Question about a build I would like to post
Discussion in 'General Talk' started by David Arroyo, Jan 27, 2016.
  1. David Arroyo
    I will be putting together a raspberry pi, arduino and cnc shield controller. Aside from the motors the rest of the parts would be sourced elsewhere. Would you allow a build like that or does it have to be a build that uses more of the products you sell?
  2. Ronald van Arkel
    Hello David,
    There are a lot more builds posted that use a few to none component from OpenBuilds. We would love to see your project especially the electronica part as most won't talk about it :D.
    Welcome to the club ;),
    -Ronald
    Mark Carew and David Arroyo like this.
  3. David Arroyo
    Good to hear. Thank you for your reply. I just like this platform since I am able to document my every move which will help me and other recreate this.
  4. Mark Carew
    Welcome to OpenBuilds @David Arroyo !
    We absolutely welcome your Build here. The idea here is to share Open Source builds so that others have a blueprint of sorts to go by when building their own versions.
    In the OpenBuilds Part Store we try to make parts that will help Builders with their builds and its great when a build can support them, but all builds with or without them are welcomed!
    So again welcome we look forward to your Build!
    Thank you
    Mark C
    GrayUK and David Arroyo like this.
  5. David Arroyo
    Workin on it as we speak. Im not going to publish it till I make some very small progress. You will see it soon.
