Spindle cooling setup
Discussion in 'Other Builds' started by Anthony Bolgar, Nov 1, 2016.
  1. Anthony Bolgar
    Anthony Bolgar Journeyman
    Smcfarrell and GrayUK like this.
  2. GrayUK
    Gonna be interested in this! :thumbsup:
  3. Anthony Bolgar
    I was racking my brain trying to find a small waterproof container to have at least a small resevoire....then I remembered I picked up two waterproof instrument cases ( 120mm X 160mm X 80mm) on the FreeStore, one of them will fit just beautifully in an 80mm v-slot setup, will probably make the rad/fan frame out of 80mm v-slot as well so that it will be symetrycal, and let me make some better rad/fan brackets to hold them in place. and it has a clear lid, so I can dye the water/antifreeze a cool florescent color for some bling.
  4. Mark Carew
    Great job @Anthony Bolgar love this, sut a professional and sleek setup. :thumbsup:
    Looking forward to seeing how you set up the reservoir
    Thanks for sharing this.
  5. Anthony Bolgar
    I am going to try using it without a reservoir, I hope it will work just as it is. If it does need a small reservoir, I will hang it on the back side of the frame, or possibly build it into a mounting base. This has been a sort of design it as you build it project, I work best that way.
  6. dddman
    dddman Journeyman
    This is the system I made :)
    Anthony Bolgar likes this.
  7. Anthony Bolgar
    Looks good @dddman . Your picture made me realize that I should have a temperature sensor with readout. Will have to add that feature to mine.
  8. dddman
    dddman Journeyman
    haha... this is my power supply voltage... now I need a temperature readout!
  9. GrayUK
    dddman. Picture has gone. :banghead:
    Can you re-upload it.
  10. dddman
    dddman Journeyman
    Still there for me... here it is :
    Smcfarrell, Mark Carew and GrayUK like this.
  11. Anthony Bolgar
    @dddman lol! It is so obvious that a temp readout would be helpful and we both missed it.
  12. Mark Carew
    Super cool @dddman looks like something straight out of back to the future! :thumbsup:
    Love it
