Coffee Cup!
Discussion in 'Other Builds' started by richard wilkinson, Oct 23, 2017.
  1. richard wilkinson
    As a disabled stroke survivor I have a couple of projects I want to try.
    I have a cappuccino machine with frother. The problem is that being only able to use one hand, I cannot lift the cup and use the frother at the same time! So I thought if I built a platform, I could use a stepper motor, to lift the cup into position.I know this sounds weird, but any suggestions regarding what equipment I should use, would be appreciated.
    Finally I want to assemble this,on my own, to see if I can do this one-handed, although I can get help if required. Also, I really don’t want spend too much money, just to lift a coffee cup!
    Cheers, Richard
  2. Rick 2.0
    Need parameters defined a little better:
    What is the distance from the countertop (or other base elevation) to the bottom of the raised cup? Any obstacles preventing a direct lift? (A photo of the system would be nice.)
    What tools do you have you can still work with? I.e. vise, saws, 3D printer, etc.
  3. richard wilkinson
    coffee.jpg Thanks for your reply:
    The cup is 3.25 tall and it is 6.5" to the bottom of the frother.
    I could solder quite well, but never tried one-handed.
    I now use a 2ft x 4ft table as my workbench and have a small suction vise and various saws, rotary tools etc. that I use.
    I spent 6 months in hospitals and nursing homes, before being allowed home, but my cognitive ability keeps improving, hence the desire to start tinkering. Apologies for the cluttered picture and thanks so much, for your help. Richard
  4. Scotty Orr
    Scotty Orr Journeyman
  5. richard wilkinson
    Thanks Scotty, for your help, checked it on Amazon and one review says:
    This works great for my somewhat unique purpose. It's used as a can lift for a stroke patient with one functional arm to allow the use of normal electric can opener with one hand.
    Sounds rather like me and with Amazon's great return policy, will give it a try. Will be very tempted to add the stepper motor and build my skill sets a little.
    Cheers, all the best, Richard
  6. Rick 2.0
    Scotty, that's way too easy. How about something a little more substantial....
    The Official OpenBuilds Coffee Cup Lifter
    Actually found the same thing Scotty found at Banggood for a few dollars less but with a much more substantial delivery time. I would suggest removing the knob, fixing the nut behind it in place, and using a small electric screwdriver with a nut driver bit to go up and down. The video on Banggood shows it takes a fair amount of cranking and wouldn't want the cappuccino to get cold.
  7. Scotty Orr
    Rick, I like yours much better (little pricey though)! And I realized it would be difficult to get a stepper to work on the other one anyway - difficult to fix "in mid air". The electric screw driver is a good idea.
  8. richard wilkinson
    Rick, this looks great, but i couldn't find The Official OpenBuilds Coffee Cup Lifter online.
    Will probably try the one Scotty found and if I ever figure out how to attach a motor, will post some pics here.
    By the way, any suggestions as to what motor would be up to the task?
    Thanks everyone, for the help!
  9. Scotty Orr
  10. richard wilkinson
    Now this looks like something I could probably do, Thanks Scotty
