OpenBuilds OX CNC Machine
  1. mihaib
    mihaib New
    Hello Flo. Can you give me details about shop were you find hf spindle? Thanks
  2. Florian Bauereisen
    Florian Bauereisen Well-Known
    actually you might buy just any of the chinese hf spindles on e-bay.
    I got mine from a company based in Germany for 2 reasons:
    I get a bill and warranty and secondly because you will need to (at least check) make sure about the elect. ground on the spindle.
    As i basically have very little experience with 220V i prefered to pay a bit more for the service - for beeing safe.
    Mine is from Sorotec in Germany, cost arpox 400 Euro but buy on e-bay direct in china youll end up around 250 Euro.
    A FU unit sets you back another say 100 Euro.
    greets
    flo
  3. Franco Ponticelli
    Hey guys, this thread became huge so I am sorry if my question has already received an answer before.
    Without changing the elements of the OX, do you believe it could sustain using 1000mm beams for x and y? How do you calculate the effective area given these dimensions?
  4. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    My Y axis on the OX AI is 1250mm
    X 900, all runs smooth by hand electronics are in the works
  5. Mark Carew
    @Yusuf Tumer I did a quick carve with a dremel 1/4 wide-1/8th shaft V bit I had laying around and it was not a problem it did great!
    Had a piece of dirty old cedar decking plank laying around (screwed it down to the spoiler board) and used ArtCam for the code
    Also did a more complicated carve and made a short video, enjoy :)
    #545 Mark Carew, Mar 26, 2014
    Chris Laidlaw, skarab, asb_79 and 2 others like this.
  6. Mopar32985
    Mopar32985 Well-Known
    Looks great mark I'm loving my machine. Got almost everything working the way I want it.
  7. Mark Carew
    Awesome bro glad to hear it, nothing like having a machine it dialed in. :thumbsup:
    Mopar32985 likes this.
  8. Yusuf Tumer
    @kram242 That's exactly what I was after. Thanks!
  9. Mark Carew
    More then welcome @Yusuf Tumer it was fun to try and now I want to make more with a better bit :)
  10. Yusuf Tumer
    Was the tear out in the photo's due to the quality of the bit or because you were running a 'roughing' speed/feed?
  11. Mark Carew
    It was really my first time trying this style an I think a combination of feed rate/dull burnt bit was causing the tear look. Once the bit did its other passes and as it reached the proper depth it cleaned all the tears out. I am confident that once we get this cutting technique dialed in it will come out look fantastic!
    Yusuf Tumer likes this.
  12. Yusuf Tumer
    Don't get me wrong. The finish in the video looked much better as the router did it's final passes. I was just curious as I don't have much experience in these things.
  13. Mark Carew
    As for V carving I am new as well :) After the milling I went back and lightly hit the surface with sand paper and it looked great.
    I would like to try and stain the wood first and then do the v carve and see how that turns out.
  14. Yusuf Tumer
    @kram242 Another thing you can try is paint/stain the surface a single colour, mask it, route the pattern using a down cut spiral tool, paint the routed bits a different colour and then peel the masking off. I've never tried it but I have seen in done in a few places on the internet :)
  15. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Nice work Mark - take care, you can get hooked on V-Carving :)
    Tweakie.
  16. Travis
    Travis New
    Hey guys, I'm new here just signed up, but I really would like to build the OX. My only question is inquriey on the OX Plates, are they going to be an option soon? I was just wondering because I want to order everything and was about to, but I dont want to order everything and be short one part. Thx for your time, hope to hear back soon on my options :)
  17. asb_79
    asb_79 Well-Known
    I can supply Waterjet cut Gantry plates and frame joiners. Check my thread in the forums.
    There are at least a couple of others supplying machined plates.
    Psychosaffa likes this.
  18. Robb
    Robb New
    I just ordered some a couple days ago from ASB_79. Look forward to getting them!
  19. Robb
    Robb New
    This is all new to me, I've built 3D printers, but not much of a woodworker in the past. What spindle would your recommend? I am planning on building a big Ox and will likely use CamBam as part of my toolchain. I'd like something that would be computer controlled on the spindle as I would be a little more comfortable. I did see the need for an emergency stop button and plan to put one in. Planning on having my teenage son and daughter help me with this.
  20. danstrider
    Hi all,
    Finished building enough to get a first cut out of my Ox this morning. Toolpathing had the little nibs in the corners, so those are on me and not the machine.
    I have 750mm y-axis rails, which gives about 20.5" of tool travel. The x-axis is 650mm, giving about 18.5" of tool travel. Z-axis travel is around 3" and limited effectively by the height of the large plates and the distance between the spoilboard and the bottom of the z-axis.
    My one squawk is how the z-axis wheels tighten onto the z-axis rail. I'm not sure if it was my drilling of the hole locations or the distance between them on the drawing, but they need to be about a half mm closer together. This leads to some y-direction flex at the tip of the tool when loaded up. There is also a little torsional rotation in the pair of x-axis rails that I can see; maybe pinning these together will help.
    A few of the first projects will be making a real router mount, cutting all the plates (by machine this time rather than center-punching and drill pressing), and some form of dust collection.
    Thanks for the original Ox drawings and the detailed parts list. I bought stuff before folks had the plates available and before Openbuilds got steppers, rod, etc, so the parts are a mash-up of different suppliers.
    Dan
    2014-03-29 09.09.54.jpg 2014-03-28 19.52.34.jpg 2014-03-20 21.44.47.jpg 2014-03-19 21.28.34.jpg
    Mark Carew and Robert Hummel like this.
  21. Tweakie
    Moderator
    Nice work Dan :thumbsup:
    Tweakie.
  22. Robert Hummel
    Moderator
    Great job!
    Look forward to your self upgrades :)
  23. Mark Carew
    Very nice build @danstrider way to go!:thumbsup: Love seeing another OX in the wild :)
    Thank you for posting your build pics I'm looking forward to your mods and I too agree with the stepper connections very nice and clean.
    Hope this machine brings you tons of enjoyment and inspires you to create great projects.
  24. Travis
    Travis New
    Thx asb, I appreciate the info, but i actually am having them made by a friend.
  25. Travis
    Travis New
    Also, just ordered all the parts for the OX build, I cant wait till all the parts come in and I can start making it :)
    Yusuf Tumer and Mark Carew like this.
  26. MartinTurner
    Hi Guys.
    Just managed to purchase all the OX parts from RoboCutters in the UK and i can't wait to get started on the build.
    Just got a few questions - Hope you don't mind...
    Does anyone know if a variable speed router spindle would be a good idea, if so can anyone recommend one?
    Where do you get your router bits from ?
    What would be the best type of bit for cutting balsa wood ?
    Martin
  27. dddman
    dddman Journeyman
    Would it be 40$ extra for Canada too? I can't imagine that it is the same price worldwide.
    Thank you!
  28. MartinTurner
    Thanks Justin...
    Just managed to pick up one of these today...Variable Speed Makita Router for £99 and 2 bits - a two mm and a 1/8 from Craft Pro (Trend). I think it should do the job. It has a chip extractor attachment - Hope I can use it.
    What sort of quality cut do you get with 1/8 inch balsa? Ribs any good ?
    By the way - How did you cut your VSlot?
    Cheers Mate
    Martin
  29. dddman
    dddman Journeyman
    I use a miter saw with a 40 teeth blade, nothing special. The first cut is a little scary but it's not worse than wood to cut (I suggest that you make your cut a little bit slower that you would for wood)
  30. Mark Carew
