UK40OB
Discussion in 'Laser Cutters' started by Ariel Yahni, Sep 26, 2016.
  1. Ariel Yahni
    Ariel Yahni OpenBuilds Team
    Ariel Yahni published a new build:
  2. Mark Carew
    This is a great Build Aerial :thumbsup: Thank you for sharing.
    Ariel Yahni likes this.
  3. Kyo
    Kyo Veteran
    Very cool, What is the new cutting capacity of the laser?
  4. Ariel Yahni
    Kyo at the moment im getting 230mmx550mm until i finishing arranging the the internal. Hope to get 300x600 at least
    Kyo likes this.
  5. MConner
    MConner New
    Great idea pulling the divider, maximize your envelope. I also like your colored plastic bracket, well made and a nice look. Did you intend to use color or was it just available? You have given me some ideas for additional parts. :)
  6. Ariel Yahni
    I have made some other builds with that color, it just looks very cool. That final mirror holder was the last piece :(
  7. Ariel Yahni
    Adding the part in dxf format
    atwise and DaveyWeaver like this.
  8. Aaronvt
    Aaronvt New
    Very inspiring build!
    So how much of the v-slot do you need to do this build? did you measure the sizes of the cuts you needed for the frame?
  9. Ariel Yahni
    Thanks Aaronvt, and as you say should be only for inspiration, i wanted to prove it was possible and fairly easy . You need to consider that i attached the gantry to the sheet metal on the sides. As we know this machines are made without making sure they are square.
    Y Side profiles are 350mm
    X profile is about 744mm ( you should mesure once you have everything else in place )
    DaveyWeaver likes this.
  10. Dregs
    Dregs New
    I have a K40 and can appreciate your comment about the machines not being very square. I've been facing issues with the stock gantry being skewed, and the "floor" panel being uneven. I've removed the stock support and replaced it with a powered Z-table... my biggest challenge there was squaring it to an un-square gantry, and leveling it to an un-level bottom :)
    I've been tempted to gut the gantry and build one like you did, but I might stay with the original sized. I'd start out by assuming nothing was level or square, and build the gantry system to float and provide as much structure itself. I have to wonder though, at what point should we consider just ditching the enclosure itself and building one out of any of the various maker-beam/open-beam type products.
    Lastly, how do you like your Smoothie conversion? I'm running a Lasersaur setup using an Arduino Mega + RAMPS ... not bad, but I'm always looking for other options.
    EDIT: I noted on your build list that you include new steppers... any reason for this?
  11. Ariel Yahni
    @Dregs ive being using LaserWeb since over a year, at that point and still today it is compatible with grbl and smoothie, both superior to ramps ( i hate compiling ). The reason i chose to put new steppers is simple: First i had them, second the is no information on the stock steppers to properly setup the current. Nothing else.
    At this point i was going to start a new mod to build a complete gantry but my tube has died so there is not much interest now :(
  12. Anthony Bolgar
    Anthony Bolgar Journeyman
    Ariel, I'll start a fundme campaign for you, and get you back up and running.
  13. Trey Roudebush
    I downloaded the files and they are really weird. Some of the parts aren't there and the ones that are scattered throughout the whole page and have a bunch of lines around them?
  14. Ariel Yahni
    Trey that's very wierd. I just downloaded the file I posted and this is what you should see
  15. Trey Roudebush
    I will download sketchup and try that since I used the dxf files and inventor.
  16. Alessandro Zelletta
    salve
    Files dxf downloaded are not consistent. Do you need to open them with a specific program?
    Alex Zelletta
  17. Ariel Yahni
    Alessandro, please explain?
  18. Alessandro Zelletta
    You have made available the dxf file of plexiglass details. I opened the file with autocad, but the result is vertical lines. It does not appear as indicated by you in your reply of 2 August 2017. The question is, it takes a dedicated software.
    Ciao Alessandro
    101LEDS&MORE likes this.
  19. Ariel Yahni
    The file that i have uploaded is for Sketchup.
    I have attached here a dxf, mind that i have not verified just exported it. Let me know if it wokrs
  20. Ariel Yahni
    After months without a tube now I'm back again on this build.
    Today I made a simple bed
  21. Alessandro Zelletta
    I solved .
    I changed the view of the drawing. Positioning it on Z / Y axes
    Thank you.
    A greeting
  22. Alessandro Zelletta
    the side guides fixing holes at which height (in mm) should be positioned.
    Thank you
  23. Ariel Yahni
    You mean the rails? If its that then you need to calculate yourself based on the current location of the mirrors, each machine is constructed differently
  24. Alessandro Zelletta
    okay, I understand.
    Thank you
    Ciao
  25. 101LEDS&MORE
    Great build, how about a file for the acrylic parts in svg? Some of us don't use sketchup or have a program to open 3d dxf files and need something in a 2d format.
  26. Ariel Yahni
    Here you go
  27. Grant B
    Grant B New
    Excellent looking conversion. I'm doing similar here in Salisbury UK ... so a question please ?
    What are you using for the carriage bar - is it simply a piece of 20mm sqr extruded Alluminium bar ?
    Another question too please..... the firmware will presumably needs adjusting for the increased cut area.... how is this done, or do you simply load bigger images to cut ?
    My software skills are not good, so any advice is welcomed
  28. Ariel Yahni
    All profiles a Openbuilds 20x40
    You just load a bigger image unless you set up firmware limits that are not on by default.
  29. GrayUK
    I wonder if someone , one day, will notice that there is a niche market in just making strong, empty, laser cabinets? :rolleyes:
    They could make basic cases, or even kits, and then work up to really classy looking units. :thumbsup:
  30. Ariel Yahni
    Im working on this :)
    GrayUK likes this.
