C-Beam™ Machine - Plate Maker
  1. Flash22
    Flash22 Well-Known
    What amp/voltage psu are you running ? what spec are the steppers ?
  2. arc1979
    arc1979 New
    Stargeezer, you are correct. The right side is opposite from the left. That is how it was shown in the C machine video.
    Flash22, I am using an OpenBuilds 24 volt power supply and Open builds Nema 23 steppers.
    I will try swapping to the 4th axis tonight and seeing if it works. Ill also research flashing the firmware.
    Thanks again for the suggestions!
  3. arc1979
    arc1979 New
    Ok. New information. I took all of the connections loose and reattached everything making sure all connections were nice and snug. Now the Y moves less than 1/2" and then quits, thats it, no more. Still makes the single click sound after moving but with no movement after the initial movement. Seems like there is no logic behind the amount of movement. Sometimes it moves 1/2" then stops, sometimes less than a few mm.
  4. arc1979
    arc1979 New
    UPDATE. ITS THE BOARD! I moved my Y motor to the X connection and the X motor to the Y connection. Y motor works, X motor now does not... So, now to order another board and wait.
  5. motopreserve
    motopreserve Well-Known
    Glad you got it sorted out. Hopefully they replace the board quick.
    arc1979 likes this.
  6. stargeezer
    stargeezer Journeyman
    For a machine as simple as these are, when they don't work right it can seem like you are chase your tail. I'm sorry it's the board, but happy you got it sorted out. I hope the gods of shipping are on your side. And on the bright side, you now know almost every way there is to solve this kind of mystery. Learning never ends.
    arc1979 likes this.
  7. R_B
    R_B New
    Is anyone else having problems with GrblPanel ?
    Mine will connect to the xPRO, read and modify settings, jog the motors, etc.
    What it will NOT do is to load a file for me to run, i.e. the file menu contains only an "Exit" item.
    I had tried the GrblPanel.application, that seems to go out onto the web looking for files and eventually tells me that the application could not be installed.
    So I am running the GrblPanel.exe directly.
    I suspect that the GrblPanel.application is what goes out and gets the menu items - just GUESSING here.
  8. Flash22
    Flash22 Well-Known
    try the universalGcodeSender java app, I've had no issues at all with it, I'm just getting to grips with fusion360 what is free to the hobbyist
    Serge E. likes this.
  9. R_B
    R_B New
    Thanks flash22, but I had trouble with that too.
    Despite java updates and removal of obsolete jre.
    ...and I thought the HARDWARE side of this was going to be tough, the software (for ME) shoulda been a breeze.
    I ain't a "mechanical guy", spent a LOT of technical years in the compooooter biz though.
  10. Flash22
    Flash22 Well-Known
    I have had 2 versions of the code sender 1 worked the other didn't, the one in the software download didn't work for me
    The one on GitHub does tho, direct download http://bit.ly/1BSKon6
  11. Mauricio Solid
    IMG_20150830_202107.jpg IMG_20150806_124808.jpg View attachment 10803
    You can use Bosh like the pictures, Dewalt and Porter Cable even Makita you only need to check the spindle diameter for the OB router mount, It's an awesome machine :)
    Ps. Double check if the router or spindle have speed control or variable speed, and use good quality router bits that's also very important not only the spindle IMG_20150905_120812.jpg
    #281 Mauricio Solid, Sep 5, 2015
  12. R_B
    R_B New
    @Flash22;
    That version does work here, the version from the C_Beam files area did NOT.
    Thanks - now for a little "air milling", then maybe buy a router and get going on some foam Yoda heads or ,,,who knows ?
    Oh yes, plates, I will HAVE TO make some plates for something.
  13. charliex
    charliex New
    So the flex Y gantry plate finally got to me and i redid it. I grabbed a linear rail i had lying around that was an ebay scratch, and chopped it in half luckily where the scratch was on the bearing race, so that part threw away, then i mounted the derlin nut to the back of my tool plate and attached the linear rail trucks on either side of the plate.
    i do have to cut out some channels for the rear Y bearing plate to clear the tool plate.
    remarkably the linear rail+trucks were exactly the right height, so lucked out there. now it's pretty much rock solid.
    #283 charliex, Sep 6, 2015
    Fety Mann likes this.
  14. R_B
    R_B New
    About Universal G-Code Sender;
    I think Mark made a comment in the video that it doesn't have a preview of the path that the tool will follow, I could be wrong about this.
    Anyway, there is a "Visualize" button and the view that comes up seems OK, it also updates as the file runs and the machine cuts.
    You can see both where the router is routing and where the buffer is leading (at least it SEEMS that the higher intensity bright line ahead of the tool probably represents what is in the buffer).
    I am starting to like this and right now I don't see a reason to use anything else - although I would like to get Estlcam running and of course the grbl-panel to load and run files.
    I'm still just "air milling" to check out the tools, so any problems of accuracy and precision have yet to reveal themselves (-:
  15. stargeezer
    Hey Charlie. Are your pics super sized? I'm just getting a big blank square. Of course this might be win 10 issues to since I just upgraded this cpu.
    Larry
  16. Flash22
    Flash22 Well-Known
    openscam is brilliant for simulating .cnc files
    Its been a steep learning curve but I got my first 2 cuts done yesterday - next up is a multi pass cut in some alloy
  17. charliex
    charliex New
    hmm maybe ? , i linked them straight off the googles (cropped them a bit). they're on my HAD project log too which automatically resizes them a lot smaller and you can click them to expand etc, https://hackaday.io/project/6921-openbuilds-c-beam-machine-build/log/24737-adding-linear-rails
    i'm waiting for Service Pack 1 to come out for win10 ;)
  18. Flash22
    Flash22 Well-Known
    There dead on your blog, looks like there set to private ??
  19. charliex
    charliex New
    strange, google+ must have changed policy. i've been linking them link that for a while.
    ok fixed, guess i'll have to go back over all my posts n stuff and fix them. sigh punishment for using google+ i guess.
    thanks for pointing it out.
    #289 charliex, Sep 7, 2015
  20. arc1979
    arc1979 New
    Unfortunely, I have not heard from the open builds parts store yet. I submitted a ticket Friday.
  21. motopreserve
    Might be the backup due to the holiday. Maybe nudge them :)
  22. carbuthn
    carbuthn New
    Charliex, nice job on the new Y work plate. I just got some aluminum in today, do you think that it is better to use 1/2" or 3/8" plate?
  23. charliex
    charliex New
    thanks! 3/8" would be fine, i've been considering dropping the size down to get some more Z, same for the 1/2" MDF spoiler, my plan is to cheeseboard it and the tool plate and use that for work holding , carpet tape doesn't work that well on MDF i've found, at least the MDF i'm using it is too smooth. i was going to try 1/4".
    my other trucks should be here this week so i can do four corner holding instead of the middle. you can find nsk/thk useable linear rails for well under $100 on ebay.
    i'm considering chopping off tiny bit from the top of the Y C-Beam, or putting a slot in the tool plate for clearance, rather than spacers, i'm using about 0.025" - 0.05" spacer, so a slight extra gain on the Z if i don't use them.
  24. Flash22
    Flash22 Well-Known
    charliex
    I like that idea it should take out any flex in the build plate, I was toying with using 2 Y axis C beam actuator
  25. David Hall
    I just finished putting my C-beam machine together and followed the 2 hour youtube tutorial meticulously. When I went to run the 'hello world' foam test, I followed the instructions and dropped the router bit down until it barely touched the top of my foam. When the program started it hovered above the foam by a few millimeters. Any idea where that setting is located? Also, is there a good software tutorial for newbies? Im using grbl panel and open S-cam
  26. charliex
    charliex New
    added the other two trucks, using 075" precision spacer clears the Y C-Beam, but i still have to mill out a channel for the end plates.
  27. Joe Santarsiero
    Joe Santarsiero OB addict
    That one wins "Most festive C-Beam machine"
    What currency is that Makita?
  28. R_B
    R_B New
    I may lack some general workshop skills, or discipline, I am NOT much of a "mechanical guy".
    I haven't had much confidence that the general system of tee nuts and cast corners is good at pulling things together "tight and square" - lack of which will probably show at some point.
    Perhaps I'm over thinking this, or maybe some of you have a "feel" for just setting them in a tiny bit from the end of a section to make joints tighten up square automagically ?
    Today I came across this;
    {I like it}
    It may be proprietary, but it seems like an open source design could be developed that wouldn't infringe.
    #298 R_B, Sep 14, 2015
  29. Flash22
    Flash22 Well-Known
    what cast corners do you have some are flat others have locating tabs these are fine when lining 2 channels that run the same direction but if you have one running horizontal and the other is vertical one side will sit in the rail but the tabs will push the other rail way out of square
    the answer is to file 2 of the tabs off, to pull the parts/rails in tight use a clamp then do up the bolts
    are you in the UK or US ?
  30. Rick 2.0
    If you want to be able to draw up the connection, mount the cast corners to the intersecting piece first, setting them a fraction of a mm back from the end. This leaves a gap that will cinch the end of the intersecting member fully against main member.
    The problem with the system that you have shown is the small size of the V-slot makes that type of connection impractical. Due to the spring, at best you would only have a 3mm bolt through the intersection and a good chunk of that 3mm cross-section would be cut away for the locking bolt. As for whether someone could create an open source system of a similar nature, its already been done. Its called a cam-loc and while you could easily drill the cam-loc hole in the proper location, finding cam-locs in an M4 or M5 size may be a bit of a challenge.
