OpenBuilds OX CNC Machine
  1. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    I think a 2.2kw would be to heavy I have 1 for a future build
  2. Jestah
    Jestah Well-Known
    ya i am looking for a smaller one as they are about half the weight but even then the RCmotor spindle with an ER11 collet chuck seems like a really nice balance between power and overall weight. This looks like it would beat the pants out of a dermal but how is it up against a wood router?
  3. Robert Hummel
    Moderator
    It deff puts a drem to shame, wood router would be stronger but then your back to the weight issue again along with size.
    Jestah likes this.
  4. Jestah
    Jestah Well-Known
    Ok sign me up for a set as soon as you can ;) just hurry up and take my money already as your parts all look amazing!
    bhalkett and Mark Carew like this.
  5. Robert Hummel
    Moderator
    On the mill now
  6. bhalkett
    bhalkett New
    +1 - I'm also interested and have sent you a PM.
    Brian
  7. Robert Hummel
    Moderator
    I will try to squeeze you in ;)
  8. Robert Hummel
    Moderator
    @Jestah
    All done!
    I have press fit the 608 zz bearings in place for you :)
    Needed to complete
    4 x 45mm M4 screws
    5045 900KV RC motor
    80 amp ESC
    ER11 100mm C8 collet
    What ever collet inserts you plan to use, I only use 1/8 and 1/4 inch myself ;)
    You can prob find a motor ESC combo for a good deal on eBay and the collet shouldn't be more then $16 on eBay
    Be sure the motors shaft is 8mm when buying your motor as everything slides onto the 8mm collet see the OX RC spindle build for details :)
    bhalkett and Jestah like this.
  9. Jestah
    Jestah Well-Known
    So here I am giggling like a school girl insisting that my girlfriend comes and checks out my new parts....
    She ask why on earth she is being forced to look at more cnc parts this early in the morning ....
    Same reason I have to watch you look at pages and pages of shoes .... Cause they are purrry and spakle and will look really nice with that little black OX number I have sitting in my workshop....
    Vengeance is mine!
    Huge thanks to Robert for getting this custom order done in lest time than most shops take to quote a job in! Stellar services and highly recommended to all!
    bhalkett and Robert Hummel like this.
  10. bhalkett
    bhalkett New
    Hey Robert,
    I've ordered the motor, ESC and the collet...No pressure!
    Question...is the a place where I can download current drawings of the machined parts?
    Regards,
    Brian
  11. Robert Hummel
    Moderator
    The current files are not uploaded but I will try to get them posted
    I should have enough plate to have a kit for you soon.
  12. Stew Skinner
    Would ferrite cores reduce signal noise?
    Stew
  13. Robert Hummel
    Moderator
    I have tried with no success but that may have bin on my part lol
    I'm just a hobbyist
  14. oni305
    oni305 Well-Known
    Robert, i've a couple of questions:
    Do you use a Battery or a Power Supply?
    How much current does it draw?
    Supply voltage?
    Total Power?
  15. Stellanhaglund
    What would you say is the total weight for this machine?
  16. Robert Hummel
    Moderator
    I use a 10 amp 12DC power supply
    No, I'm now using a 1.5kw spindle.
    After milling all the 3/8 plate with my last RC Spindle I decided to go bigger so that I could push it a lot harder
  17. Robert Hummel
    Moderator
    Your kit is done, I just need your full mailing address for shipping cost
    Going to the post office today, let me know
    bhalkett likes this.
  18. bhalkett
    bhalkett New
    Hey Robert,
    They look great! Sending you a PM now.
    Brian
  19. SlyClockWerkz
    SlyClockWerkz Well-Known
    Do you mill all these aluminum parts with the rc spindle? I've had my eye on your design for awhile
  20. Robert Hummel
    Moderator
    No what you see in the pic is what I ship.
    The end user will need to get an RC 5045 with 8mm shaft, ER11 collet 100mm long, 80 amp ESC and 4 x M4 x 45mm screws.
    Then it's just a matter of assembly like in the build log.
  21. SlyClockWerkz
    No, Sorry I meant is the spindle capable of aluminum machining? Do you use your rc spindle for milling aluminum
  22. Robert Hummel
    Moderator
    Oh! Lol sorry just got up to a bunch of updates and pms
    Yes I have cut 3/8 aluminum plate as that is how I built my current mill.
    I only ever do pass's of 1/64 to avoid chatter.
    With the right bit for the job an RC spindle should last you a while before a simple rebuild would be required "replace bearings and clean"
    I now use a 1.5kw spindle for milling parts.
    This is what my mill started out as
    I then used it to upgrade itself :)
    This is a pic of parts that where milled with my RC spindle
    #652 Robert Hummel, Apr 22, 2014
    SlyClockWerkz likes this.
  23. SlyClockWerkz
    Oh ok. Looks cool! Next question is, is it quieter than a spindle with similar performance? Quietness would be my main quest haha
  24. Robert Hummel
    Moderator
    At low RPMs it screams, 10,000 RPM it's tone changes and is a lot easier on the ears.
    See my video in the build log for an idea
  25. Robert Hummel
    Moderator
    @bhalkett @Jestah
    Your orders have shipped and a pm has been sent Ty and let me know when they arrive
    Jestah likes this.
  26. bhalkett
    bhalkett New
    I'm playing around with a few different 3d printed carriers right now. I may go that way just because I can. Well see...
  27. Karl Miller
    @kram242, or anyone else, if I were to swap out the v-slot for beefier 80/20 X and Y axis (with openbuild's linear rails), could I use the OX AI plates and create an 4x8 building with the same steppers that would allow me to double up the build for use as a plasma cutter and router cnc?
    (I know that the base would need some redesign for the slats, etc.)
    I guess I am asking about the compatability of the plate's holes and whether a 8' Y and 4' X would support the weight with out sagging and still offer precision wood and aluminum cuts?
    Thanks,
    Karl Miller
  28. Mark Carew
    Hello @Karl Miller,
    The OpenRails plates hole pattern would not be the same as the V-Slots since the OpenRail bolts to extrusion and the 'V portion of the rails sits on the outside edge of the extrusion. You would need to make a plate with a wider hole pattern to achieve this.
    You can check out the example models here (Green download model button in OpenRail description) to get an idea of where the hole spacing would be for the OpenRail and the extrusion you are looking to use.
    Hope this helps
    Mark
  29. oni305
    oni305 Well-Known
    Hi @kram242,
    I'd like to build a large OX 1mx1,5m but it seems that all the 20x80 x1,5m in the world is OutOfStock...
    Can you give an estimation on when it will be sold again?
  30. Mark Carew
    Hello @oni305
    A lot of OpenBuilds distributors should be receiving their shipments soon so you should see it popping up to (hopefully) a town near you. If not we will have some shortly as well.
    Mark
