Batxillerat Research Project: Design and construction of a CNC
Discussion in 'CNC Mills/Routers' started by Pol Feliu, Jul 6, 2014.
  1. Pol Feliu
    Pol Feliu New
    Pol Feliu published a new build:
  2. Seul Kee
    Seul Kee New
    Hi, Pol!
    I am also a new OpenBuilder living in Busan, South Korea. (I have been to your
    city once about 10 years ago and I had a great time!)
    I just begun to work on my 4' x 4' OX-like CNC router which I hope to finish by
    the end of July. :D
    That is why I am keenly interested in your CNC build. (Especially with respect to
    your Arduino-based solution.)
    I originally wanted to use Arduino and some shields together with LinuxCNC.
    After many sleepless nights, however, I ended up choosing EdingCNC's CPU5A4
    control board and its free control software. It is awesome that you designed the
    motor control board yourself!
    Come to think of it, I should have posted my build like you and others did. But
    I must admit that I was lazy as well as busy. :nailbite: I will do sooner or later, though!
    Best luck for your CNC build!
    Tae
    #2 Seul Kee, Jul 6, 2014
  3. Pol Feliu
    Pol Feliu New
    Thankyou! I've just finished building the board, and haven't tested yet. I hope it will work!
    I was lazy about it too. Now I'm kind of stucked and i don't have much work to do because the components from the part store are taking a while...
  4. Mark Carew
    Welcome to OpenBuilds @Pol Feliu ! The work sheet that you put together looks great and we look forward to your builds :thumbsup:
    Mark
  5. JerryD
    JerryD New
    Nice Build, I'm designing something similar. Any deflection issues with the tall gantry supports?
  6. Pol Feliu
    Pol Feliu New
    Hello Jerry. I haven't done more updates on this post (haven't had the time). Since then i changed the dremel to a laminate trim router that works better but it is heavier. It is more stiff than it looks but it could be defnitly better. Long story short: if you have the money, time and resources go for a water/plasma cut plate like the OX routers, if you don't and use a small spindle/router like i do and want the flexibility to change the height of the y axis this is great.
    I've been meaning to change it but not because it doesn't work well, but rather because i would like to move on to a nice silent watercooled spindle.
    Lots of things have changed, hope i find some time to write them down.
  7. JerryD
    JerryD New
    Thanks for the insight, Pol. I'll consider the OX plates, the only issue is Z-axis travel. Most of them have minimal travel ranges of 4-6". I'm looking to get a max of 12-16" depending on how I mount the machine to the table. 90% of anything I do at that height will be soft wood etching, laser etching, or 3D printing so it's not like the machine will be under harsh forces like cutting wood or aluminum. I would like to have the ability to cut wood an aluminum if I need to and in that case I could lower the gantry to as low as practical. It's looking more like building two machines may be the best option. If I had the room for two machines that would help, lol!
    Thanks again!
    -J
  8. Pol Feliu
    Pol Feliu New
    You could make some tall plates. What i mean is that they must be worth it because its more simple since the wheels and the y gantry mount directly to it.
    If you get them custom made i suggest you make several holes so that you can adjust the height to the table if you needed. That would be very cool. With this most of the Z axis would be unused but its not a problem since you'd be using the stiffer part of it
  9. JerryD
    JerryD New
    I like that idea. I've also considered making a portion of the table and spoil board removable (open to the floor) so I could drop in tall work pieces when I need to.
  10. Pol Feliu
    Pol Feliu New
    watch frank howarth's vertical table on his old cnc video.
    Its very cool, but for jointery i still think a pantorouter is better.
