Z axis.
  7. Tweakie
    Moderator
    Great stuff Steve, I am pleased it is of use to you. :)
    Tweakie.
  8. Robert Hummel
    Moderator
    Well here it is T, my very own diy touch plate.
    Thanks for the great build and idea
    1/4 " Buss bar from the scrap
    Milled minus 25% and lightly brush finished @800 grit
    Scrap 5.8mm acrylic
    Finished results ;)
    Just love turning junk into a useful item again :)
  9. Tweakie
    Moderator
    That is just way too cool Robert. Excellent work sir. :thumbsup:
    Tweakie.
  10. Mark Carew
    Work of art my friend! :thumbsup: Awesome job
    BTW In case you did not know this, in SketchUp you can add more sides to an arc or circle by right clicking on the edge > entity info and adding more line count in the segments.
  11. Robert Hummel
    Moderator
    Ty bud!
    I'm having issues with the output of code with the new plug in update.
    Half way through cutting my code
    "Center line tool only so far" the machine goes nutz pulls some random moves and continues on like nothing happened ?
    I'm not sure what's happening but I have gone through a lot of matireals :(
  12. Mark Carew
    I will send you a PM Robert. Sorry to hear of the bugs
  13. David the swarfer
    please post the sketchup file and the gcode you generated.
  14. Robert Hummel
    Moderator
    I will post ASAP
    Just a build I'm keeping on the down low for now so I don't want to post the files here.
    Pm me an e-mail I can send them to
  15. GrandpawB
    GrandpawB Well-Known
  16. Tweakie
    Moderator
    @GrandpawB What video's are you referring to ?
    Tweakie.
  17. GrandpawB
    I'm sorry. The tool positioning videos. Under "Builds" there's video 2 and video 3 but no video 1.
  18. Tweakie
    Moderator
  19. GrandpawB
  20. GrandpawB
    Perhaps they're just mislabeled.
  21. Indieflow
    Indieflow Journeyman
    @Tweakie In the your main article you mention:
    Any chance you could upload a picture or some more information?
    I'm looking to add a fixed tool setter system to my new build like the below picture though first want to see what else you use ;)
  22. Tweakie
    Moderator
    Time marches on, no sooner had I completed most of the documentation for the construction of my low profile tool setter, I was approached (totally out of the blue) by a commercial concern who were interested in buying the design. The negotiations took some time but I finally sold the design outright so I am no longer able to disclose any details of this item. Sorry.
    Tweakie.
  23. Indieflow
    Not a problem at all, the picture tells me everything I needed to know ;)
  24. AK-Creation
    AK-Creation Well-Known
    Do you need more picture about a Referenzsensor?
  25. Indieflow
    I don't now! :thumbsup:
