plasma cnc
Discussion in 'Other Builds' started by cureac, Nov 26, 2014.
  1. cureac
    cureac New
  2. Steve B
    Steve B Well-Known
    I'm starting to put together a BOM for an OX Plasma as well. Look forward to tracking your design, please post updates as you go. I plan on tweaking the standard OX design to accomplish the following:
    - 2 x 2 cutting area
    - portable, plan on placing the machine onto the material to be cut
    - mill compatible - be able to switch between milling and plasma
    - THC
    Have you thought about your electronics at all? Anything out there that includes THC or DTHC is really expensive.
  3. cureac
    cureac New
    today I bought 4 axis driver LV8727T4V1 and a power supply S-350-24 ( input 100-120v or 200-220 v depending on country output +24v 15A)
  4. Psychosaffa
    looking good. what plasma cutter are you using?
  5. cureac
    cureac New
    I have not bought plasma cutter
  6. Mark Carew
    This is a great looking build so far @cureac looking forward to seeing this one in action. Thank you for sharing
  7. Jeferson SImoes
    @cureac what can you tell about the LV8727T4V1?
  8. cureac
    cureac New
    The driver is Chinese made. It's only working with mach 3, not compatible with emc2. The driver are 4 axis. 24 v, working well with nema 23, 250 Oz,4a.
  9. Bob Andres
    Hi new to the forum. I am a fabricator welder delving into the unknown world of building a plasma cnc.
    I bought a Chinese controller board USB6560 12V which also has on board drivers for 4 axis system. Just got the board and software it came with working today.
    I'm going to be using a Hypertherm plasma cutter. This is probably one of the best machines in the business.
    Dont worry about your welding it looks fine as long as the penetration is good no worries.
