Lautr3k
Discussion in '3D printers' started by skarab, Jan 7, 2014.
  1. carl
    carl New
    looking sweet :thumbsup::thumbsup:
  2. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    Ty :)
    I went with 480mm 20x40 for the Z rails and also plan to use 20x40 for the X.
    The support rails will be the only 20x20 used so it's sturdy that's for sure lol
    Todd and carl like this.
  3. Robert Hummel
    Moderator
    Little update using pics :)
    Time to cut some leadscrews and design the X Axis carriage :)
    Edit
    Leadscrews installed :)
    #183 Robert Hummel, Jun 22, 2014
    carl, Todd, Mark Carew and 1 other person like this.
  4. skarab
    skarab Journeyman
    Beautiful, I love your work :)
    Todd and Robert Hummel like this.
  5. Mark Carew
    WOW Robert very nice!:thumbsup:
    Robert Hummel likes this.
  6. Robert Hummel
    Moderator
    Just finished up the last parts, I have the X carriage designed in my nerd just gotta make it up in sketchup and mill it :)
    Support plates, and leadscrew end supports ;)
    Mark Carew, carl and skarab like this.
  7. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Nice work Robert :thumbsup:
    Tweakie.
  8. carl
    carl New
    Robert you must be up and running now ?
  9. Robert Hummel
    Moderator
    Not yet lol
    Ramps kit will be here end of the week and I'm still waiting for my E3Dv6 to ship.
    Also I have no idea what extruder to use.
    I have seen the bulldog design but would like to use a design that is proven to work.
    Everything is built except the bed plate for the MK2b and mounting plate for the extruder/hotend.
    Tried to get some PLA but E3D stock is just hmmm wow!
  10. carl
    carl New
    Robert Hummel...oh so you not going to try using the hole 300mm x 300mm bed then ? for filament i use this http://3dfilaprint.com/ its the best iv come a cross so far but do not know what the shipping will be to you tho o_O...
  11. Robert Hummel
    Moderator
    The main bed will be as large as possible for non heated prints :)
    The mk2 may be used in some way "detachable"
    carl likes this.
  12. Robert Hummel
    Moderator
    carl likes this.
  13. Robert Hummel
    Moderator
    Ramps kit came in :)
    The hot end not shipped :(
    The MK2B board is not flat so I'm taking it I have some work ahead of me here lol
    Is it possible for me to just mill an aluminum 1/4" bed with a way to mount the MK2B when need ?
    What solutions are used to get the board flat? as I'm sure that I am not the only one with a un-even bed
    carl likes this.
  14. carl
    carl New
    I'm using a aluminum sheet 2mm thick on top of my 300mmx300mm heat bed with auto bed leveling so i don't worry about a un-even bed.
    #194 carl, Jun 27, 2014
  15. carl
    carl New
  16. Robert Hummel
    Moderator
    Heat sinks mounted and cured :)
    skarab, Todd and carl like this.
  17. Todd
    Todd New
    I found these at igus that can be had here in the US for a decent price. I am sure the mounts will need some modifications.
    1 DST-LS-10X25-R 2.00 $/PC $21.85 $43.70
    DS SCRW10X25
    2 units at 381 mm ea
    overall length tolerance is +/-2mm
    Right Hand,10x25 stainless steel
    http://www.igus.com/wpck/10893/SD_Gewindetriebe
  18. Robert Hummel
    Moderator
    While looking I noticed the length of the leadscrew listed at 38.1 inches
  19. Todd
    Todd New
    I took a second look at the quote I got from them and it shows 381mm, so should be ok $88US for 2 lead screws and the nuts to go with them. Not too bad a price.
  20. Robert Hummel
    Moderator
    I agree that's a good deal for sure
    Do they do longer lengths ?
  21. Todd
    Todd New
    Yes, that quote was for the length that skarab said was needed for his build, but I saw this in the quote
    "Rail and shafting sections of less than 1000 mm in length are non-returnable and non-
    refundable.
    Rail and shafting sections exceeding 1,829 mm must ship motor freight. "
  22. carl
    carl New
    Robert did you salt some thing out for your bed ? as i having a lot of trouble with my unlevel bed too now even with auto bed leveling as it more of a bowing i'm using the hole 300mm x 300mm, and also getting a wobble in the Y
    Anyone got a idea how to fix or a design that can help ? thinking i may do smooth rods and bearings if i can not stop the wobble
  23. Francisco Angelini
    Hi Skarab,
    Tinitylabs stay offline i don't find this 10 start 25mm pitch fast lead screw and nut here in my country :(
  24. skarab
    skarab Journeyman
    Hello there,
    Trinitylabs was the only supplier for this specific model. And as they closed their doors, I do not find an alternative to the same specifications / price. Robert Hummel doing some tests with Openbuilds screws and I think it works, but not a crazy speed.
    carl likes this.
  25. carl
    carl New
    Thank you so much Robert Hummel the parts you made are here :thumbsup::):cool: iv only just got to want until my wheels turn up now, as the openbuilds uk were out of stock so i've ordered them from USA
    #205 carl, Jul 17, 2014
    skarab and Todd like this.
  26. Jim Neill
    Jim Neill New
    That looks promising. The only thing that has kept me from building a Luatr3k was the closing of Trinity Labs. Hopefully someone will give this a try and report back.
    I also think Robert is on to something in regards to creating a kit for the machined parts. It would make things a whole lot easier on everyone sourcing this stuff from the same place we're getting the other components from.
  27. Axel
    Axel New
    if you dont have aluminium spacer you can use m5 washer (7 pieces) :)
    so you can build on sunday your printer.
    and TL drawing from fast lead screw have anyone saving this and can post here?
    thanks
    #207 Axel, Jul 20, 2014
  28. Todd
    Todd New
    I am hoping to start building this soon now that I am moving into my new house next week. I am going to try using the igus lead screws, but I don't think they are going to fit in the couplings, so would it be better to file down the lead screws or drill out the couplers, and then file down some flat spots for the screws?
  29. skarab
    skarab Journeyman
    Good question. I think it depends on your equipment and your abilities. In my opinion, it is easier to drill couplers, but reduce the screw is cleaner. Wondering how you'll even do :)
    carl likes this.
  30. Tweakie
    Moderator
    Hi Todd,
    For reliable operation of CNC machines in general it is quite important that the motor shaft / coupler / lead screw are as concentric as possible.
    If you do not have access to a lathe then taking the parts to a local machine shop (or friend with a lathe) where they can be turned / drilled accurately will, I am sure, pay dividends in the long term. ;)
    Tweakie.
    Todd, carl and skarab like this.
