Fushion 360 users
Discussion in 'CAD' started by Barry Danks, Sep 21, 2017.
  1. Barry Danks
    Barry Danks Well-Known
    Hey how do I put 3 holes 120deg apart on a circle.
    Thanks in advanced
  2. Joe Santarsiero
    Joe Santarsiero OB addict
    A few ways to do this. One way is to extrude circle. new sketch the hole circle. cut hole using extrude. Then under create select pattern then circular.
    In the circular pattern dialog choose features for pattern type, select the hole you cut(use the time frame), select the axis of the disk you are cutting, quantity 3.
  3. JustinTime
    There is also an option to make holes in Fusion. I can't recall the exact procedure, i don't have Fusion on my new computer, but it's one of the menu options.
  4. Barry Danks
    Been doing cad for years but my first drawings with any 3d software. Thanks a bunch
    #4 Barry Danks, Sep 22, 2017
  5. Barry Danks
    Any ideas why it won't thread this hole?
  6. Joe Santarsiero
    Does it run into the front hole? It might not like that. Uncheck full length and try a depth to see if this is the case.
  7. Barry Danks
    Thanks again
  8. Barry Danks
    Need more assistance guys I Looked for tutorials on moving the group of 4 small threaded holes and also copying to the other.
    side.
    Thanks very much in advanced
  9. Joe Santarsiero
    I could tell you how to do this off the top of my head for SW, but not fusion. I'll try though.
    To move the existing hole pattern you just find and edit the sketch of the holes. To make a pattern on the same plane you can either pattern the holes in the sketch or pattern the feature out of sketch. To duplicate everything on the bottom of the part you select extrude cut, select the same sketch again, select extrude from, and choose the bottom surface.
  10. Barry Danks
    Anyone else ever have issues exporting a dxf file. I've watched a couple of tutorials and pretty sure I'm doing it right, but I cant open the dxf
  11. Barry Danks
    Banging head on desk....Why? lol
  12. David the swarfer
    Fusion is an odd beasty (to me anyway) but once you 'get it' it is simple enough.
    The key is that you do most stuff by doing a 2D sketch first, then extruding that to 3D.
    You should watch these....
  13. Barry Danks
    Yes awesome videos
  14. Barry Danks
    Any ideas how to make this slot wider?
  15. Joe Santarsiero
    Find the sketch or feature that made it that wide Barry! You need to have more confidence in yourself sir. lol
    crispin likes this.
