My 2nd cnc build
Discussion in 'CNC Mills/Routers' started by Garrettcompston, Feb 19, 2017.
  1. Garrettcompston
  2. stargeezer
    stargeezer Journeyman
    Looks Great!
    I hope you will post a video of it in motion after you get it finished. I am also building a C-beam based router an considered the 8mm screws, but in the end I choose to use 1/2" 5 start acme screws instead. There has been some discussion about the 8mm screws being "fast" enough to use on a decent sized machine. I wasn't sure either way and decided in favor of what I had used before.
    More pics please. I love to see how others build their controller case.
  3. Garrettcompston
    The controler case isn't finished either once the machine is running. I plan on cutting alot of pieces for the case. I would like to see your screw setup
  4. T4Concepts
    T4Concepts Journeyman
    I'd like to see a little more as well ............................ but it seems that Garrett has disappeared !
    I think the machine has great potential :thumbsup::thumbsup:
    TURK
