XPro V2 vs LinuxCNC plus something build from bits off ebay
Discussion in 'Controller Boards' started by Pops, Apr 29, 2016.
  1. Pops
    Pops New
    Hi All
    I have started the mechanical build of an Ooznest OX CNC and getting to the point where I need to commit to my choice for a controller. Ideally I'd like to go down the LinuxCNC route but I am struggling to work out what controller setup to go for. The simple option would probably be to go for an XPro V2 and UGS but I like a bit of a challenge. I would be interested in your views and opinions and experience on this.
    Ivan
  2. Joe Santarsiero
    Joe Santarsiero OB addict
    What's your budget? :D
  3. Pops
    Pops New
    That's a good question. All in with power supply and controller, 200 GBP. Thanks, Ivan
  4. snokid
    snokid Journeyman
  5. Joe Santarsiero
    We'll you're all set for a TinyG, xpro, or a shield. The question is how far do you want to go?:troll:
    Your only a few more pounds away from a G540, power supply, and motorcables. Download LinuxCNC and go. You need an lpt port interface though which could be an additional cost depending. Personally, even though I'm not a fan of the G540 I'd go that route in your shoes. Its much more capable than the above mentioned combination boards. It'll provide you with enough overhead for growth and the performance and support are proven just about to an absolute. It'll likely be the last thing to give you trouble and be there for you if decide to build bigger. Resale isn't bad either.
    Just my 2c
    Joe
  6. Pops
    Pops New
    Thanks for your advice. I look into those options. The UK reseller for the g540 charges 325 pounds for it. Has anyone in the UK bought direct from gecko. I may go down that route. Another g540 question. I would need the 4th access to mirror the Y. Is that configurable in linuxcnc or would I have to do some fancy wiring to make that work?
    Ivan
  7. Rick 2.0
    As for a source, you might check with Automation Technologies to see if they'll ship your direction. G540 with resistors / G540 without. (You should be able to find the resistors cheaper on your end.)
    Stelios Malakoudis likes this.
  8. Joe Santarsiero
    No fancy wiring. Slave it from the software.
  9. Pops
    Pops New
    Thanks everyone for your input. I ordered from the US a G540. Now to see if I can get my head round linuxcnc stepconf and how to slave the second y axis.
    Joe Santarsiero likes this.
