WIN a Free Smoothieboard! [CLOSED]
Discussion in '* CONTESTS * Win Cool Stuff!' started by MaryD, Mar 21, 2017.
Thread Status:
Not open for further replies.
  1. Doug!
    Doug! New
    I would build a specialized 3-axis mill: Z-axis, A-axis, and C-axis with a swappable spindle and laser head. So a 2-axis trunnion/ H-table and a Z-axis as a peck drill. This would allow for milling 3D relief hemispheres with laser-scored details.. you know, for making half globes of planets!
    MaryD likes this.
  2. MidnightQuads
    I'd use it to make a swappable CNC router and 3D printer.
    MaryD likes this.
  3. TanManGuy
    TanManGuy New
    24" by 24" by 24" 3d printer
    MaryD likes this.
  4. Brian Ching
    Would love to build a laser cutter engraver!
    MaryD likes this.
  5. EdStoddard
    I am in the process of building a Delta6 delta printer with 360mm diameter build area. I am still in need of a controller. Hint. Hint.
    MaryD likes this.
  6. Yos
    Yos New
    Thanks for the contest.
    If I'll win, it will be used as the brains for my new delta printer! (custom built)
    MaryD likes this.
  7. Sigmaz
    Sigmaz New
    I have always wanted to convert my manual Bridgeport mill to a CNC hybrid.
    Recently I have been starting to put the plan all down on paper and sourcing components. i.e. Motors, Drivers, Belts...
    I really think that a Smoothie would run the mill much better than any parallel breakout or RAMPS style device.
    MaryD likes this.
  8. DaveRodecap
    I'd put it in my D-bit CoreXY printer.
    MaryD likes this.
  9. Michael Scholtz
    My printers are the the 3Done - RepRapWiki machines. I have no idea how many people have built them but the reason for them is nothing other than wanting to build an affordable high quality printer and I see no reason not to share the design for others to build it should they want to.
    I have been building with Ramps since I started long ago enough that I had to solder the components onto the 1st one I built.
    Smoothie boards have always been something I've wanted to add to my machines and I'd particularly want to see how it improves print quality.
    MaryD likes this.
  10. Paul Stoller
    Paul Stoller Journeyman
    I would use it for a laser build. Probably 40w or 80w co2 laser.
    MaryD likes this.
  11. Licensed2hench
  12. Licensed2hench
    I have been wanting to build a new 3D printer with a larger build area. Ideally 300mm x 300mm
    I have been planing to go with a Core XY design and a smoothie board to drive it. :)
    MaryD likes this.
  13. Atanur
    Atanur New
    A 3D printer that can capable to use multicolor flament with 4 axis to produce complicated parts.
    MaryD likes this.
  14. Steve Barney
    MaryD likes this.
  15. Ryan James
    I would use it on the D-bot I'm working on. Would be a good replacement for the RAMPS board.
    MaryD likes this.
  16. crystaldragon141
    I'd use it on the new printer I'm designing. It's based on the CoreXY architecture. I call it SemiXY, it's designed using as many stock openbuilds parts as possible. The approximate build volume will be 450mm x 450mm x 450mm. I'll be working on uploading the build to the forum soon.
    MaryD likes this.
  17. Pepetruen0
    I'd install it on my laser cutter and then another one on an i3
    MaryD likes this.
  18. Marmil
    Marmil New
    Does it look like there's a miniature CD/floppy CNC pen plotter hiding in this box? I think so.
    Would a Smoothieboard be total overkill? Probably.
    Do I still want to try it out? Yes! :)
    MaryD likes this.
  19. richard yates
    Upgrade on my current 750mm X 750mm V-Slot machine
    MaryD likes this.
  20. Juha Kuusama
    I would write a sw module to control ODrive board and build a super fast PnP machine!
    MaryD likes this.
  21. Amazonense
    I would build my first 3D printer
    MaryD likes this.
  22. Jamie Charleston
    I would use this for my custom 9' x 5' OX based CNC Router. My 9' Y axis is made with 9' 2"x3"x 1/4" Aluminum tube with OpenRail .
    MaryD and crispin like this.
  23. Bigpaws Bear
    I have a few mendel Prusa frames that could use a good controler!
    MaryD likes this.
  24. PhotoSgt85
    PhotoSgt85 Well-Known
    I would use this in an upcoming multi-use machine that will be used for producing large cuts with a router/spindle setup, laser cutting, and a non-transferred plasma torch for producing RF restive coatings. This machine will focus around large envelope production with accuracy, so the use of a board with the features of a SmoothieBoard are essential.
    MaryD likes this.
  25. Rodm
    Rodm Well-Known
    Nice contest!
    What would I build???... What don't I want to build???... There are so many great builds. Every time I surf the site I find something else I would like to do. Latest is the neat little laser engraver by Kyo. I did a simple 3d printer in January, Almost finished with the med sized c beam plate maker build 750x and 625y that will be used to make stuff for what will probably be aa ox like machine for 1/2 sheets (4x4). That's the machine it would most likely end up in.
    Hi my name is Rod and I think I'm a buildaholic.:banghead:
    MaryD likes this.
  26. ampapa
    ampapa New
    The SmoothieBoard with its 32bit processor would make a great center piece for my first build!
    Start with great electronics is what I say.. I have a CoreXY design in mind with a large printable surface... it's as good as mine... lol!
    ampapa,
    MaryD likes this.
  27. Dwa60
    Dwa60 New
    I would use it on the one I have been building for the last 6 months. Thank You
    MaryD likes this.
  28. gjwest
    gjwest New
    I'd use it to build a 3D printer
    MaryD likes this.
  29. M attAUSA
    M attAUSA New
    I would use this for my large Ox CNC. Looking at the gshield as my budget has already gone over but this would complete it very nicely
    MaryD likes this.
  30. Limine3D
    Limine3D New
    Well since I am working on a build right now...the 3D printer!
    MaryD likes this.
Thread Status:
