MUSK-OX
Discussion in 'CNC Mills/Routers' started by Larry_AK, Jan 27, 2015.
  1. Larry_AK
    Larry_AK New
    Larry_AK published a new build:
  2. Nick W
    Nick W Well-Known
    Looks good! I like the 3D printed parts. I guess it's hard to say if they helped any since you didn't have any flexing issues before installing them. I'm contemplating on welding them together. Your clamping solution looks really nice too.
    Larry_AK likes this.
  3. Larry_AK
    Larry_AK New
    All I can say is it makes the X beam very solid, like one piece. I printed them real tight, then had to drive them in with a hammer and wood dowel. I'm sure it would be very difficult to take apart without damaging it.
  4. Serge E.
    Serge E. Journeyman
    Very nice ... Your build didn't take that long. Nice to see the wife getting involved as well ...
    Looking forward to the evolution of your OX.
  5. Larry_AK
    Larry_AK New
    A little video MUSK-OX first run.
  6. Larry_AK
    Larry_AK New
    Guys, I have some of these little proximity sensor. Maybe one of you can explain / show me how to wire them to the bob? The bob runs on 5v and sensor on 10-30v. Don’t what to cook anything if I can help it!
    Larry
    Product Name: Proximity Switch Sensor
    Model: SN04-N
    Wire Type: DC 3 Wire Type (Brown, Black, Blue)
    Theory: Inductance Sensor
    Output Type: NPN, NO
    Output: Switching Transducer
    Sensing Distance: 4mm
    Working Voltage: 10-30V DC
    Response Frequency: 500Hz max
    Indicator: Red LED
    Size: 36 x 18 x 18mm / 1.4" x 0.7" x 0.7" (L*W*H)
    Cable Length (Approx.): 110cm / 43.3"
    Hole Size: 0.9 x 0.4cm / 0.35" x 0.2" (L*W)
    Extenal Material: ABS Resin
    Net Weight: 34g
    Color: Black, Green
    mybuild14 likes this.
  7. Mark Carew
    Great Build @Larry_AK thank you for sharing. We love to see any new projects you have made with it as well.
    Thanks again
    Mark
  8. Larry_AK
    Larry_AK New
    We moved last summer, it's still sitting in the corner of the shop waiting it's turn to be hooked up. I did start working on a new bench for the MUSK-OX but something always seems to come along that needs doing. Soon!
  9. Larry_AK
    Larry_AK New
    Up date, I did get Musk-OX up and running again before Christmas and made a few gifts.
    snokid likes this.
  10. Mark Carew
    Wow you are rocking with that OX! Great projects, love the way the frame turned out with the rope,well done! thank you for sharing
  11. Giarc
    Maybe you mentioned it before, but what software did you use for those lithopanes? They look great.
  12. Larry_AK
    Larry_AK New
    PhotoVCarve with this Bit I picked up on amazon.
    SYT@ CNC Carving 4.82 Deg Tapered Angle Ball Tip radius=0.5mm X 1/4" Shank tungsten Solid Carbide HRC55 with TiAIN Coated Router Bits
  13. Giarc
    What? You didn't go for the 5 pack of Amana bits like that for $447.50 that pops up as a choice on Amazon when I searched the one you posted. ;) (SYT@ CNC Carving 4.82 Deg Tapered Angle Ball Tip radius=0.5mm X 1/4" Shank tungsten Solid Carbide HRC55 with TiAIN Coated Router Bits: Amazon.com: Industrial & Scientific) But seriously, I will have to order one like you suggested. It looks good. We need a sticky just for end mills and bits so when people find one they like after some time in on it they can post it up. Maybe break it down by size and type (flat, V, etc...)
    Thanks for the info.
    #13 Giarc, Jan 17, 2017
