C beam machine (with larger T-slot platform)
Discussion in 'CNC Mills/Routers' started by Dangatech, Sep 19, 2017.
  1. Dangatech
    Dangatech New
  2. Dangatech
    Dangatech New
    Larger image
  3. Xernami
    Xernami New
    Very interesting to see this idea built and ready to go.
    I went the same route you did with the table (the tape on MDF approach doesn't hold small parts well...), excepted for the Y-Axis, which was doubled up to avoid deflexion when machining far from the centerline.
    I see the linear rail on the left of your picture. Any plans to upgrade de C-Beams or just some stuff lying around?
  4. Sprags
    Sprags Well-Known
    I like the idea of building the table out of extruded aluminum as opposed to MDF or even a solid aluminum plate because the weight savings for one is huge plus as you mention you now have a different surface to hold your parts plus ways to attach various types of workholding such as vises or clamping. I hadn't noticed other builds filling in the slots of all of the beans like your photo shows. That's a smart thing to do too.
