Routy CNC Router (V-Slot Belt & Pinion)
Discussion in 'CNC Mills/Routers' started by Mark Carew, Nov 11, 2013.
  1. Rick 2.0
    Here is one suggestion Plywood Clamp. It could be simplified a bit more by replacing the second screw with a small block of wood.
    Based on your goal of wanting a platform to learn cnc and one that will cut aluminum plates for a future Ox, I would suggest starting with the C-Beamâ„¢ Machine - Plate Maker. For the Routy to do well with aluminum you'll need to keep it fairly small and that eliminates any real direct upgrade potential. The C-beam Machine will give you much better results in aluminum as it has a higher resolution due to using the screw drive.
  2. Nate Green
    I know it's been a while since anyone has posted to this thread but what is the actual finished working area? Thanks for the info. Can't wait to build this!
  3. Giarc
    From the beginningof the build thread:
    However you should be able to make it bigger or smaller.
  4. Nate Green
    Quick question. Why does the parts list NOT reflect the photos of the build? No where in the parts list does it mention single t nuts but I see many of them being used. Also the parts list does not mention M5 locknuts but I also see many of them. The main frame photos show 2 long and 2 short sections of 20x80 but the parts list states one section of 20x80 cut into two pieces. I'm getting very close to ordering parts to build the routy but I'm a little discouraged at the differences. Is there an updated parts list? Are there any actual build videos? Please let me know.
  5. Rick 2.0
    This is a very old design and quickly fell by the wayside once the Ox came along. By rough count, it appears that 86 T-nuts are required. As for the regular 5mm lock nuts, those are included with the wheel kits.
    Take another look at the photos. The long side rails are 20x60. The only pieces of 20x80 are the base supports across the ends. Sorry no videos available. It might be a good idea to download the Sketchup file so you can see how it all goes together.
  6. Greenman
    Greenman New
    I am finally getting back to finishing my Routy build. My question is has anyone ever used a trim router with this build? Also is there a source for spindles for this cnc. I hate to use a dremel as they have a lot of run out. Thanks Bill
  7. Rick 2.0
    You might just give it a try. I would probably consider the Makita RT0701C as it's about the lightest of the bunch. The beauty of the OB system is how easily things can be modified if something doesn't work. You might also consider one of the smaller spindles. A good adaptation of a smaller spindle on a lightweight system can be found here: https://openbuilds.com/builds/candler-customs-custom-cnc-machine.6234/
  8. Neil Rosenberg
    Neil Rosenberg Journeyman
    Up until recently I would have suggested the DEWALT DNP611, it's been the "go-to" spindle for hobby style CNC routers. That is, until DeWalt stopped selling the motor-only. Too popular I guess. Now if you want that motor you have to buy a complete router kit and throw away everything but the motor. Sad, but in reality only adds a few bucks to the cost.
    #608 Neil Rosenberg, Mar 7, 2020
  9. Greenman
    Greenman New
    IMG_5423~photo.JPG 000_1182.JPG 000_1182.JPG IMG_5423~photo.JPG Thanks for your keep. Has anyone on the forum used air tools? I use a modified die grinder for inlay work. They have a 1/8" collet and they are very accurate and have little run out. I will try to upload a photo.
