Hi all, here we are with the (likely) final version of the control board! With a cool new feature: the ability (OPTIONAL OFCOURSE) to faking the Z axis for triggering the limit switch, for when you have only 2 axis and you still want performing the Homing cycle
Hi oni305, where can I get one of the boards or *.BRD file to start my own laser project? Regards Ronald
Hi Right now I'm testing the new design! The base board works fine but I have yet to try the laser driver I have some unpopulated boards, if you are interested (both old or new)
Hi oni305 I see your Raster 2 Laser GCode generator at github now works with the latest Inkscape 0.91 which is excellent as it automatically maintains the correct size of the original artwork. I have however got a slight problem when making PCB boards on my laser machine, because of the small amount of backlash inherent on all machines I end up with a small amount of overlap of the laser when it goes one way and then the opposite way. This causes a real problem when making narrow PCB tracks it ends up becoming sort of a zig-zag track. Do you have any suggestions how it may be possible to only turn on the laser when it goes in one direction. I think that would overcome the problem. Cheers Alfred
hmm, you can try the version V5 of the extension : http://www.openbuilds.com/attachments/raster2laser_v5-rar.2033/
Hi goodjob oni305...i hope it does PCB etching ...any possible to use only schematic for laser driver setup using on rampps board or cnc shieldv3 because dont need those steppers(from your board) in this case more thinking for expansion my own boards just editing the code and voila should be working wants to build meself or buying jtechphotonics.com only laser driver solution but exceeds my budget in shipping and customs say about almost in total 250 dollars... absurd I just read you still have pcb boards how many$ where from? possible to use drv8825 steppers?
Looks good I hope to be able to use one of these on a future project, with regards to the homing cycle that's a good idea if you don't wish to edit the grbl config.h to remove z from the homing cycle. Ben
Yes I can sell some PBC 1) OLD (no pwm, laser driver integrated) 9€ (10$) 2) NEW (pwm capable) without laser driver 9€ (10$) 3) NEW (pwm capable) + Laser driver board 13€ (15$) + Shipment 13€ (15$)
Anybody please help me. I got a problem like this I tried to install on 3 computer but it didn't work. This is an error code : Traceback (most recent call last): File "raster2laser_gcode.py", line 531, in <module> _main() File "raster2laser_gcode.py", line 526, in _main e.affect() File "C:\Program Files\Inkscape\share\extensions\inkex.py", line 268, in affect self.effect() File "raster2laser_gcode.py", line 126, in effect self.PNGtoGcode(pos_file_png_exported,pos_file_png_BW,pos_file_gcode) File "raster2laser_gcode.py", line 170, in PNGtoGcode reader = png.Reader(pos_file_png_exported)#File PNG generato File "C:\Program Files\Inkscape\share\extensions\png.py", line 1376, in __init__ self.file = open(kw["filename"], "rb") IOError: [Errno 2] No such file or directory: 'C:\\Khac\\nam_0001.png'
Hi oni305, thank you for your Inkscape extension "Raster 2 Laser GCode generater". It is very good to engrave jeans clothing. Designer Jeans with a Laser | OpenBuilds
Hey, you are still working on it and also with laser driver PWM, nice May you remember you send me some pcb's of the first version to germany, now im very interested in your updates, would you like to send me the shematics? Did you needed to modify GRBL for the new driver?
Hi, Yeah, I remember you The board works fine? For GRBL it depends, if you want the PWM you have to upload the correct version. (even compiling with the arduino ide is pretty simple) (I've sent you a PM)
Thank you so much! Well, i did so many diffrent things, that i never finished the boards. But i've been getting all parts needed and still willing to do so. About the GRBL you use for PWM, you switched the arduino pins 12 and 11, which is pin 15 and 16 on the ATmega chip and used the stock GRBL with spindle PWM right? Im actually planning to integrate this also in Marlin, as i did with a PID closed loop AC Spindle controll allready. Maybe i can manage to have a gcode supported way of controlling the laser PWM from Marlin in a better way too. But yeah, i really need to finish this soon. Will get back with some results here as I'm able to finish this. Keep up your awesome work.
