OX AI
Discussion in 'CNC Mills/Routers' started by Robert Hummel, Feb 3, 2014.
  1. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    Robert Hummel published a new build:
    Pawlenko M likes this.
  2. Franco Ponticelli
    Super good!
    Any chance they will be put for sale somewhere?
    chris sluggies likes this.
  3. Robert Hummel
    Moderator
    As soon as I'm happy that they work and are of good enough quality, "I'm picky lol" I will offer the plates.
    I think the main thing will be the shipping but will see what the final weight is :)
    chris sluggies and Mark Carew like this.
  4. Franco Ponticelli
    Keep us (me) posted ;)
    chris sluggies and Robert Hummel like this.
  5. bobt
    bobt Well-Known
    Robert - I appears from your pictures that the files are on Sketchup. Can you make your files available so the rest of us can piggy back on your fantastic work.
    Bob
  6. Robert Hummel
    Moderator
    Absolutely!
    kram242 has given the go ahead and I will post the sketchup and nc files.
    I use no tabs so take caution when milling.
    I will post them as soon as they are assembled and tested for fit, as I did have to do some work converting things to work on my mill from Marks original files.
    chris sluggies, Pawlenko M and Dave M like this.
  7. Dave M
    Dave M New
    You have a nice CNC with a water cooled spindle, Do you think the OX can be that good, cutting Alum ? Can't wait to see more on your build. Keep up the good work. Inspiring.
    chris sluggies and Pawlenko M like this.
  8. Mopar32985
    Mopar32985 Well-Known
    Wow man looks great so far cant wait to ge a CNC up and running
  9. Greenman
    Greenman New
    Very cool- please keep us posted with the build progress.
  10. Robert Hummel
    Moderator
    I got my hands on a copy of the model file as you see pictured in his build and pulled it apart by editing the components.
    I was asked to keep it on the low as I'm sure you can understand.
    Kram242 has given the go and I'm sure his files will be posted soon
  11. Mark Carew
  12. Robert Hummel
    Moderator
    After some test fits of the hardware I have found that the holes are machined so close to spec in relation to the diameter of the screws and eccentric spacers that about .01 needs to be added to my files.
    I will make the adjustments and mill a second set of plates "sorry spoken for" :)
    If the new set works I will post the gcode and scetchup files.
    With the release of my build I have had a ton of requests for production.
    I have talked to the openbuilds staff and they are cool with me helping along with your builds
    You must all know I'm a father of a 3 and 6 year old and have a very demanding job as an emergency generator technician.
    As most of you, this is simply my hobby and love it.
    I will get the plates to where I'm happy with them and then begin to offer them for fellow members.
    Pricing is being worked out as I have many factors to consider.
    Not here to make money rather help but can't work free.
    My mill is no where near perfect but I would say it does the job ;)
    #12 Robert Hummel, Feb 4, 2014
  13. Robert Hummel
    Moderator
    All holes are now adjusted and I will mill another set in the AM :sleepy:
  14. Robert Hummel
    Moderator
    Milling went as planned :D
    I will upload my sketchup files ASAP
    Please note again I mill with no tabs so you may want to add some in the drawing before generating your g-code
    Milling of plate sets will be done while I work on this build :cool:
  15. Mark Carew
    Glad to hear it went well Robert
    Multitasking at its best!
    Robert Hummel likes this.
  16. Robert Hummel
    Moderator
    Plate files are up :D
  17. Mark Carew
    Wow the plates look AWESOME!!! and so do the spacer blocks! I love the look of the milled aluminum.
    Great job Robert thanks for posting the new pics for us to drool over :p
  18. Robert Hummel
    Moderator
    More to come ;)
  19. Derwin Palacpac
    Thanks for sharing! i see the files, are there other files available with the dimensions and measurements, also what is the thickness of the aluminum pieces, that way i can order longer bolts for the v wheels, etc.
  20. Robert Hummel
    Moderator
    The aluminum is 1/4"
    24x24 sheet should do
    If you would like dimensions look to Kram242's OX build files as that is where I got my info for the plates, I just added my own touches and adjusted the hole sizing for my liking :)
    dean3 likes this.
  21. Derwin Palacpac
    right on! i shall pull up Kram242's files...:D:D:D:D
  22. Daryl
    Daryl New
    Could you please upload *.stl files for the plates?
  23. Mark Carew
    Robert the acrylic spacers are super cool looking bro!
  24. Robert Hummel
    Moderator
    Ty bud ;)
    Thought it would look sweet with the AI plates, deff happy with the outcome :D
    It's coming along real nice, I designed them to be cut from 1/2" HDPE so it would multi task as a motor spacer, couple sheild and vibration isolator ;)
  25. Robert Hummel
    Moderator
    I can see what I can do, I'm sure it's just a matter of converting them some how
  26. Derwin Palacpac
    Hmmm I'm wondering if I'm doing the correct thing.. I've downloaded sketchup and added the phlatboyz plugins, opened the plates in sketchup toggled the generate gcode, BAM! The file gets saved in a folder. Opened up the grbl controller 3.5, opened one of the plate files and WOW the code is there.. I have all 4 plates as cnc files. Only thing is.... Lol I have no cnc machine to mill my plates!!! This is my first build.. Trying to find all the hardware, piece together all the software, trying to see if I can finish this puzzle!!! Doing this all by reading this forums, THANKS GUYS..
    dean3 and Mark Carew like this.
  27. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Excellent progress Derwin, you'r going to be an expert on all this long before your machine is even built. :)
    Tweakie.
  28. Mark Carew
    Great to hear that your able to follow the workflow and get the plates coded! :thumbsup: Like Tweakie say you are already ahead of the game with learning the software side of things.
  29. Robert Hummel
    Moderator
    Sounds about right :)
    We all start somewhere and learning the software first is smart, it would suck to have a cnc but not be able to make anything
    mike125 and Mark Carew like this.
  30. Mark Carew
    Wow that carbon fiber wrap looks fantastic!
