C-Beam Big Mouth
Discussion in 'CNC Mills/Routers' started by Richard Gouge, Jun 26, 2016.
C-Beam Big Mouth
My first build was with the basic C-Beam Build. I soon found the z clearance a little constricting So I added 2 500 mm actuators to support the x axis rail . I also left off the front and back y axis support rails for easy cleaning. I mounted the base of the machine to 1/2" mdf with 10/32 screws and blind nuts.
