C-Beam "2" XLarge CNC Router
Discussion in 'CNC Mills/Routers' started by mcbuilder22, Apr 15, 2017.
  1. mcbuilder22
  2. WildBill
    WildBill Well-Known
    What are you using for the spindle speed for the aluminum?
  3. mcbuilder22
    The lowest speed setting on the Dewalt DWP611 router. I'm new at this so I could be way off but I will say I was really nervous after reading online that Aluminum is hard to cut but now I've had good cuts all day and this is my first day of cutting. I've varied feed rate from 15ipm to 45 ipm.
  4. WildBill
    WildBill Well-Known
    I just checked and the lowest speed for that router looks to be 16,000. I asked because I just build the regular XL with the Makita router and have been cutting 1/8" aluminum and getting great results but at a much lower feed rate, around 8ipm and 10,000 spindle speed. I broke a few bit's trying faster feed rates but with enough variables that I was not sure what was out of wack.
    I will try your speeds to see if I can get things going faster,
    thanks
  5. WildBill
    WildBill Well-Known
    I have been using a 2 fluke bit cutting 6061 .125" thick.
  6. mcbuilder22
    I'm cutting .03 per step down into the material. Started at .01 and .02 and worked my testing up.
  7. WildBill
    WildBill Well-Known
    I have been using .02
    I have been getting great results, but would like to run a little faster.
  8. mcbuilder22
    Looking at my pieces. 15 ipm and .01 the edge cut was smooth like glass. The others have a slight rough edge.
    #9 mcbuilder22, Apr 15, 2017
  9. Anthony Perry
    What are your setting for the steps and feeds for mach 3 I just built an ox/sphinx cross and am having trouble with setting up me steps and feeds for mach 3
  10. mcbuilder22
    2540 steps per inch set in Mach3
    800 steps per revolution set on the motor driver
  11. mcbuilder22
    Today I was doing some more cutting and got good results with a feed rate of 45 ipm and .01 depth of cut.
    I can push it more but I'm not sure how that effects machine and tool life so I'm thinking I will stick with the .01 depth of cut even though cut times are longer.
    I haven't used any cutting oil yet. I have air blowing the chips out and that seems to work well. I'm a little concerned introducing oil will cause the chips to stick.
  12. Anthony Perry
    thanks
  13. WildBill
    WildBill Well-Known
    Well I am making progress as I slowly keep increasing the feed rate. I have doubled the speed that I was working at before. I am up to 15 and think I would be able to double it again or more because I not seeing any issues. I have been using a spray bottle of water to cool and lubricate the bit. I have been working with 1/8" aluminum and after the next step will see how I make out with 1/4" aluminum.
    I think my earlier problem was trying to make to deep a cut so I am staying at .01 inch (about .25mm) and have not broken any more mill bits at that depth.
    Seeing its only a couple weeks into my first CNC I am very happy with the results you can get.
  14. mcbuilder22
    I've cut hours worth over the last few days and the only bit I've broken was from the work piece moving because of incorrect tab settings.
    On .190 thick 5052 I'm starting to get some "chattering" of the cutter so tomorrow I'm going to adjust some settings. I don't know if it's my feed rates too high or if it's because the cutter is 1/8" diameter and going too deep.
    I'm also wondering how much cutting you get before the end mill gets dull. I doubt I'm there yet but maybe the new sharp edge is worn a little and that is the change I've seen.
  15. mcbuilder22
    I figured out where my chatter came from. At some point I had slightly turned up my RPM on the router.
    I'm getting what I consider nice cuts with the following:
    - Dewalt Router RPM turned all the way down the most it can go
    - 30 IPM feed rate
    - .01 depth of cut
    - 1 flute 1/8 end mill (Onsurd 63-610)
    I could push it faster and deeper but I'm not sure what that does to tool wear and machine stress over time. I let the CNC run and go do something else so I'm not overly concerned with getting the fastest speed at this point.
  16. WildBill
    WildBill Well-Known
    I have cranked up the speed to the point where I am not sure I want to go any more. I started at 8 IPM and am now using 50 IPM. more than 6x speed increase makes me smile.
    Router at 27,000 RPM
    Cut Depth is .01"
    2 flute 1/8" end mill (cheap 10 for $10 ones)
    I was cutting plates of 1/4" 6061 aluminum all afternoon and had no problems and have not broken any bits since going to .01 cut depth. I will play a little with the cut depth next to see what happens if I increase it some. After I am happy with the setup I might even buy some quality bits.
    I do stand and watch with an air hose to blow chips away and give a squirt of water once in a while to cool & lube the bit.
  17. mcbuilder22
  18. WildBill
    WildBill Well-Known
    I was just about to place an Amazon order so I think I will add one of these to the order.
    If it can mist and blow away the chips then I could walk away. At that price even if it didn't work you could use use the parts for something else.
  19. mcbuilder22
    I haven't tried the misting part but the air spray works fine. You can unscrew that 8mm connector and it has 1/4" threads that fit a standard air hose connector.
  20. WildBill
    WildBill Well-Known
    And I have a bunch of air hoses with 1/4" ends so it should be easy to hook up.
  21. OpenBuildsAccount1
    How did you invert the linear rails for the plate? I have having my rod exposed to debri and would love to flip it. Thanks!
  22. WildBill
    WildBill Well-Known
    Look at the C-Beam LX build guide. I built mine following the guide.
    I have the X axis plate against the Z axis plate so the whole Z axis assembly moves.
  23. Giarc
    mcbuilder22 likes this.
  24. WildBill
    WildBill Well-Known
    Thanks for the pointer, half hour after I received it I had it working, and it works great.
  25. mcbuilder22
    I made a modification to my CNC to make it more rigid. My problem was on parts 1 end of the part would be higher than the other causing the end mill to dig in hard on the outside cut.
    My first attempt to fix this I just put in a 1/4 end mill and had it mill my spoiler board level. This helped a bit but wasn't a full fix. I think the flex in the MDF platform was the issue.
    So I ordered a large aluminum plate 3/8" thick to replace the MDF platform then mounted the mdf spoiler board on top of the aluminum. Again I milled the MDF down to a flat level.
    This has greatly improved how level my material is from one side to the other and has fixed my issue. It also has the added benefit of giving me an extra 5/8" Z travel.
  26. mcbuilder22
    Reasons I've broken end mills while cutting aluminum:
    • Unlevel material causing too deep of cut on 1 end
    • Too small tabs on the work piece and it came loose
    • Aluminum plate not screwed down to the spoiler board tight enough and vibration caused the end mill to catch the wall of the groove it cut
    • Making a hole I didn't have the tool path correct to remove all material. There was a small sliver in the middle of the hole that came loose when the cutter got deep in the hole. This caused binding and snapped the end mill.
    These might be obvious to others but maybe someone can learn from my pain.
    GrayUK and Rick 2.0 like this.
  27. Adam Filipowicz
    Adam Filipowicz Journeyman
    Are you using only one Gantry Plate per 1000mm Cbeam? Adding a 2nd one will impove stiffness.. but reduce travel.
  28. mcbuilder22
    I might have to try that. I'm currently having an issue that seems to only happen when cutting on the far front. When doing .190" thick aluminum with a 1/8" bit cutting around the outside of a part I start to get more than normal vibration and chatter. I've broke 1 bit because it hit the side of the cut from the vibration and I've had to stop the machine a couple more times because it sounded bad like it was about to break the bit.
  29. mcbuilder22
    To further fine tune things and try to reduce chatter I finally downloaded a feeds and speeds calculater here: CNCCookbook: Be a Better CNC'er
    I was running at 30ipm with the Dewalt RPM at the minimum. The calculator suggested 37 ipm at the max RPM (27000). I've now tried this on a couple parts and it seems to have reduced the chatter some more.
    This seems to be a 1 step at a time learning process to get everything dialed in. I will keep posting here to help others and help myself remember.
