Plasma cutting table
Discussion in 'Laser Cutters' started by mytechno3d, Jun 9, 2016.
Tags:
  1. mytechno3d
    mytechno3d Veteran
    mytechno3d published a new build:
    Just Fish Metal Art likes this.
  2. Mark Carew
    This is great @mytechno3d can't wait to see more! I really like the floating Z head concept, nice Build :thumbsup:
    BTW I have to ask, what would it take to get that V-Slot plate? We have a display shelf here at OpenBuild HQ for OpenBuilds 1st and this would look great on there.
  3. mytechno3d
    mytechno3d Veteran
    Hello , i can send it to you for the price of the shipping cost.
    Perhaps do you prefer a plate with your openbuilds signs ?
  4. mytechno3d
    mytechno3d Veteran
    Water pan is really helpfull on this build ,it absorbs the toxic fumes and splash molten steel
  5. Mark Carew
    @mytechno3d That's great news! Which ever you choose but I do like the idea of the OpenBuilds logo too that would look cool! we will be more then happy to pay any shipping charges. It will be displayed proudly at OpenBuilds HQ and we thank you. :thumbsup:
    Please let us know the final cost http://support.openbuilds.com/support/home and will take care of it.
  6. pizzaman85
    that is a really great looking machine, will there be any design file for this build
  7. mytechno3d
    mytechno3d Veteran
    Hello Pizzaman85 , yes i will post specifics files for this build . I' m started today with "bent blade comb.dxf " ( sorry , maybe it is not the right name but my english is a bit limited ;) )
  8. pizzaman85
    Thank You. Cant wait to see them.
  9. mytechno3d
    mytechno3d Veteran
    Hello Mark , your Openbuilds sign is ready :) , i will paint it and send it to you .
    You can see the cut here :
    gwandad, eddiejr and Mark Carew like this.
  10. Mark Carew
    You rock bro! This is so cool to watch cut. Thank you :thumbsup:
  11. carbonlife
    I love this build, would you happen to have a BOM for this project? Thank you! And thanks for sharing this :)
    Steve
  12. silopolis
    silopolis New
    Splendid build !
    Can't wait to study the design and BoM...
  13. slm222
    slm222 New
    during the cut, im assuming the reason for the floating torch holder, does the plasma torch tip ride on the piece of metal? it has been some years since I used one. does the torch need to stay in contact with the cutting material or does it need to be slightly above the material? sorry my brain is fried, so the wording of my question may not be clear.
  14. Kyo
    Kyo Veteran
    Not being familiar with plasma, I to would like to learn more about the floating head.
  15. ghostmaker1
    This might be the coolest project I've seen for quite a while! Nice work sir! I look forward to more postings (as there is a plasma cutter somewhere in my future).
  16. Jan Hoekstra
    first of all, you made a very nice machine! I 'm working on a similar machine. So, I'm curious about what software are you using?
  17. mytechno3d
    mytechno3d Veteran
    Hello
    Sorry for my late answer ...
    The only reason of the floating torch holder is to set 0 on Z axis , you activate the endstop and go up for xx mm ( depend of the position of your endstop ) , this way your torch is just on metal sheet regardless of thickness .
    During cutting operation , torch is around 1.5 mm above the metal sheet .
    The cutting distance is very important for the quality of your cut .
    Kyo likes this.
  18. mytechno3d
    mytechno3d Veteran
    Hello
    I use autocad ( or other like illustrator , skecthup .. ) to create parts , sheetcam to create g-code ans mach3 to control the machine .
  19. slm222
    slm222 New
    Great info. With that software can you account for the plasma path to cut on the inside or outside of the design respectively?
    #19 slm222, Aug 5, 2016
  20. mytechno3d
    mytechno3d Veteran
    This is done with Sheetcam , you can define "inside" , "outside" or "on" the path , just like Vectrics or cambam
    slm222 likes this.
  21. petere101
    petere101 New
    My first machine is going to be plasma. I'm half way through the BOM for a complete custom build. I'm a bit lost as to how to connect a THC to the plasma voltage if there is no connections brought out. Can anybody help?
    Pete
  22. mytechno3d
    mytechno3d Veteran
    Hello
    It really depend of the brand of your plasma .
    On mine , there is 2 way to do the THC connection .
    1 / using a plug on the back side of my hyperterm .( with 1/50 scale )
    2 / Directly on the row voltage of the arc
    I try both , i had some trouble with de 1/50 divider ( voltage was not correct ) so i 'm now using the raw valu of the arc and it is much better .
    I'm using a low cost THC , a Proma THC SD
    I hope that can help you
  23. petere101
    petere101 New
    Thankyou for your very concise reply!
    In the diagram above, the direct connection is to the 2 outer points of the Proma. Obviously, the main cables still go to the torch head. So, how do you get the 2 extra wires inside the connection? Is there an adapter that screws in between? Or, do you cut back a bit of the screen off the cables?
    Pete
  24. mytechno3d
    mytechno3d Veteran
    It really depend of your plasma . On mine i had to drill the enclosure and make a connection on the electronic board .
  25. petere101
    petere101 New
    Thanks.
    Can I ask for some more info?
    What software and controller do you recommend for plasma cutting with THC?
    I've just been reading the cs-lab.eu website, and that stuff is impressive. You're both in the EU, have you tested this stuff?
    Pete
  26. Recklessford
    What kind of accuracy have you been seeing? +/-
  27. Mark Carew
    Props go out to @mytechno3d for sending us this super awesome plasma cut OpenBuilds Logo!
    This is going on the shelf of first :thumbsup:
    Thank you!
  28. mytechno3d
    mytechno3d Veteran
    Than you mark for this nice picture . :thumbsup:
  29. mytechno3d
    mytechno3d Veteran
    It depends of the thickness of the metal sheet .
    I usually get an accuracy between 0.4 mm and 0.8mm
  30. Redneck darrell
    Sorry I'm new here but confused what is a THC ? I'm looking at a plasma build and I can't figure out how to wire the plasma to the cnc. Great build I'm impressed.
