IndieLC
Discussion in '3D printers' started by Indieflow, Apr 11, 2015.
  1. jezter6
    jezter6 New
    Will see what it looks like when it all gets here.
  2. jezter6
    jezter6 New
  3. Bad Sequel
    Bad Sequel Well-Known
    Any updates on the next version of the Indie?
  4. Indieflow
    Indieflow Journeyman
    The latest design (rendered image below) has now been tested to a standard I am happy with, I just need to tidy up the wiring before I can picture/video the real model. I need to put a lot of work into altering the build instructions prior to launch, fingers crossed end of the month.
    Also due to the unfortunate demise of RepRapPro I am currently trialling a replacement PCB heated bed to ensure the standard components are still available for others to purchase. :thumbsup:
    stephen cia, Sonny Lowe and mario like this.
  5. Bad Sequel
    Oooh, that is beautiful!
    Sonny Lowe likes this.
  6. Indieflow
    :) Thanks!
    I've really enjoyed learning how to mill the aluminium plates to make this stronger variation, I now just need to stop constantly altering the design and get on with releasing it! :banghead:
  7. Bad Sequel
    If it ain't broken don't fix it and all that ;)
    Will you be offering kits via eMaker of this design also?
  8. Indieflow
    Yes, I aim to offer the same kits (plastic parts, Ali plates, fixings) giving the options for builders that can make certain items themselves. However the Ali plates will have a lead time due to the machining time required.
  9. Bad Sequel
    Nice!
    Fairly certain I will be your first customer ;)
  10. mario
    mario New
    wonderful!!! i can't wait!!!!!!! :thumbsup::thumbsup::thumbsup:
  11. Indieflow
    Finally getting on with updating the Build Page to Indie i2 :D
    So far I have updated the links in the Parts List section (not updated the kits on eMaker yet, though they are available!). All the 3d printed parts (Stl's) are now up for those that want to get printing and next I will be sorting out the Dxf's for the Aluminium plates.
    mario likes this.
  12. Evgeniy
    Evgeniy New
    After the update files in the file section disappeared .dxf laser cutting. This is a mistake, or you want to change them?
  13. Indieflow
    Hi, the laser cut file was removed on the latest update as the Indie i2 (latest version) uses Aluminium plates instead of Acrylic! The Dxf's for these plates will be up shortly :thumbsup:
    If you still need any of the files for the older version (IndieLC) then they can be found at the following sites:
    Thingiverse
    GitHub
  14. Vslot
    Vslot New
    Testrun prototype Indie i2
    Many thanks to Simon Day for his help. Great communication and trustworthy person!!!
  15. Bad Sequel
    eMaker has changed. Cannot find the various Indie kits anymore.
  16. Indieflow
    Thank you for pointing this out, I hadn't noticed or been informed by eMaker!
    It seems that due to the closure of RepRapPro, eMaker is now only being used to sell the Fisher printer and associated spares. This means it is no longer a open shop for other enthusiasts to advertise their goods!
    I will do some research and see if I can find another suitable place to advertise the kits and source the additional components that where sold by others like me. I would use eBay though am hesitant to due to the fee they charge that would then force me to increase my prices.
    In the mean time please feel free to contact me direct for any kits you require.
  17. Indieflow
    Wow, printer is looking great! Plus loving the mods :)
  18. stephen cia
    stephen cia Well-Known
    I would love to see more video of this printer in action.
  19. Bad Sequel
    Me too so I have something to drool over while waiting for parts to arrive ;)
  20. 0x0000
    0x0000 New
    Outstanding printer - I'm really excited about the design! I've just built an Ormerod, but you've come up with some really excellent ideas! Can you post your DXF files for the aluminium parts? The eMaker shop no longer works. Thanks!
  21. Peter Eastwell
    I like this idea. because its the same one thats been tormenting my thoughts for months and here it is completed by someone else. Thank you.
    you have a wonderfully simple approach to this concept
  22. Indieflow
    I've finally got around to producing the dxf files for people to make their own plates. Rather than putting up a single DXF file I have produced a file which shows a number of views with dimensions - Gantry Plate 1 in the 'Files & Drawing' section. The dxf is to scale (1:1) so the central picture can be used for programming your CNC machines. The additional views and information are to portray the pocket and hole depths.
    Before I go to the trouble of producing the other files in this way I just wanted to check these made sense to most people? Thoughts welcome!
    eddiejr likes this.
  23. Kyo
    Kyo Veteran
    I like it! I think it makes sense. All the information you need to make the part; size , depth , location of features are all included and easy to read. :thumbsup:
    Indieflow likes this.
  24. Indieflow
    Thanks for the feedback! :thumbsup:
    As no one else has commented I'm guessing the rest agree so I best get producing the other dxf's! :)
  25. Peter Eastwell
    I think what you have done is just great and I look forward to seeing the other plate designs in the same format.
  26. Bad Sequel
    Received parts from Simon to build an Indie I2 yesterday. The aluminium and printed parts I received all look nice, and everything was neatly packed.
  27. boutrous
    boutrous New
    Hello, all . Just got done printing out the parts for a build and have my rails cut. The build is for my 5th grader. He wanted his own printer so he is going to do the build. Are the other DXF files for the other plates available? I am going to do a test print with some CF ABS and see how that works as an option to milling the parts.
    Great design, thanks for sharing.
    Gary
  28. Indieflow
    The main DXF files are now uploaded, just a few more to go for the heated bed! Also I have uploaded some of the pictures/videos for the Y-Axis assembly :D
    boutrous likes this.
  29. Bad Sequel
    Working on my build. Much of the mechanical assembly I can figure out from the 360 video, but the filament drive system, especially, needs some instructions.
