OpenBuilds MiniMill
Discussion in 'CNC Mills/Routers' started by Mark Carew, May 26, 2017.
  1. Sonny Lowe
    Sonny Lowe Journeyman
    I'm running on a RCA Cambio Tablet, Windows 10, running at 32 bit on a 64 bit based processor, I've never had any issues with this setup...knock on wood ;)
  2. mopar99
    mopar99 New
    ok, that confirm it... I need to find a 32 bit os work off of...:mad: with all the "junk" i have laying around i would have though i had something to us for it. however that give me an ideal, try the surface tablet.
  3. Sonny Lowe
    I would have loved to use my Surface 2 tablet but you need a Surface Pro to run third party software :(
  4. mopar99
    mopar99 New
    well that stinks:cry:... does LinuxCNC work:rolleyes:? may just have to do some summer cleaning to before i can invest in another pc;)...
  5. Sonny Lowe
    I ahve no idea about LinuxCNC, maybe one of the other guys can chime in and let us know!?!?
    Haha, I know what you mean, move the old for the new :p
  6. Peter98
    Peter98 New
    In the Actuator testing data something struck me as odd. The odds and even test results are almost identical so in reality all of the variability measured is between odd and even tests? Is this an over sight and something is driving this error or is there something in the methodology that i do not know?
    My guess given the 2mm pitch lead screws is accuracy should be much better than being presented?
  7. MaryD
    MaryD OpenBuilds Team
    3D Carving!
  8. Rick 2.0
  9. MaryD
    Good eye Rick. We are releasing a new LED light ring very shortly....
    Sonny Lowe likes this.
  10. Sonny Lowe
    This is a great example of the true 3D capabilities of this little machine, it is the very thing that drew me to it in the first place :thumbsup:
    Very cool project, I cut a few very similar skulls around Halloween last year...too much fun :D
    Can't wait to get my hands on one of the LED Rings...
    MaryD likes this.
  11. mopar99
    mopar99 New
    Just be overly cautious here but does anyone have a photo of the stepper wiring? Or can confirm this one?
  12. Julius
    Julius Well-Known
    just find the pairs of wires then go off that. Color combos are not a standard between all motors
  13. Alejandro M
    Im trrying to use a GRBL Shield to operate this, what settings are you using? currently mine trembles a lot when steppers are moving and cant seem to figure out why. Thank you
  14. Georgio M.
    I'm hoping to get some help for a Fusion 360 build of the MiniMill. I'm putting one together from the OpenBuilds Part CAD library, but the lead screw isn't lining up. It looks about 3mm off, but the video and parts list call for a 3mm spacer. The attached file is where I'm at. Appreciate the help, and can't wait to build one in real life!
  15. Sonny Lowe
    Not sure I can help, but I'll try to take a look at the file later tonight...
  16. Sonny Lowe
    I think I've got it, your mate between the 3mm spacer and the anti-back lash nut block has the spacer seated into the counterbore. The counterbore is actual smaller ID than the spacer OD, so the spacer should nest on top of the block, not recess.You may still have a slight misalignment (1mm), I think I added a 1mm precision shim to both of those spacer (total 4mm) on all Axis!?!? I'll take a look at my machine tonight and let you know for sure...
    Sonny
    Georgio M. likes this.
  17. dddman
    dddman Journeyman
    Can a X-Large plate be used instead of a double one on the Z-axis? I understand that the handles would have to be removed. Would it make it less sturdy?
  18. Sonny Lowe
    I used the XL Gantry Plate (XLP) when first testing the Minimill, it worked perfectly fine. Keep in mind the other two axis see similar loads when moving, and they utilize the XLP. I found that the XLP gave you a bit more Z movement (it's shorter than the GDP) and the fact the wheels are on the outside it will allow easy adjustment if eccentric wheels if required. The Double Gantry Plate (DGP) spreads the load out wider (taller in the case of Z-Axis) so it should be inherently more stable, although I'm not 100% sure the extra stability would be noticeable!?!? I saw no significant difference between the two.
    Regards,
    Sonny
    p.s. I still ran one handle even with the XLP
    dddman likes this.
  19. dddman
    dddman Journeyman
    Yesterday night spare time investment :)
    Georgio M. and Sonny Lowe like this.
  20. Georgio M.
    Thanks for the help, Sonny! I was probably way sleepier than I thought. :banghead: Anywho, here's a close enough Fusion 360 model if anyone needs it.
    AndreMerc likes this.
  21. dddman
    dddman Journeyman
    Here are some updates for my minimill:
    Printed some feet on vibration dampener:
    Printed some limit switch mounts (X-, X+ (mirrored) and Zup):
    Printed some wire management:
    I just ordered the CNC xPRO V3 for the controller :)
    Does anyone have examples of their sacrificial board?
    Does anyone knows why the OB spindle mount is 71mm? It doesn't seem to fit on any spindle without adding shims...
  22. Anthony Bolgar
    Anthony Bolgar Journeyman
    If you are looking for a router mount that fits standard spindle sizes, Brandon over at SMW3d.com has some inexpensive custom aluminum ones.
    cdii likes this.
  23. Sonny Lowe
    "This mount works best with the Bosh Colt Router; With some additional shimming, this mount is also compatible with the Dewalt 611 Router!"
    dddman likes this.
  24. AcBCDN
    AcBCDN New
    I am using LinuxCNC on my minimill.
  25. Julius
    Julius Well-Known
    While your 3D printing, make the shim for the 611. File is on thingverse.
    As a former CBeam user, I say it's essential to use a plate with mini wheels inside and regular on the outside as well to be able to cut aluminum properly. You want to go at least 600mm/min with a single flute and .010 or more otherwise you just waste time.
  26. dddman
    dddman Journeyman
    Here's the plate I made for the CNC xPro, the top of the enclosure just finished printing. The hole is for a 60mm fan (50mm spacing between the holes) and I will use some 1.5 inches standoff to link them together.
    If you want to use this design, here's some tips: Screw the bottom of the standoff first, then the case_bottom to the C-beam and finally the CNC xPro to the case_bottom. wire everything up and you'll be able to add the case_top and the fan. The fan uses 4 M4x20mm screws.
    #86 dddman, Aug 19, 2017
    Sonny Lowe and Grantman like this.
  27. Lofton Harris
    Yesterday I received a 400w brushless spindle motor with power supply, PWM speed control and spindle mount. The spindle is 52mm diameter and the supplied mount doesn't fit the mini mill. So I created an adapter ring that looks like it will do the job. I'll post the stl file shortly. The spindle is way quieter than any of my routers, large, medium or small.
    CNC 400W Brushless Spindle Motor ER11 & Mach3 PWM speed controller & Mount + PSU | eBay
    My mini mill is looking like it's going to need it's own electronics cabinet, what with two power supplies, PWM and controller board.
  28. Julius
    Julius Well-Known
    What RPM range? Did you bog it down yet?
  29. lofton
    lofton New
    0-12,000 RPM. Haven't milled anything yet so don't know whether it will bog down.
    Here's the stl file for my adapter ring:
    I wrapped the outside of the spindle as well as the adapter with one layer of plastic tape to prevent slippage.
  30. lofton
    lofton New
    Might you be so kind as to post the stl file(s) for your endstop switch mounts? Thanks!
