Laser V
Discussion in 'Laser Cutters' started by Robert Hummel, Nov 30, 2013.
  1. Woodie49
    Woodie49 New
    I'm useing the Mini V Wheel Kit, spacer & ect. Every thing is square.
    It does look like some of the V wheel aren't hiting the top and bottom of the V groove.
    I did get the Y axis wheels to move good.
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Sounds like something is not plumb.
    Is it possible that the dimensional width of the gantry does not exactly match the dimensional width of the frame - as far as the V-Wheels / V-Slots are concerned ? In which case additional shims / spacers may improve the situation.
    Tweakie.
  3. JCPhlux
    JCPhlux Well-Known
    What plates are you using?
  4. JCPhlux
    JCPhlux Well-Known
    I am getting excited my parts are one day out. :D
  5. Woodie49
    Woodie49 New
    The Plates I got from Robert.
  6. Wojtek
    Wojtek New
    i am at the moment designing the case for the laser cutter. what should the minimum hight of it be
  7. skarab
    skarab Journeyman
    I still had some 20x40 aluminum profile and 20x20x1000mm v-slot from my last build. Your project running through my head for a while. Pending the material for the OX, I started a laser router wickedly inspired by your construction.
    Thank you for sharing :D
    Robert Hummel likes this.
  8. JCPhlux
    JCPhlux Well-Known
    looks good.
    I finally got all my parts in but have a 4 week contract that really needed 8 weeks so I have to put my build on hold.
  9. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    I hope that means your care package made it :)
  10. JCPhlux
    JCPhlux Well-Known
    Hey sorry Robert, I thought I sent you a msg. Go the package I have not had a chance to play wit any of it yet but it looks great.
  11. skarab
    skarab Journeyman
    Too happy :D A big thank to Robert Hummel for his build log, OpenBuilds and all the DIY community! Next the OX :thumbsup:
    2014-06-22 17.13.52.jpg 2014-06-22 17.12.35.jpg 2014-06-22 17.13.00.jpg 2014-06-22 17.28.40.jpg
    Mark Carew and Robert Hummel like this.
  12. Robert Hummel
    Moderator
  13. Mark Carew
    Well done @skarab :thumbsup: looks great!
  14. Robert Hummel
    Moderator
    So after going through end user suggestions, the following updates have bin added to the laser V LD2X
    -Power indication LED
    -Relay is powered by 5v regulator rather then the arduino
    -Relay contact rating of 3 amps
    -Regulated 5v pin rail added along side of the negative pin rail
    -Manual laser on/off pin-out for a momentary switch beside the reset pin-out
    -Dual stepstick Y axis
    -Single stepstick X axis
    -Single stepstick Z axis added for laser focusing
    -RX/TX pin out
    Everything else is the same, board size was enlarged by 20 mm width wise.
    Again I have kept it single sided for easy DIY
    The updated file will be posted soon along with a parts list
    AlexUT, Mark Carew and skarab like this.
  15. Mark Carew
    Sounds great Robert! :thumbsup:
  16. JCPhlux
    JCPhlux Well-Known
    Ok, I am back. I am going to start my build tomorrow!
    skarab likes this.
  17. Woodie49
    Woodie49 New
    Has the updated file and parts list been posted yet?
  18. Pokry
    Pokry New
    Hi
    I have a question. Could someone draw a square and a circle in the program to generate g-code and add a file? I want to see what he looks like. Is he saved in txt format?
  19. bobt
    bobt Well-Known
  20. JCPhlux
    JCPhlux Well-Known
  21. Pokry
    Pokry New
    I am doing a project on stm32f401 and do not know how to program it is able to do different shapes.
  22. JCPhlux
    JCPhlux Well-Known
    What is stm32f401?
  23. Menneset
    Menneset New
    I was planning a laser cutter build and stumbled across this site and in particular this build. This is freaking awesome! This is one of--forget that, this is the best and most detailed build post I have seen. I am so pumped up right now, I gotta get to work on this...
  24. JCPhlux
    JCPhlux Well-Known
    Very cool. Cant wait to see your build.
  25. Robert Hummel
    Moderator
    New LD3X test board :D
    Wiring and getting ready for full testing :thumbsup:
  26. AlexUT
    AlexUT New
  27. JCPhlux
    JCPhlux Well-Known
    very nice
  28. skarab
    skarab Journeyman
    2W Laser diod from eBay.
  29. Robert Hummel
    Moderator
    Part number is M140
