looking forward to this i already made a miter attachment to mine making cuts up to 32 inches .. helps alot
I am debating whether the gantry should be horizontal with a brake in the same plane as the wheels or vertical screwing in through the gantry plate. I will make a picture.
keep us update this will blow out a pro 40 vega fence And talking about fence this oen is nice but the price is not TS-LS Table Saw Fence, 52" Range, Incra LS52-TS-XL but i might consider building one from Vslots which would be more rigid
So I am thinking either of these. These are just quickly thrown together, those handles are not to scale they are just models I found. There are three bolts to attach the rail to the table so I cannot do the vertical rail
A TR8*8 screw through a nut block won't have sufficient holding power to be of any value. You really need a clamp of some sort. The one you have shown, modified with a good rubber bumper is probably the best approach. One option I have been looking into is adapting Titanium Skewer Drum Bicycle Quick Release Hole Hub Carrrier Rack Install LO | eBay. I haven't gotten very far with this because I only received them yesterday but as it turns out the threaded rod is M5x0.8 so it is easily removed and regular screws can be threaded into the cam clamp head which can in turn pull against the inside of the V-slot channel as a locking method.
Hey Don. Nice looking design! We hope to add a break to the Part Store in the future. If you or Rick find the type you like, please reach out to us at http://support.openbuilds.com/support/home with the details. Thanks
Welcome to the forum @TrishC. (It's about time you joined us.) The rubber bumper upgrade I was referring to can be found at Toggle Clamp Upgrade although the ones he selected may be a bit big for your use.
Let me know how that bicycle hub goes because that seems to be cheap strong and other than a bit long, perfect
Worked like a charm. Removed the bicycle bolt and threaded in an M8x35. Sawed off the bolt head and added back the original shoulder washer and then added a rubber washer and finally a tee-nut. The rubber washer helps soften the grip on the extrusion and increases the acceptable grip range. Without it there is enough force in these clamps to deform the inside edge of the extrusion. Here is the final assembly. I got them as a better alternative to the adjustable lever clamps used in Adjustable Router Guide Template. Note: the exposed stud was trimmed to a length of 17mm below the cam lever handle (based on it being at the 90°, locked position). This appears to be just about right for passing through an 1/8th inch plate and into the tee-nut in the extrusion.
What does the top of the bolt look like before modification? Does it thread into a nut inside that cam lever? I think I would prefer to cut on that end and save buy an m8 bolt, mostly because I would want to buy an m8 bolt with a t-slot end. Maybe I will stop being cheap and get some of these McMaster-Carr
Oops, meant M5x35... As for the connection, it's fairly simple. The threads are tight however as this end of the rod was not intended to be adjustable. As for the M8 T-stud, it's way too big for V-Slot. (Sorry for leading you astray on that one.) The biggest bolt that will fit is 1/4-20 and you may need to grind the head of any T-headed bolt that big to get it into the slot. I'm currently working on a drill press table and plan to use 1/4-20 hot shoe studs with the sides trimmed as part of the hold down system. Cam clamps to use with these are fairly easy to find should you want to go that route.
Hmmmm... I like this table saw fence. I may make one, but maybe add steppers and a control panel. Zero it against the blade then input the width you want to cut. Not necessary, but fun. Edit: This has me thinking, if "necessity" is the mother of invention, then is "not necessary, but fun" the drunken uncle of invention?
Now another engineering debate. Because these are soft wheels, I have to be careful about how the clamping force interacts with the wheels on the rail. Do I use one on each side of the fence and/or on both gantries? Depending on what I do it could tilt the fence or pull the bearings out of the wheels. I almost wonder if I could put the clamp on another wheel and use that as the brake in line with the rest of the wheels.
Hi, I'd being thinking to build a fence like this for a while, with the same problem about the brake. What you think about using a C-Bean linear actuator, with a wheel handle instead of an stepper motor? and just a rail at the other side. This way you don't need a brake.
The brake just showed up, but now I am having second thoughts. Its almost a waste to invest so much good material (open builds) in my terrible table saw.
Yes, I got the same feeling... the materials to use cost more than my table saw, that's why I was trying to get to a design without motors and as simple possible, at the end I want a better saw anyway. But, it is still a very cool project.
So I finally did some work on this. I stumbled across a small toggle clamp which worked perfect if not over priced. I did a POC using nuts as spacers so I could double check my measurements and calculations. I just ordered my 40mm spacers and my 60mm shoulder bolts. I ended up not likely the hub clamps mentioned above because they snapped too easily. I would have rathered use the toggle clamp in a direction either opposing the wheel axis or braking on the rail but the fasteners prevented that.
I need some help. The delrin wheels allow the rail to flex when clamped down. This is exactly why I didn't want to clamp with force perpendicular to the radial axis of the wheels. Would the polycarbonate or steel be better
Polycarbonate might be better but you might consider moving the clamp to end of the plate and pushing against the rail instead. This would eliminate the torsional leverage on the system.
Going by the first picture above, wouldn't it be just easier to devise a clamp to go through the plate, directly into the centre gully with a tee nut, and put in any necessary spacers so as not to put any stress on the wheels. Rick's bicycle clamp, or similar, really looks to be the easiest method. Even a bolt with a knurled head would do as well. Additionally, with a few springs included, could you not create notches at say inch, or centimeter marks, and pre-mark them? Gray
I could do a corner bracket or a cube but I would probably need spacers to get the position perfect. This little clamp is strong for its size and the price was killer cheap compared to what I expected. I wanted to position it under the plate but then the open position has no room for the handle. They are discontinued and although I can find similar, I think the required close tolerances would be a deal killer. It would have to be basically rubbing on the top. That was the original plan but I was having trouble finding the right hardware to enable it. The bicycle clamp was very very cheap, but it was very very very very cheaply made. Snapped one of them and then the other I still have yet to find (whoops). Nice Idea about the notches but I prefer to have a scale on the table, tape like that is fairly cheap. I tried that, the screws and nuts on the underside of the plate would rub the rail. Its not even close where I could just grind down the nut and cut the screw. It is tight. Might try polycarbonate if this all fails. Thanks.
So, I found this little angle bracket in my junk bin and it worked. Also, my shoulder bolts and spacers came in and everything is perfect.
Well back to the drawing board. If I want to use the miter slot, then I need to move the spacer and bolt attaching the table to the top slot of the extrusion . If I do that then I can only used rollers on one side of the carriage. So I think I am going to order some openrail to stack on top of a 20x20 extrusion instead of the 20x60. Of course that will flex more. And I will also have to redo the spacers under my rollers to adjust the spacing of the main fence and table height.
Done. The spacers weren't perfect, but after spending $25 bucks on spacers which I thought were perfect and they weren't I was willing to do some finangling. I need to find some square spacers or I will try to just use small bits of extrusion. I also need to find a small L bracket that is better for the brake but for now it works perfect. The fence is a bit long so I will need to cut that too. All and all I am happy
