Upgrading the “old” C-Beam machine
Discussion in 'CNC Mills/Routers' started by Ronald van Arkel, May 24, 2016.
  1. Ronald van Arkel
    Ronald van Arkel published a new build:
    Paul Stoller and Tom Allen like this.
  2. Kyo
    Kyo Veteran
    Awesome, Those are the same mods to the Z-axis I am planning ( belt reduction and double wide plate. ) Looks like it came out great; we are running the same router to boot.. Can not wait to place my next order with the PS. :thumbsup: Thanks for sharing.
    Paul Stoller likes this.
  3. Moag
    Moag Veteran
    Now that's going to be one strong C-Beam Machine Ronald, liking the Y axis mod, very clever. :thumbsup: Top Job.
  4. Mark Carew
    Monster strong! Well done :thumbsup: Ronald
    Looking forward to seeing the first cut in action
    Thank you for sharing.
  5. Rick 2.0
    Nice work. Only suggestion I could offer would be inverting the screws on the Y-axis plates and turning them downward. This will make attachment of the build plate easier.
  6. Ronald van Arkel
    Hi guys,
    Thank you for your nice comments!
    @Rick 2.0, the build plate won't be put back. There will be a 1/2" aluminum plate for table, and I've to see if I'll use another layer of 1/8" acrylic sheet. I'm still green when it comes to cutting aluminum :oops:. The table will be perforated where the lock nuts are ;). To give you an idea of the height of the screws sticking out, it's just under 9mm (8.8). I've still to explain my Y axis setup later this week.
    -Ronald
  7. Jonathon Duerig
    Jonathon Duerig Journeyman
    This looks really great.
    I'm curious about one thing. The other day I was browsing the shop and saw the high torque motors and the reducing belt that you use for the Z-axis. I was wondering when I would want to use one vs. just using a coupler. You use the reducing belt for the z-axis and not for the other axes. Why is this? Is the extra torque of the reducing belt more useful on the Z-axis for plunge cuts? Does it slow down the x and y axes too much?
    In general, it is often hard to tell from the store front when I would want to pick one kind of thing over another. So any insight here would be of great use to me.
    -D
  8. Ronald van Arkel
    Hello @Jonathon Duerig,
    I've still have to play with cutting harder materials like non-ferrous metals (the soft ones that is ;)). But, what I've seen is that the Z-axis needs more holding torque than most of us would expect. It seems that, when plunging hard/steep, the Z axis bounced up, even pushing the stepper motor a few steps back. Adding more weight to the Z-axis will help but it can be done with the belt reduction as well; note this is not proven but I thought there would be some logic. I might put reductions on the other axis too, for now it's just to demonstrate what can be done with the new parts.
    Upgrades are relatively inexpensive as 90% of the already own parts are being re-used. For me only the build plate had to go.
    -Ronald
  9. snokid
    snokid Journeyman
    looking good, for us owners of the c-beam it's great to see what people think up!!!
  10. Paul Stoller
    Paul Stoller Journeyman
    I love this, I had already finished the mechanicals of my build but I can already see that I'll likely end up rebuilding multiple parts by the time I finish the entire build. Now the question becomes do I bite the bullet and just update the build to be 1000mm wide as well.
  11. Ronald van Arkel
    Hello guys,
    I'm still working on the wire diagram for the control panel. I thought I would make it in one day but I'm just using AutoCAD to draw this stuff so it will take some time. I'll include a drawing of the control panel (in some NEMA housing), limit switches with pull-up resistor and capacitor, all the other buttons. The PWM for the spindle I will leave out for now.
    The table drawing is ready, just a 3/8" plate with 30mm hole spacing all over; this one will be machined locally so that might take some time. Leveling of the bed will be done with thin sheet aluminum beer can :D (the secret it out).
    What also might take some time are the 3 flute, 1/8" shaft, GP 30°, AlTiN coated square (tip) end mills to come in. There is nothing sold here. I've decided to add an air-blower tube with coolant/lubricant injected through a Venturi valve; this will cool and clean the cut at the same time.
    Back to work!
    -Ronald
    eddiejr likes this.
  12. Darrell Corpening
    Ronald,
    I for one am in eager anticipation of the next chapter in your upgrade. Y Axis, wiring, etc.
  13. UltiBots
    UltiBots Well-Known
    Ronald - Great upgrade!!! Machined 6.5mm 6061-T6 Aluminum carriages for our V-Slot DeltaBots and found rigidity an issue. See gallery images and details below. Looking forward to implementing your upgrade.
    #13 UltiBots, Jun 4, 2016
    Synths, GrayUK and Mark Carew like this.
  14. Carl Feniak
    Carl Feniak Journeyman
    Ronald,
    Nice enhancements. A few questions:
    1) what size spacers are you using with the mini v wheels in the top portion of the plate sandwich?
    2) Are you using this setup to the belt reduction?
    GT3 20 tooth pulley, 6mm belt width:
    GT3 Timing Pulley - 20 Tooth
    GT3 40 tooth pulley, 6mm belt width:
    Where did you source yours? Doesn't look like the OpenBuilds store has them. I found this, GT Pulleys (GT2 and GT3)
    240mm GT3 6mm wide belt
    Closest I could find... 231 GT3 6 round timing bel 231mm length GT3 6mm width 5pcs free shipping-in Transmission Belts from Industry & Business on Aliexpress.com | Alibaba Group
    3) Do you think using "high torque" 9mm wide belts would be beneficial?
  15. EvanBruner
    EvanBruner Well-Known
    It looks like that's the right parts for the pulley setup. I cant find them on the openbuilds US site which is a shame since I saw them on there not long ago. It looks like the Mexico site has the parts though.
    I looked on ebay for a reduction setup and there are some but only in GT2 belts. I'd imagine the GT2 is fine for a reduction setup but I'm not sure.
    gt3 reduction belt | eBay
    If you go that way it looks like you'll have to request a belt for about a 45-55mm wheelbase, if anyone can confirm that it'd be great.
    Edit:
    HTD3M 50T 25T Belt Width 10mm Timing Pulley Belt set kit Reduction Ratio 2:1
    That seems to be a really good option if you can't get the parts from Openbuilds. 10mm belt, 3mm tooth (GT3?) and a large motor pulley for a lot of tooth engagement.
    #15 EvanBruner, Jun 11, 2016
  16. Dave420
    Dave420 New
    6mm 9mm 6mm spacers. those are not mini v wheels nut standard v wheels. if that is a
    Gantry Plate - XLarge
    #16 Dave420, Jun 11, 2016
  17. Ronald van Arkel
    Hello @EvanBruner,
    It looks like the OpenBuilds HQ has pulled the plates from the store for now to add some improvements. OpenBuilds Mexico has indeed only 2 in stock at the moment. I would wait a bit till the plate is released again as I don't see GT2 / 2GT as an option, MXL can be found as 2.93mm (0.115") pitch, close to 3mm and works well.
    The belt and pulleys are sold by OpenBuilds, it's just the plate that is missing from the store.
    @Dave420 is right about the spacers and some of the 6mm spacers you already have.
    I've been working on some other small projects that I had laying around, so still no drawing for the electrical part. The table I'll have ready by next week, so they say ;). I'm also waiting on my DW611 collet replacement (1/8) and some bit's to start with, big thank you to @UltiBots for the great tip!
    Dave420 likes this.
  18. UltiBots
    UltiBots Well-Known
    Ronald -
    I Implemented some of your upgrades. Unfortunately I was traveling when I placed the order and didn't order 2 C-Beam™ Gantry Plate - XLarge :( Been making lots of chips since I upgraded XY gantries. See the results in our C-Beam & Carriages galleries.
    Thanks for sharing - Brad
    www.UltiBots.com
    Modified C-Beam Bundle
    Dewalt 611
    Elaire 1/8" Collet
    1/8" Single Flute Carbide End Mill
    Workflow = Fusion 360 & Cam > Chilipeppr > Tinyg
    Feed = 20"/min (508mm/min), Ramp = 10"/min (245mm/min), Plunge = 8"/min (203.2mm/min)
    Pocket cut = 0.25mm rough & 0.2mm finish, 3mm max stepover
    Bore cut = 0.2mm pitch
    Contour cut = 0.25mm rough & 0.2mm finish
    Ronald van Arkel likes this.
  19. EvanBruner
    Does anyone have any tips for adjusting their eccentrics on sandwiched gantry plates? I can only seem to get the row of wheels farthest from the z axis tightened with the eccentrics, the rest are kinda floating. Thanks!
  20. Carl Feniak
    Hmm, 3D print a double ended wrench so you can tension both at the same time? Else two wrenchs, hex key, and nut driver all at once! 4 handed operation.
  21. EvanBruner
    Haha I wish I had a 3d printer or 4 hands! I'll just have to spend a bit more time on it I guess.
  22. Ronald van Arkel
    Darn, just a "few" chips. I'm about the order the collet like you have, and I'll go with those end-mills as well. Sure it will take months to have that shipped to Mexico. Next week I hope to get the table plate in, 3/8" with treated holes every 30mm. I'm also still waiting for the 100nF and 10k resistors for the switches. In the mean time I'm working on a "low cost" router, today I'll draw the cable chain. All will be with OpenBuilds parts except the cable chain.
    @EvanBruner, use a mirror and always turn the laser-marked side pointing outwards of the X-Z body ;). The eccentric spacers will not turn when you tighten the nut.
    Carl Feniak likes this.
  23. Metalguru
    Metalguru Veteran
    Ronald:
    Awesome upgrades. I just finished posting my table/Y Axis upgrades for the C-Beam machine, now have 420mm x 420mm capacity! Take a look and see what you think: C-Beam Machine Too
    I was trying to think of a way to improve the Z gantry stiffness and this is exactly it! I have most of the parts, just need the belt reduction and the double c-beam gantry plate to make it happen.
    Keep up the fair work, buddy! ;)
    GrayUK likes this.
  24. Metalguru
    Metalguru Veteran
    So what happened to the belt reduction parts in the OB store? They are not there anymore...
  25. Ronald van Arkel
    Hello @Metalguru,
    Just contact them by mail, they have them in stock, it's SKU 872.
    I'll read trough your build later, doing some precise drag chain drawing (18x25 chain). Did you by the Igus or any other chain?
    -Ronald
  26. Metalguru
    Metalguru Veteran
  27. Ronald van Arkel
    Only the plate is gone, the rest should be there:
    GT3 Timing Pulley - 20 Tooth - High Torque Series
    and... what the... Just write them tomorrow, I have no clue why the parts are not there at the moment.
    That drag chain doesn't look that bad at all. Most are made of P66 nylon so durability must be okay, I also see you can open them so no need to cut the plug of your router/spindle :).
    -Ronald
  28. Metalguru
    Metalguru Veteran
    I haven't broken one of them yet, and they have mounting holes at both ends, so you can split them in the middle into 2 pieces. 1/2m is good enough for most x/z axis applications. And, they have holes big enough for M5 screws.
    GrayUK likes this.
  29. Bob K
    Bob K New
    This is my first build so I expect that, once again, I've selected the wrong parts or are assembling them wrong. Your help would be much appreciated.
    I'm trying to use your wheel sandwich on a C-beam machine I'm building and I can't figure out how to get the anti-backlash nut's 8mm hole to line up with the 11mm hole in the C-beam end mount.
    The center of the backlash nut's is about 2 - 2.5mm higher (towards the edge with the two tapped holes in it) than the center of the 11mm hole in the end mount (best case).
    As best I can tell from the build pictures and the C-Beam plate cutter BOM I'm using the same parts.
    I'm using a 965 C-Beam end mount, a 2030 C-beam Xlarge gantry plate and a 1055 anti-backlash nut. The 965 end mount is bolted to the pre-tapped holes in the C-beam. The gantry plate is laying flat on the C-beam. There are no spacers being used.
    I used a 1/4" rod to find out where the backlash nut's hole center was in relation to the hole in the end mount.
    Bob
  30. Kyo
    Kyo Veteran
    You will need to install a 3mm spacer between the xl plate and nut block for proper alignment with the end plates.
    #30 Kyo, Jun 30, 2016
