Hello all. I hope someone can Help ....please..... I'm getting Crazy I added some screenshots of the motors and setup. First of all I love my machine... but I have some problems getting my motors to run smooth after cconfiguring. Let me first explain where I bought my motors and my setup. C-Beam X-large fro Tronixmaker Belgium Motor, Controller and board from German Ebay: 2.5Nm Nema23 Schrittmotor CNC 4 Achse 5A TB6600HG Endstufe Professionell 36V 10A 2.5Nm Nema23 Schrittmotor CNC 4 Achse 5A TB6600HG Endstufe Professionell 36V 10A | eBay Software: Mach3 I received a PDF from the manufacture to use these settings. 3rd_5Axis_Breakout_Board_Main_Settings_En.pdf Had some problems first with the motor running smooth and loosing steps in Mach3......but after reading some good tutorials I found it was related to windows GUI setting to classic....( good tip to all other users). Set Default Units for Setup: in MM's In Mach3 settings Motor tuning and setup: Steps per: 750 Velocity: 100 Acceleration: 15 Step Pulse: 5 Dir Pulse: 5 I tried to increase the Steps per: to 2000.......but than the motor jerk and run crasy. when jogging using the MPG Jog in Mach3 or on the Keyboard of the Computer....all Motors run like a charm...real nice.....so fare so good. Now when I try to calibrate my Machine.....that it runs accurate in mm's...it happens..........the Motors getting really slow. I go back in the Motor tuning and setup in MAch3....the Steps per ( was 750) changed to like 24 steps per...and it runs sooooo slow now!! Now what I do wrong???? Something with the controllers....wrong jumper settings??? Strange is that all runs smooth when I jog the MPG in Mach3..... I hope that someone has a good tip...configuring my setup..... Thank you all.
Hello I found the problem. In was in the board settings and the jumper from the controller. Greats Goran
