Nice printer I have the same in full black ;-) Do you have bed tilting betwin front and back compared to the center of gravity made by the leadscreews ?
Me too, but still have have instability cause by flexibility of Z motor holders, and flexibility of 2020 Z extrusion (well bolted), only when I use Z hop, perfect without.
yes he talks about that I think 1 video back. Maverick Seems like this kind of design has a couple of problems. First one is it's not very rigid you have seemed to solve that problem with new corners. The z axis seems to give people problems. I have seen many people move the z linear screws to the center of gravity and that seems to mostly fix that problem. In your next video could you put some kind of indicator on the bed and flex it a bit, so we can see how much flex there is? One last thing I llike the build and talk style of videos you did on other topics, this series you are more showing what you have done after the fact. more building!!! LOL thanks for the hours of entertainment though... Bob
Maverick I saw the answer this weekend at MRRF. use a c-beam on the back for the z axis. I will post a like to a video as soon as I get it done. Bob
spauda01 here Saw your 3-27 video, hooray for stock config You're right about not leaving enough room in the control box for lcd adapter, I either connect to pc or to octoprint. If you let me know how much wider and taller you want the box I'll post an updated version.
Hey spauda01 I am building your cbot Well done with the PDF so much detail Do you have a macro for the bom I have a build plate of 250x250. And lead screw off 300mm Cheers marty I look fwd to any updates
What is the marlin firmware that you have. I have also built a 300x300 machine but I can't get the steppers to rotate, they hum and get hot but won't rotate. I'm not sure if I have them wired incorrectly but everything was followed as the instructions. If you don't mind sending me a copy of your marlin configuration. And if possible pictures of the motor wires and ramps wiring that you have
hello, I would like to build one, but I have no idea where to find the printed pieces ( I don't have a 3D printer yet), so can anyone tell me where i could buy it ? Thanks
What is your country ? If you are in France we can deal together, if not go on C-bot / D-bot Facebook to ask for print in your country or find a fablab to print it for your, or ask on "3d hub" close to your home to print it for you. Take care about choosing the right parts because there is a lot of mods on this printer to improve the parts, the C-bot reworks is a good one and check witch extruder you want too.
