Plasma cutter - 608 on steel tube version
Discussion in 'Other Builds' started by openhardwarecoza, Apr 17, 2015.
  1. EfrainLenisMaturano
    Dear,
    Do you have any video with the equipment working?? any coment please.
    @Raed Al Nuaimi
    Some old posts on OpenBuilds G+ community - shows a picture story of how I build the torch by converting a handheld torch:
    1. Buying the plasma https://plus.google.com/+PetervanderWalt/posts/MPkTR144xuP
    2. Tearing down the inverter to see how it works https://plus.google.com/+PetervanderWalt/posts/RsxT7PffvR8
    3. Investigating the idea of converting the hand torch: https://plus.google.com/+PetervanderWalt/posts/GVs1mPf6vhA
    4. Carved new holder out of PTFE and straigtened the copper tube after grindning away the plastic: https://plus.google.com/+PetervanderWalt/posts/GUggT4eY6Wd
    5. Filled it with Epoxy Resin https://plus.google.com/+PetervanderWalt/posts/2d7V5TiwEPg
    (The comment threaads under each post holds valuable info too)
    @EfrainLenisMaturano
    Negative on this particular machine. The person I was building it for's son kicked his dad out of the factory and cut off the funding over some family fued, and that sadly ended the project too
    I did later go on to build a plasma running on OpenBuilds VSLOT instead:
  4. Don_Karlos
    I built one! I finished the steel frame after getting the laser parts. The design had to be converted a little:) In Germany you don't get the 76x25 Steel tube for the X-rail. I ended up buying a 45x25 and a 35x25 which is available. The carriage works as well on a 80x25 rail. The carriages for Y-axis are missing one slot for the weldin nose of the long Motorplates. I cut those two noses of. And I had to open up the cut out for the 80x25 X-rail.
    If I finish it and have a running machine I'll post a video:)
    IMG_6595.jpg IMG_6597.jpg IMG_6598.jpg IMG_6599.jpg IMG_6600.jpg IMG_6601.jpg IMG_6602.jpg IMG_6603.jpg IMG_6604.jpg IMG_6605.jpg IMG_6606.jpg IMG_6607.jpg
    MaryD likes this.
    Amazingly awesome! You just made my weekend! Cant wait to see the final result of your german engineering, improving on my sadly never completed project :)
    Anthony Bolgar likes this.
  6. geduss
    geduss New
    Hello
    Noticed a dxf missing joint?
    Good catch!
    Its been so long, i dont recall, perhaps it was on my cut parts too, since those are more for alignment you could just grind off the extra tab, or fix the drawings before you send them in
  8. javornh
    javornh New
  9. Ioannis Nterkarampetian
    Hello,
    do you have the plans to send me please?
    Click Files and Drawings at the top of this page
  11. LoCo DIYer
    Were you ever able to get this bad boy wrapped up? Would love to see your finished build and hear about your build in general.
    Sadly no :(
  13. Squirrel101
    Hi Peter, super design you have here. I'm also in ZA and want to attempt this design of yours. I have fixed the dxf file with the missing tab slots. Are there any suggestions or improvements on this design? Can you advise of local suppliers for these motors etc?
    I like this design as its simple and like you said, the vslot and extruded aluminium price is ridiculous here in ZA. I aim to do simple projects so this suits me fine. Any help will be appreciated!
    Phew no sorry, been out of the local game since 2015, not sure who'se still around? Microrobotics, Netram, Communica, etc? Most of the belts/pulleys and stuff used on the build was just Aliexpress
    No other suggestions, as mentioned before in this thread, the guy I was building this for had a fight with his son and the son kicked him out of the business. Last I heard the unfinished machine still stood on the mezzanine floor of the son's factory :)
    Squirrel101 likes this.
