Mini v-wheels distance?
Discussion in 'Helpful Tools' started by MarkM_NJ, Nov 13, 2017.
  1. MarkM_NJ
    MarkM_NJ Well-Known
    hello everyone,
    I'm designing new plates. I'm trying to find what the distance should be for the mini v-wheels to ride on the outside of v-rail. Would anyone have the number? I found the +20.6 for standard wheels. Also any benefit to use eccentric spacers on both top and bottom? Is there a calculation to how many wheels to have on a plate?
    Thanks,
    Mark
  2. Rick 2.0
    12.0 + nominal extrusion width.
    Also for regular V-wheels 20.0 + extrusion width is generally the safest route.
    Kyo and MaryD like this.
  3. MarkM_NJ
    MarkM_NJ Well-Known
    Thanks Rick!
  4. MarkM_NJ
    MarkM_NJ Well-Known
    Rick would you happen to know a good rule of thumb for screw lengths to use? I'm going to be using c-beam, wondering how far the screw should thread in?
  5. Rick 2.0
    When using the C-BeamĀ® End Mount 20mm screws are generally sufficient. These give about 10mm embedment into the end of the extrusion.
  6. THE LINK
    THE LINK New
    Get 25mm shouldered, spacers,crush washers and lock nuts. I suppose it depends what plates your using but I made mistake here also. Think Im go with 2 bolts per wheel and extra nuts for tightening as seems common they shake loose, maybe a bunch of crush washers.
  7. MarkM_NJ
    MarkM_NJ Well-Known
    Thanks guys!
