Was just wondering if anyone could measure or has the measure of the total height of: C-Beam plus mounted universal Gantry Plate. I know the C-Beam is 40mm, and the Gantry Plate is 3mm, but was wondering how much height is added when mounted. Thanks for any assistance! Dean
Hello Dean, Just under 46mm (45.843mm ) according to @Mark Carew C-beam Sketchup model. But it really depends on what spacers you end up using for your wheels / nut block as to how high off of the C-beam the Plate will ride.
To do it by head and without the drawing: C-Beam till half the wheel: 30mm Half wheel height: 5.5mm Shim: 1mm Spacer: 6mm Gantry plate: 2.93mm Total: 45.43mm Screw head is about 1.55-1.60mm in height. So yes, 45.843 is close enough . -Ronald
