Plasma cutting table
Discussion in 'Laser Cutters' started by mytechno3d, Jun 9, 2016.
Tags:
  1. petere101
    petere101 New
    THC stands for Torch Height Control. It's a method to optimise the height of the plasma arc above the work piece. In the extreme, it can be used to (for example) cut a piece of corrugated iron....
    gwandad likes this.
  2. Redneck darrell
    Ok that makes sense , now I just need to figure out how to wire the torch ( powermax 30 ) to the cnc.
  3. petere101
    petere101 New
    OK, Plasma enthusiasts!
    What size machine do you have and what is your best result in (1) Aluminium, (2) Mild Steel, and, (3) Stainless Steel. Please provide images of cut and dross :) AND plasma machine info and cutting settings. This should be interesting!
  4. mytechno3d
    mytechno3d Veteran
    My best result is in Mild Steel 3 mm , speed 2500mm/mn , arc voltage 125V , torch height 1.2mm
    [​IMG] [​IMG]
    also good in mild steel 5mm at 1400mm/mn
    Plasma cutter in an Hypertherm PowerMax 45.
    I'm still searching good setup to cut aluminium .
  5. mytechno3d
    mytechno3d Veteran
    this face has no treatment ( except it's painted ) , there were some dross on the other side , but really easy to clean.
  6. mytechno3d
    mytechno3d Veteran
    some of my works done with this cutting table
    Giarc and Evan F like this.
  7. Svetko Buha
    Ciao
    E 'possibile acquistare The laser Box ( laser 2.8W) già montate o di progetto per la sua preparazione per uso hobbisti.
    Buha
  8. mytechno3d
    mytechno3d Veteran
    Hello
    Yes it is possible , i will contact you on PM
  9. mytechno3d
    mytechno3d Veteran
    My CNC plasma cutting table is now working with a THC , it is a pretty nice addon , but really usefull only on big size cutting .
  10. mytechno3d
    mytechno3d Veteran
    z floting head.jpg IMG_20170308_182605.jpg IMG_20170308_182551.jpg IMG_20170308_182524.jpg IMG_20170308_182538.jpg For those who asked me some pictures of the Floating Head
    polemidis and Kyo like this.
  11. Mark Carew
  12. EfrainLenisMaturano
    hi, can you send the wiring diagram please? thanls
  13. mytechno3d
    mytechno3d Veteran
    Hello
    For which part do you need the wiring diagram ?
    For all the movements, it is identical to the OX CNC , for the wiring of theTHC , you can find the wiring on this thread some post before .
  14. EfrainLenisMaturano
    Ok thank you
  15. trivalb
    trivalb New
    Hi, I already have an OX derived router diy.. I'm wondering. Are delrin wheel ok for a plasma cutter? No troubles whith high temperature of iron small pieces from the spot ? Sorry for the poor english.
  16. mytechno3d
    mytechno3d Veteran
    Hello
    I use delrin v wheels from around a year , and i have no problem with them.
    They are pretty resistant .. :)
    trivalb likes this.
  17. JustinTime
    A few days ago on another thread someone mentioned that he had problem with the delrin wheels. They got a flat spot when he left his machine idle overnight. I think his gantry was a bit heavy, which makes it more prone to getting a flat spot.
  18. mytechno3d
    mytechno3d Veteran
    it can happed when your eccentric spacer is over tight
  19. Redneck darrell
    What program do you use to do the cutting with? All I can find in open source is laser programs nothing with a lead in or lead out.
  20. mytechno3d
    mytechno3d Veteran
    I do not use an opensource program with this machine .
    I use sheetcam to generate my gcode file , and you can use grbl software to control it like a cnc ( with a torch instead router )
  21. Tinkerman92
    @mytechno3d I'm thinking about doing a build very similar to this minus the water table for now.
    I have 3 questions
    1. Do you feel the 20x80 rails are necessary without a water table or could 20x40 rails be used instead
    2. What size belt and pull are you using
    3. What size motors
  22. Redneck darrell
    I just tried sheet cam out well worth buying just one question im using ardunio grbl what post processor do you use
  23. mytechno3d
    mytechno3d Veteran
    Hello
    Sorry to answer you only now , to much work to do and not enough time ...
    1 / because au the size of the machine i prefer using 20x80 instead 20x40 rails , plasma cutting go really fast , and you must have the maximum rigidity .
    2 / I'm using GT3 belt and GT3 pulley ( same as ox CNC )
    3 / I use nema 23 for x and y axis and nema 17 for 7 axis
  24. mytechno3d
    mytechno3d Veteran
    Hello
    I 'm using a mach3 compatible card now , but when i was using GRBL , from memory i also use mach3 post processor , but as i said , it is from memory ..
  25. mytechno3d
    mytechno3d Veteran
    It's been 2 years now that I use this machine , no problem at all :) .
    My only advice is not to invest in THC for this size on cutting table ( on only use 3 or 4 times in 2 years )
  26. John Mayer
    Can you please provide the BOM?
  27. mytechno3d
    mytechno3d Veteran
    Hello , i will try to post the BOM tomorrow afternoon
  28. mytechno3d
    mytechno3d Veteran
    BOM is now published , some parts are missing but will be added really soon .
    John Mayer likes this.
  29. John Mayer
    Thanks! Looking forward the completed version!
  30. toomanyquail
    I would also love to see the completed BOM. This machine looks great. What is the fastest feed rate you feel comfortable with on the machine (not worrying about plate thickness)? Thanks!!
