Ike:Laser
Discussion in 'Laser Cutters' started by Jean-Francois Talbot, Sep 10, 2017.
  1. Jean-Francois Talbot
    Jean-Francois Talbot published a new build:
  2. Jean-Francois Talbot
    Here are the source files, the file upload in the build page would not work.
    Enjoy.
    Jeff
    Azman Ishak likes this.
  3. JustinTime
    I wonder how the flex of the plastic plates manifested itself since you don't really have any force on the y axis to cause the plate to flex. Unless, of course, you plan to use the machine as hybrid, laser and/or router/spindle.
  4. Jean-Francois Talbot
    I was able to flex it by hand, without too much force. It might have worked just fine, as you said, there won't be any resistance on the machine's axis.
    But I figured, with the back forth motion of the X axis, the last thing I wanted was a slight oscillating X axis support.
    Unless someone else builds this out of UHMW, we will likely never know :D
