TABLE OX Router/3D-Printer
Discussion in '3D printers' started by angelo, Jun 2, 2014.
  1. angelo
    angelo New
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Neat idea @angelo - I like multi purpose machines. :thumbsup:
    Tweakie.
  3. Mark Carew
    I like this one too and I think it would be cool as just a 3 tier router without the 3D printer! :thumbsup:
  4. angelo
    angelo New
  5. angelo
    angelo New
    Yippie, now I have the Parts.
    They was in the customs office (Zollamt).
    Now I can start to Build the machine :)
  6. angelo
    angelo New
    Sh**...
    i have ordered the1 x 8mm Acme Nut Block.
    But they had delivered the V-Slot ACME Nut Plate
    But I need this:
    8mm Acme Nut Block is Out of Stock
    I write them and ask, If they can send it.
    #6 angelo, Jul 16, 2014
  7. angelo
    angelo New
    Now I have to wait for the Nema23, 0,9 Deg, 126Ncm, -> 23HM22-2804S
    http://www.osmtec.com/nema_23_stepper_motor_23_hm.htm
    And for the 8mm Acme Nut Block.
    By the Way.. The cut for the cuted Linear Rail (60x20) have a tolerance from +/- 0,2 mm.
    In the first Step I have put some Precision Shim - 10x5x1mm betwen the Plate and the Rail :-(.
    If it is possible for future Order, that we can get a Service of precision cut, that was for the next builders a great help.
    #7 angelo, Jul 17, 2014
  8. angelo
    angelo New
    MY Nema23, 126Ncm, 0,9Deg 126Ncm and 56mm Shaft was arived yesterday.
    And my 8mm Acme Nut Block is also now here.
    Thank you for you perfect Support to the OpenBuilds Team:
    Here my 1/128 Microstepperdriver (Nema23, 126Ncm,0,9 deg ->400 Fullsteps x 1/128 Microsteps = 51200 Steps per turn -> 96Khz Signal (ArduinoDue+RADDS v1.1) /51200 Steps/Turn= 1,875 Turn/second ->
    GT3-30Tooth = 60mm one Turn x 1,875 Turn /seconds = 112,50 mm/sec and 60mm/turn / 51200 Steps/Turn= 0,001171875mm/step)
    With this Setup you have a theoretic Precison of 0,001mm/Step and for
    Singlestepping a Speed of= 110mm/sec
    Doublestepping a Speed of =220mm/sec
    Quadstepping a Speed of over 400 mm/sec :)
    http://www.repetier.com/firmware/v091/
    (Allow quad stepping. Required for frequencies larger 24000 Hz.)
    http://www.robocutters.co.uk/proddetail.asp?prod=GT3PulleyBelt-OD30-ID8
    32-Bit Electronic:
    http://www.dr-henschke.de/RADDS_due.html
  9. angelo
    angelo New
    By the Way..
    Why I would like to or what is my desicion to build an Router with Delrin Wheels and GT3 Timing Belts...
    They are silence, because I put the Router/Printer in my basement.
    So I can close the Basement-Door and my Wife and the Neighbours has no Problems with it.
    If I use Hiwin Guides (ritsch,ratsch) and if I use ballscrew with a pitch of 5mm (12 Turns Ballscrew =1 Turn GT3 30 Teeth = 60mm).
    For This, I think about a 2,2Kw WaterCooled "China-Spindle" (reasen, because I can Plugin a 12 mm diameter Shaft for Wood..)
    Have anyone experiance with low-noise Spindle up to 300 Watt?
    (Sorry for my bad english)
    #9 angelo, Jul 22, 2014
  10. angelo
    angelo New
    This was we like to Print maybe ...
  11. angelo
    angelo New
    The Electronic setup:
    #11 angelo, Jul 31, 2014
  12. Tweakie
    Moderator
    Thank you for posting these excellent video's Angelo, they are most informative :thumbsup:
    Tweakie.
  13. angelo
    angelo New
  14. angelo
    angelo New
    Endstops and last V-Slot for Z-Achses (60x20) arrived :)
    I Thing i have now all I need
  15. angelo
    angelo New
    a short question...
    Everyone knows a loudnes or silence Spindle up 200 Watt?
    Otherwice I think about a 2,2KW China Spindle Watercooled.
    Thank you for the Answers in advance
  16. angelo
    angelo New
  17. Mark Carew
    Yes @angelo but yours looks like it will be much easier to make for sure. :thumbsup: I was taking a look at how to build that one and it looks like it will take some time.
