BAFP 3D Printer
Discussion in '3D printers' started by Steven Bloom, Nov 24, 2015.
  1. Mark Carew
    Wow! @Tim N this is an impressive build! I want one of these giants
  2. James Armstrong
    I have a really stupid question. I have been looking at this printer and is it really a CoreXY? The description says "A new Core XY printer" but from what I can tell you are using two motors for Y (one for each side) and a motor for X. That is just a standard setup, not CoreXY. Am I missing something?
  3. Steven Bloom
    Steven Bloom Journeyman
    It was the closest category that I could match to. Do you have a better suggestion ???
    Thanks Steven
  4. James Armstrong
    Not sure, it just through me off because I was interested in CoreXY printers (those are the type I like building). They only use two steppers to control X and Y at the same time, like H bot but better because of minimized backlash and racking.
  5. Steven Bloom
    we are using one motor on x and two on y because of its massive size. the two y motors work off 1 controller.
  6. Val Cocora
    Val Cocora Well-Known
    did you connect the y motors in series or parallel?
  7. Val Cocora
    also, can't wait to see the extruder mounted on it.
    edit:
    never mind that, i missed the extruder in the last pic. my bad.
    #97 Val Cocora, Apr 2, 2016
  8. Steven Bloom
    I think it would be considered parallel
  9. Val Cocora
    s
    i also connected mines in parallel. trying to connect them in series and frying a couple of m542t stepper drivers was the main reason.
  10. Tim N
    Tim N New
  11. Tim N
    Tim N New
    Printer is now 99% completed...
  12. Val Cocora
    i almost hate you for those awesome led lights.
    regarding the printed part, have the same delamination on my first successful print.
    nozzle was 0.35 mm, and filamwnt was pla 1.75 mm.
    temperature was 185 c.
    did you guys figure out why it happens?
  13. Steven Bloom
    Player should be printed around 210 c. 185c is causing your problem
  14. Steven Bloom
    Pla
  15. Val Cocora
    will try 210 c.
    thank you, sir.
  16. stargeezer
    stargeezer Journeyman
    Your filament feed may be too low as well. Try bumping it up a bit.
  17. Tim N
    Tim N New
    Any more pics of your giant printer? Also, what slicer are you using?
  18. Val Cocora
    thank you, will look into that.
  19. stargeezer
    Val, I should have asked first, but have you calibrated your extruder? If not there are lots of good youtube instructions that can walk you through the process. It's not hard, but more involved than I can describe here in a couple paragraphs.
  20. Val Cocora
    this here pic is taken after the printing of the delaminated part. one can see it under the extruder.
    ..and below is the second attempt, with 210 celsius temperature per steve's recommendations. part printed fine, it's just that i forgot to add support for an overhang. it printed it anyways..:)
    i use slic3r then load the saved gcode into pronterface
    #110 Val Cocora, May 31, 2016
  21. Val Cocora
    I did a sort of preliminary calibration of the axis except the extruder, but you are right, i should fine tune those numbers.
    regarding the extruder, it's a dual but one of the tits is not hooked up to the smoothieboard.
    my buddy is supposed to stop by one of these days and hook it up, then i can finally calibrate the whole unit.
  22. Val Cocora
    youtube link below:
  23. Val Cocora
    on a non technical note, she loves to sing, especially when doing circles.
  24. Tim N
    Tim N New
    2 new prints...
    Simple vase:
    First few layers have blobs since filament fan was turned off intentionally. Subsequent layers were fine...
    Also need to get rid of the Z-scars....
    Trying 2-color printing, ooze barrier was too close to the actual print that put artifacts on the object:
    After some clean up:
  25. Val Cocora
    steve and tim, are you using a heated bed?
    if so, what is the wattage of the heating pad, or element?
  26. Tim N
    Tim N New
    Hi Val,
    Yes, we are using a heated bed. It is 110V AC @ 1200W rating.
  27. Val Cocora
    replace the glass and heater with pir foam. add a bit of a raft to your part prior to printing.
    sink the extruder about 1 mm into the foam and print.
    you will forget there's such thing as warping.
  28. Val Cocora
    first thing first, credits go to the digital dentist for the tip:
    https://vimeo.com/66108108
    https://vimeo.com/66108107
    a few things about pir foam, or polyisocyanurate foam: one can usually buy it from building materials suppliers, comes in 4x8 sheets, sometimes 4x9. the usuall thicknesses are 1 inch and 1.5 inch. they come either foiled in paper (harder to peel off) or aluminum foil, easier to remove. price for a 4x8 sheet: around 20-25 bucks. bought mine from lowe's.
    i use 1 inch because i believe 1.5 to be a waste. the foam can be reused a few times, but since the majority of 3d printers are no bigger than 0.5x0.5 meters, one can cut many smaller sheets off a 4x8, so that's some of the best spent 20 bucks ever. besides, one can use the other foam face anytime.
    the foam can be used for pla, which is the material i used, but the digital dentist has successfully printed on abs. both materials stick to the foam like hell, as his video above shows. depending on the geometry of the printed part, you might wreck the foam while removing, but good thing a 4x8 sheet is plenty. also, leveling becomes kind of moot, seeing how the danger of the extruder hitting the printing surface is rendered null.
    regarding the printing itself: i tweaked the beginning code in slic3r to home x and y axes, then manually home z myself then, with the machine ready, i lower the extruder tip by no more than 2.5 mm into the foam and start printing. i use a 2 loop skirt to increase the contact surface of the printed part to the bed, but i recommend using a raft.
    try it, and experience the pleasure of not having to wait for the bed to heat up prior to printing.
    #118 Val Cocora, Jun 5, 2016
  29. Val Cocora
    for some reason beyond my limited knowledge, i cannot seem to convince the machine to accept an all axis homing gcode, followed by the lowering of the extruder a few mm into the foam.
  30. Val Cocora
    there was absolutely no warping on any of the parts i printed, big or small.
    print a larger part, you will understand why it won't warp when you remove it from the bed.
    i think i figured out the gcode part. it is very important how much one sinks the tip of the extruder into the foam.
