Sea-OX
Discussion in 'CNC Mills/Routers' started by Steven Bloom, May 29, 2015.
  1. Steven Bloom
    Steven Bloom Journeyman
  2. Mark Carew
  3. Steven Bloom
    Well tonight I designed and printed a prototype of my first part. The part is a "Y End Plate". You will need 4 of these for the printer. I will post the .STL file for now. I used Solidworks for the first time, its not too bad.
  4. Steven Bloom
    Okay, I have now proven that my Endplate will now work. I have printed out a bunch of pieces with my 3D printer and have assembled them. I now that I will also need two double corner brackets , one three hole plate and one corner connector bracket. Let me know if everyone things this will be sturdy enough for the corners.
    2015-05-30 16.26.55.jpg 2015-05-31 14.37.12.jpg 2015-05-31 14.37.28.jpg 2015-05-31 14.38.51.jpg 2015-05-31 14.39.13.jpg 2015-05-31 14.40.21.jpg
  5. Joe Santarsiero
    Joe Santarsiero OB addict
    That's crazy. I love it. Being a designer and having to color code everthing to help convey intent, I love the fact you printed everything in different colors. Great model Steve. I think you should build and work out any further kinks now.
    Steven Bloom likes this.
  6. Steven Bloom
    Here is my new faceplate design for the Sea-OX. I am going clean it up a little. But you can see where I am going. By the way, A Sea-Ox is another name for a male Manatee. They are very tough and can push through anything !!
  7. Ronald van Arkel
    There are easier ways to see if things fit with CAD programs, it's crazy indeed to print all but darn it looks cool! :thumbsup::ROFL:
  8. Steven Bloom
    What program would you recommend ??
    Thanks Steven
  9. Ronald van Arkel
    Just SketchUp Make 2015.
    I've been using different 3D programs over the last 22 years and I like SketchUp the best. Been using it since January this year. The only downside I´ve found is that you need to make some objects at a scale of 10:1 else SketchUp will crap out on you: for example making a Acme rod, you must draw it as 80mm as 8mm will give you errors with extrusions and the follow me tool. Some plugins might be needed to complement your SketchUp install, like drawhelix14, ene_uprightExtruder_v1.2.1 and a few more. DXF/DWG import and Boolean function are only part of the Pro version, that's the downside of the free SketchUp. I don't use the render functions as I only care for functional design. Lining up parts might be the biggest task you will face.
    For 2D I still use an older AutoCAD version ;).
    -Ronald
  10. Steven Bloom
    So tonight was a good night and I did some more design work. Here is a completed "Sea-Ox" 3D Printed plate. I will getting two of these in stainless steel. My Nema-23 motors also came in. They are capable of 24KG/CM. They should be good and strong. I also designed this part to act as a corner brace. Maybe I can get someone to sell them at their site.
    Joe Santarsiero and Mark Carew like this.
  11. sw3Dp
    sw3Dp New
    Manatee I love it, looking foreword to seeing it swim.
  12. Steven Bloom
    Well I had some time again to design the "Y Inside Plate". I don't know if I have everything on the plate but I will revisit it again tomorrow night. This plate should allow a "X" C-beam to mount to it and have the normal C-Beam End posts tie into it.
    Enclosed is a picture and the STL file as of now.
    • yyy2.STL
      File size:
      186.8 KB
      231
    silopolis likes this.
  13. Steven Bloom
    Here is the "Y Outside Plate". I also added a picture of how the two pices would kind of line up as well. Also, the STL file is included.
  14. dddman
    dddman Journeyman
    I suggest that you may extend it to be near your X beam to prevent stuff to get on your wheel or add holes to be able to add a brush (hard to find)
  15. Steven Bloom
    Not sure what you saying by extent it near X Beam. Enclosed is a new picture. I was hoping that with this design there would be a minimum amount of dust near the wheels.
  16. dddman
    dddman Journeyman
    OK I understand now :) I taught that the bog plates would have been on the outside like the OX
  17. Steven Bloom
    I am now getting closer. Tonight I will start on the plates that will travel across the X axis and hold the Z. This part will be tough for me.
    JacquesBotha likes this.
  18. Ronald van Arkel
    The 20*40mm V-Slot at the back, move it as far to the edge of the back of the side plates, put the 90º corners to the front of it; this helps a bit with sturdiness. Another tip: use 2 Acme blocks on each axis, put them apart as far as possible and put them in a distance of steps of 8 mm, hart to hart. This will reduce vibration and slack. Looking good!
    -Ronald
  19. Steven Bloom
    More Changes . Moved the V-Slot back and now can use two acme blocks per side.
  20. Steven Bloom
    I am done with work for the night but I got a chance to work on the X/Z Plates. It is starting to come together.
  21. dddman
    dddman Journeyman
    You'll gain some X travel if you put the big Y plates on the outside of the C-Beams, but as I said earlier, you'll have to modify a little bit your inside plates to protect your wheels/belt.
  22. Steven Bloom
    Actually the X is 500mm. It will still travel the same distance either way. The only way to make the trave longer is to decrease the size of the gantry that is holding the spindle or increase the X beam
  23. dddman
    dddman Journeyman
    True, you'll just optimize the footprint the other way.
  24. Steven Bloom
    Almost done designing the last part of the Z Axis. But I have a question ??? What is the normal amount of room betwwn the top of a wood board and the cutter. I think I can cut something up to 40mm thick.
    Is that enough room ?? I have no idea what the standard is .
    Thanks Steven
  25. Joe Santarsiero
    I think that depends on what you cut and what precision you expect. closer to the gantry means better precision. The further out you hang that thing in a cut the more torque that's translated to the gantry and the more doc plays a part. The other problem to consider is that bits and drills come in different lengths. So, you have to factor that in as well. 40mm is good, but do you need that much of a gap? on that note, You can throw in more or less spoil board for adjustment.
    #25 Joe Santarsiero, Jun 6, 2015
  26. Steven Bloom
    Ok, I now am pretty much done drawing. I might have to make the Y Plates a little higher. I don't know because I need to see home much clearance I really have. Now I need to buy some stuff.
  27. Steven Bloom
    Ok, did a little more cleaning up. Enclosed is a new pic and a complete zip file of the OpenSCAD rendering and all the associated .STL Files. Some of the .STL files are my design and some are .STL files that are Openbuilds.
    Thanks Steven
  28. Steven Bloom
    I did not have any designing to do today but incase you want to see the Sea-Ox in action, just watch the movie !!!!
  29. Steven Bloom
    Just created my first 3 plates for the X/Z axis on my 3D printer for test purposes. They came out nice.
  30. Slobberknocker
    Are you using the 8mm lead screws. I love your design and will start building it soon. This will be my second build as I am wanting an all aluminium machine. I'm a little worried that anything less than 12mm lead screws may promote whipping under a heavy load. Thoughts?
