How to Setup & Configure An OX CNC Controlled by a TinyG V8
A Step by Step Video Series on how to get your OX CNC up and Running With a TinyG V8
  1. Akfreak
    Akfreak New
    Akfreak submitted a new resource:
    How to Setup & Configure An OX CNC Controlled by a TinyG V8 - A Step by Step Video Series on how to get your OX CNC up and Running With a TinyG V8
  2. ElRowlando
    Thanks so much for this. I've been struggling to get my machine set up with Tinyg. I was wondering if you may be able to help me out with something however.
    When I set up my machine I had used the motors from the store here, then decided to upgrade to a 480 oz stepper in hopes of solving some issues I was having. After doing that I updated the FW on the tinyg and updated the json server. After getting everything set up again, I noticed that when the machine was moving between cuts it was moving at a rate of 2 ipm. Before I updated I never had this issue. In an attempt to fix the issue I changed some settings and now my machine tries to fly when jogging and when starting a job, about 1000 ipm and when it does that it binds up. It is still moving at 2 ipm between cuts. I have a video of what it is doing when I say "Binding up" but don't know how to upload it. Basically if I try to tell it to move more than 4-5 inches it'll move the initial 5 inches then bind up and stop.
    Other issues are settings not saving to the board correctly and things of that nature. I'm running the latest FW and have a very similar setup as you. Even when I changed the max velocity to 10 ipm it still gave me the issue.
    Again, thanks for the great resource! Also if you would like I can upload a video of what mine is doing.
    Thanks!
  3. greenyone
    greenyone New
    I'm a know nothing who is interested in getting into this as a hobby. These videos give me the confidence to make the machine but the part that confuses me is the actual drawing of objects. Not being familiar with CAD, I decided I'd grab a cad drawing (.dwg) that I found on the web and converted it to .svg. I loaded it into jscut to play around, but I get nowhere real fast. Can someone point me in the right direction on tutorials or information on how to properly set up a .svg for jscut?
  4. leversole
    leversole New
    Trying to look at a "standard" or "normal" TinyG config for an ox type machine...the pastebin link in the video says the page was removed...can someone post it for me, or post your own tinyG parameter dump?
  5. Robert Bailey
    Robert Bailey Well-Known
    think this was my last one, of course there are new FW revisions out there I am a little behind. don't fix what isn't broke
  6. leversole
    leversole New
  7. Anthony Spadavecchia
    hello first off thank you for all of the step by step help in wiring and setting up the board and power supplies. the issue that I am having is downloading the JSON server. I went to my computer settings and can see that the USB is plugged into COM3 but I am unable to download and go further, can someone help a newbie? PLEASE?
  8. biggestb35
    Hey Akfreak,
    All I can say is WOW.. great job.. very informative in every aspect.. I'm fairly new at this but I wish I had all this information before starting my build.... I began to build my OX cnc 2 years ago.. and it took me a year to get all the parts before finishing the build.. It took a while but I was able to do it ( i purchased a few pieces a month, have kids and mortgage, sorry ).. I follow all of Mark Carew tutorials, I got all the same hardware and used the same software he uses. My only concern is that I've been struggling to get a right cut... Meaning when I do a simple circle, I never really get a perfect circle specially if I do it in more than 2 passes.. Its never consistent.. I try to calibrate the machine but I can only do it on one direction. If I fixed the X direction positive the X negative its off. Same with the Y.. Again. I don't know if this is a hardware issue or software...
    Anyways, What I'm trying to say its that you are correct about not getting enough info on the Software side of building the OX... I wish someone can do what you did for the gShield, I feel i'm the only one having this issue since I don't see anyone mention this..
    Thanks guy... sorry to vent..
    Thank you again Akfreak
  9. George Allen
    Thanks for the configuration info. I have had to figure out some things for my self. I see you configured your CNC like I had to when I noticed that the chilipeppr logo was backwards. I had to enter the X axis polarity as reversed. Glad I figured that out, I was about to pull the gantry off the table and turn it around!! One question:
    When I read the directions to the ox build it says the x-axis extrusion was only 200mm. When I saw that the lead screw I received from open builds was much longer, I decided to go to a little longer extrusion, but the rod still sticks out the bottom and occasionally hits the platform. What lengths are you Z-axis threaded rod and z-axis extrusion? Is your Z-axis only 200 mm?
  10. Matthew Goulet
    Can you post the settings from video 3 that you were revising. So i can do a side by side and compair for my tingG.
